Canon Support for imageCLASS MF445dw | Canon U.S.A., Inc.
imageCLASS MF445dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 04.07.25
File Size 1.32 MB
Date 10.04.19
File Size 958.35 KB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 04.07.25
File Size 1.85 MB
Date 07.20.23
File Size 405.58 KB
Date 01.31.23
File Size 2.92 MB
Date 01.31.23
File Size 2.26 MB
Date 09.17.24
File Size 1.85 MB
Date 10.04.19
File Size 815.82 KB
Date 12.02.20
File Size 961.90 KB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.85 MB
Date 12.20.23
File Size 1.32 MB
Date 07.20.23
File Size 146.85 KB
Date 01.31.23
File Size 2.16 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 09.04.19
File Size 408.66 KB
Date 12.24.20
File Size 819.56 KB
Date 01.31.23
File Size 1.63 MB
Date 04.27.23
File Size 460.45 KB
Date 04.27.23
File Size 1.72 MB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
imageCLASS MF445dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF445dw
Products ChromeOS
imageCLASS MF445dw
imageCLASS MF445dw Spec Sheet
imageCLASS MF445dw
MAIN UNIT
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Fax
ITEM CODE 3514C004
PROCESSOR Canon Custom Processor
CONTROL PANEL5" Color Touch Panel
MEMORY1 GB
STANDARD INTERFACE CONNECTION USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Optional: 550-sheet Paper Cassette (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)Standard: 65 Sheets
SUPPORTED MEDIA TYPES Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIMEFrom Power On: 14 Seconds or Less
From Sleep Mode: 4 Seconds or Less
DIMENSIONS (W x D x H) Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
INSTALLATION SPACE (W x D x H) Standard (Desktop): 17.9" x 34.8" x 26.2" (453 mm x 883 mm x 664 mm)
Fully Configured: 17.9" x 34.8" x 31.3" (453 mm x 883 mm x 795 mm)
WEIGHT2Unit: Approx. 35.8 lb. (16.2 kg)
Boxed Weight: Approx. 45.9 lb. (20.8 kg)
OPERATING SYSTEM UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.9.5 (or later)
PRINT SPECIFICATIONS
PRINTING METHOD Laser Beam Printing
PRINT SPEED3 Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT OUT TIME Approx. 5.3 Seconds
RECOMMENDED MONTHLY PAGE VOLUME 750 - 4,000 Pages
PRINT RESOLUTION (dpi)600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, PCL®5, Adobe PostScript 3®
DOUBLE-SIDED PRINTING Automatic (Standard)
DIRECT PRINTAvailable from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES4 Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service
FONTS PCL: 45 Fonts
PS: 136 Fonts
PRINT FEATURES Secured Print, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations
COPY SPECIFICATIONS
COPY SPEED Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST-COPY-OUT-TIME (LETTER) Approx. 6.2 seconds
COPY RESOLUTION600 x 600
COPY SIZE Platen: Up to Letter
ADF: Up to Legal
MULTIPLE COPIESUp to 999 Copies
COPY EXPOSURE Automatic
MAGNIFICATION 25% - 400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
COPY FEATURES Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPE Single-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY 50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES Legal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS Single and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book
PULL SCAN ScanGear MF for TWAIN, WIA, and ICA
SCAN RESOLUTION300 x 600, 600 x 600
SCAN TO MOBILE DEVICES Canon PRINT Business
SCAN SPEED (LETTER)Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW)
Double-sided: 26/70 ipm (300 x 300 dpi) (Color/BW)
MEMORY MEDIA Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
ADDRESS BOOK LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION 600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUICATION PROTOCOL File: FTP, SMB Email/iFax: SMTP, POP3, iFax (Simple)
FILE FORMAT Standard: TIFF, JPEG, PDF (Compact, Searchable)
FAX SPECIFICATIONS
MODEM SPEED Super G3: 33.6 kbps
G3: 14.4 kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Statement to Legal
FAX MEMORY Up to 512 Pages
SPEED DIALSMax. 281
GROUP DIALS / DESTINATIONS Max. 299 Dials
SEQUENTIAL BROADCASTMax. 310 Addresses
MEMORY BACKUPYes
FAX FEATURESRX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Department ID Authentication
DATA Standard: Verify System at Startup
NETWORK Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT Secure Print, High Compression PDF, Searchable PDF
WI-FI AUTHENTICATION METHODS Wi-Fi Infrastructure Mode:
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTIONMaximum: Approx. 1330 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 0.34 KwH
STANDARDSENERGY STAR® Qualified, Currently Rated EPEAT Silver1
CONSUMABLES
TONERCartridge 057 Black, Standard - Yields up to 3,100 Pages
Cartridge 057 Black, High Capacity - Yields up to 10,000 Pages
FOOTNOTES
  1. For current EPEAT rating (Gold/Silver/Bronze), please visit epeat.net.
  2. Includes consumables.
  3. Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
  4. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
  5. Warranty program is subject to certain conditions and restrictions. See warranty card for details.
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
