Canon Support for PowerShot G7 X Mark II | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
20.1 Megapixel*, 1.0-inch CMOS (sensor aspect ratio: 3:2)
* Image processing may cause a decrease in the number of pixels.
Total Pixels
Approx. 20.9 Megapixels
Effective Pixels
Approx. 20.1 Megapixels
Focal Length
8.8 (W) - 36.8 (T) mm (35mm film equivalent: 24-100mm)
Optical Zoom
4.2x
Digital Zoom
4x
Focusing Range
Normal/Auto: 2.0 in. (5 cm) - infinity (W), 1.3 ft. (40 cm) - infinity (T)
Macro/Underwater Macro: 2.0 in. - 1.6 ft. (5-50 cm) (W)
Quick: 5.0-65.6 ft. (1.5-20m) (W), 5.0-65.6 ft. (1.5-20m) (T)
Autofocus System
TTL Autofocus, Manual Focus
Optical Viewfinder
N/A
LCD Monitor
3.0-inch tilt-type TFT color liquid crystal, with biaxial tilt for low and high angle shooting
LCD Pixels
Approx. 1.04 million dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/1.8 (W), f/2.8 (T)
Shutter Speed
1-1/2000 sec. (in Auto mode)
15 -1/2000 sec. (in all shooting modes)
BULB (in M mode only)
1/8 minimum in Manual Movie Mode
Sensitivity
ISO 125-6400 (in Auto mode)
Max. ISO Speed in P mode is ISO 12800
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments
Videos: &plusmn;3 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater WB, Kelvin Settings, Custom 1-2
Built-in Flash
Auto, On, Slow Synchro, Off
Flash Range
1.6 ft. (50 cm) - 23 ft. (7.0 m) (W), 1.3 ft. (40 cm) - 13 ft. (4.0 m) (T)
Image brightness may diminish depending on the shooting distance
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
Shooting Modes
C, M, Av, Tv, P, Hybrid Auto, Auto, Self Portrait, Portrait, Panning, Star Portrait, Star Nightscape, Star Trails, Star Time-Lapse Movie, Handheld Night Scene, High Dynamic Range, Fish-eye Effect, Art Bold Effect, Water Painting Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Grainy B/W, Underwater, Fireworks, Standard Movie, Short Clip, Manual Movie, Time-Lapse Movie, iFrame Movie
Self Timer
Off, 2 sec., 10 sec., Custom
Wireless Control
Wi-Fi&reg; / NFC
Continuous Shooting
One Shot H: Approx. 8.0 shots/sec. (max. 30 shots)
One Shot L: Approx. 4.0 shots/sec.
Servo H: Approx. 5.4 shots/sec. (max. 46 shots)
Servo L: Approx. 4.0 shots/sec.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Fine / Normal
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG), RAW (Canon original: 14-bit, CR2)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Description
List/Play Digest Movies, Story Highlights, Protect, Favorites, Erase, Image Search, Slideshow, Rotate, Album Playback, Short Clip Mix, Resize, Cropping, Red-Eye Correction, Face ID Info, Creative Filters, RAW Image Processing, Photobook Set-up, Image Transition Effect, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Image Jump with Control Ring/Front Dial, Set Touch Actions, Playback Information Display
Audio Out
Stereo
Other
Direct connection to Canon SELPHY, PIXMA Photo Printers &amp; PictBridge compatible printers
Power Source
Battery Pack NB-13L, Battery Charger CB-2LH
In-Camera Charging via USB Cable available through Compact Power Adapter CA-DC30* (Charging time: Approx. 5 hrs.)**
* To use CA-DC30, IFC-600PCU is necessary.
** Charging time varies considerably depending on the remaining battery power.
Shooting Capacity
Approx. 265 shots with Screen On (CIPA compliant)
Approx. 355 shots with ECO Mode
Playback Time
Approx. 5 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.15 x 2.40 x 1.65 in. / 105.5 x 60.9 x 42.0mm
Weight
Approx. 11.3 oz. / 319g (including battery and memory card)
Approx. 10.4 oz. / 294g (camera body only)
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
Wireless API Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: PowerShot G7 X Mark III: Firmware Version 1.1.0
Advisory Type
Date 10.23.19
Title Canon Support | Service Notice: Picture Style File Registration
Advisory Type
Date 12.15.19
Title Canon Support | Firmware Notice: PowerShot G7X Mark II: Firmware Version 1.0.1.0
Advisory Type
Date 10.26.16
Title Canon Support | Firmware Notice: PowerShot G7 X Mark II: Firmware Version 1.1.0
Advisory Type
Date 10.18.20
Title Firmware Notice: PowerShot G7X Mark II: Firmware Version 1.2.0.0
Advisory Type Firmware Notice
Date 05.18.23
Title To Users of the Compact Digital Camera PowerShot G7 X Mark II
Advisory Type
Date 09.19.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
