Canon Support for imageCLASS MF416dw | Canon U.S.A., Inc.
imageCLASS MF416dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 17ppm (2-sided plain paper letter) / 35ppm (1-sided plain paper letter)1 |
First Print Time | 6.3 seconds or less (letter)2 |
Printer Language | UFR II (Host-based), PCL6 (5c, XL) / PS |
Print Resolution | Up to 600 x 600 dpi; (1200 x 600 dpi quality) |
Maximum Print Size | Up to Legal (8.5 x 14 inches) |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
Print Memory | 1 GB (Shared) |
Direct Print from USB | PDF/JPEG/TIFF formats |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 35ppm (letter) |
Duplex Copy Speed | Up to 17cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 16 seconds or less from power on |
First Copy Time | 10 seconds or less3 |
Recovery Time | 5 seconds or less |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25-400% in 1% increments |
Copy Size | Platen: Up to 8.5 x 11, Feeder: 5.1 x 5.5 to 8.5 x 14 |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 406 x 391 dpi (ultra fine) |
Transmission Time | Approx. 3 seconds per page (ECM-JBIG, transmitting from the memory at 33.6 Kbps) |
Memory Capacity | Up to 512 sheets4a |
Speed Dials | Up to 281 dials |
Group Dialing | 199 destinations |
Sequential Broadcasting | 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (sending only), DRPD, ECM, Auto Redial |
Memory Backup | Yes |
Activity Reports | Fax Activity / Result Reports, Fax Activity Management Reports |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail, FTP, iFax Simple |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical), 9600 x 9600 (software interpolated resolution) |
Scan Size | Platen: Up Letter, Feeder: Up to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA 2.0, ICA |
Output File Formats | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Scan Features | Push Scan, Pull Scan, Scan to USB |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Send Specifications
Scan to Email | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Scan to SMB | JPEG, TIFF, PDF, PDF(Compact), PDF (OCR) |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 50-sheet multipurpose tray5 |
Optional Paper Source(s) | 500-sheet cassette5 (PF-44) |
Document Feeder | Duplex Auto Document Feeder 50-sheets5 |
Paper Output | 150 sheets (face down) |
Paper Weight | 16-34 lb. (bond, plain paper) |
Media Sizes | Letter, Legal, A4, A5, B5, Executive, Statement |
Media Types | Plain, Heavy, Recycled, Color, Label (20 sheets, mp tray), Envelope |
Envelope Capacity | 5 (Multipurpose Tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), 802.11 b/g/n Wireless6, Wi-Fi Direct Connection6a, NFC7 (Near Field Communication) |
WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business8, Apple® AirPrint®9, Mopria™ Print Service10, Google Cloud Print™11 |
Network Functions | Print, Scan (SMB, E-mail, FTP), PC Fax |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4, IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1 (IPv4,IPv6), SNMPv3 (IPv4, IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac OS X® 10.6 & up |
Cable Included | Power Cord, Phone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
Power Consumption | Approx: 600 W (during operation), 9 W (standby), 2.2 W (energy saver / sleep mode) |
Typical Energy Consumption | 1.2kWh |
General Specifications
Dimensions | 15.4"(W) x 18.6"(D) x 17.0"(H) |
Unit Weight (without/with cartridge) | 40.6 lbs w/o cartridge, 42.3 w/ cartridge |
Package Weight | 51.6 lbs |
Cartridge Type | Cartridge 119 (Yields approximately 2,100 pages), Cartridge 119II (Yields approximately 6,400 pages) Single Cartridge System *Yields based on ISO/IEC Standard |
Department Counter | No |
LCD Display | 3.5 Inch, Color Touch LCD |
Duty Cycle | Up to 50,000 pages per month |
Department ID Management | Yes, up to 300 ID's |
Security | IEEE802.1x, SNMPv3, HTTPS, IPSEC, Secure Print (up to 32 jobs), Department ID up to 300 IDs |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty12 (Extended warranty available) |
PRODUCT LIMITED WARRANTY
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
