Canon Support for EOS R5 Mark II | Canon U.S.A., Inc.
EOS R5 Mark II
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.02.24
File Size 142.00 B
Date 09.30.24
File Size 142.00 B
Date 09.30.24
File Size 142.00 B
Date 08.21.24
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type Digital interchangeable lens mirrorless camera
Image Processor DIGIC X (with DIGIC Accelerator co-processor)
Recording Media Card 1: CFexpress memory card
Type B: Card slot
CFexpress 2.0 and VPG400 supported
Up to 2 TB is supported (a card exceeding 2 TB is handled as a card of 2 TB).
Card 2: SDXC/SDHC/SD memory card
Compatible with UHS-II
Eye-Fi cards and MultiMediaCards (MMC) not supported
Compatible Lenses Canon RF lens group (including RF-S lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type Canon designed full-frame back-illuminated stacked CMOS sensor
(compatible with Dual Pixel CMOS AF)
Effective Pixels Approx. 45 megapixels
Screen Size Approx. 36.0 x 24.0 mm
Pixel Unit Approx. 4.40 m square
Total Pixels Approx. 50.3 megapixels
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature (1) Self Cleaning Sensor Unit
Removes dust adhering to the low-pass filter.
At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indicated on the screen) or manually (taking about approx. 8 sec. as indicated on the screen).
After manually activated cleaning, the camera will automatically restart (Power OFF to ON)
When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
(2) Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
Not available with RF-S/EF-S lenses. Setting may not be possible depending on the combination of functions (see the menu screen).
(3) Manual cleaning (by hand)
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*.
*Supports time difference information.
Image Format RAW: RAW / C-RAW
JPEG / HEIF: L / M / S1 / S2
Movies:
RAW
XF-HEVC S YCC422 10bit
XF-HEVC S YCC420 10bit
XF-AVC S YCC422 10bit
XF-AVC S YCC420 8bit
Folder When a card is inserted, the following folders are created automatically. DCIM, CRM, XFVC, and MISC folders
Folder Actions Select folder, Create folder, Change folder name
Still Photos DCF standards compliant.
The following folder is created automatically in the DCIM folder.
Default: EOSR5
*This can be changed to any character string (5 characters).
Movies XF-HEVC S / XF-AVC S format REEL_**** in XFVC folder
A normal movie file (MP4) is saved. REEL_**** in CRM folder
A RAW movie file (CRM) is saved. In each REEL_**** folder:
* Up to 999 files can be saved in one folder. When [Add News Metadata: On], an XML file is saved to the same location as the movie file in the card after movie recording.
News Metadata XF-HEVC S / XF-AVC S format
News Metadata is saved in the XMLTAG folder in the currently selected card.
* Up to 100 XML files can be saved in one XMLTAG folder.
Still & Movie Dual shooting (still & movie): On/Off
* When using LP-E6P Battery / DR-E6P Power Adapter
Drive mode: High speed / Low speed / Single shooting
* High speed shooting: Max. approx. 7.5 shots/sec. (NTSC), Max. approx. 6.2 shots/sec. (PAL)
* Low speed shooting: Max. approx. 5.0 shots/sec. (NTSC), Max. approx. 4.1 shots/sec. (PAL)
JPEG quality: 110 (settable in 10 levels)
Movies Main recording format: XF-AVC S YCC420 8 bit Movie recording size
Resolution: Full HD (Normal)
Frame rate: 29.97 (NTSC) / 25.00 (PAL) fps
Compression method / LGOP
Still Photos RGB primary color filters
Settings (1) Auto (Ambience priority/White priority)
(2) Daylight
(3) Shade
(4) Cloudy*1
(5) Tungsten light
(6) White fluorescent light
(7) Flash
(8) Custom (Custom WB)
(9) Color temperature*2
*1: Effective also in twilight and sunset.
*2: With an EL / EX-series speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000K if the flash unit does not have the color temperature information transmission feature.
* White balance can be adjusted during movie recording.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Shifted from the color temperatue of the current WB mode.
Blue/amber and magenta/green shift can be set at the same time.
WB Bracketing available, up to ±3 levels Blue/amber or magenta/green, via Quick Control Dial
Type OLED color electronic viewfinder; 0.5-inch, approx. 5.76 million dots
Coverage Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 25mm eyepoint).
Magnification / Angle of View Approx. 0.90x / Approx. 41.4 degrees (with 50mm lens at infinity, -1 m-1)
Eye Point Approx. 25mm (at -1 m-1 from the eyepiece lens end)
Dioptric Adjustment Range Approx. -4.0 to + 2.0 m-1 (dpt)*
*1: Dioptric adjustment lock mechanism
Viewfinder Information (1) Maximum burst
(2) Possible shots/Sec. until self-timer shoots
(3) Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
(4) Shooting mode
(5) AF method
(6) AF operation
(7) Image quality
(8) Card
(9) Drive mode
(10) Metering mode
(11) No. of remaining shots for focus bracketing, multiple exposures, or interval timer
(12) Electronic level
(13) Movie recording time available
(14) Battery level
(15) Image Stabilizer (IS mode)
(16) Histogram (Brightness/RGB)
(17) Quick Control button
(18) Anti-flicker shooting
(19) White balance/White balance correction
(20) Picture style
(21) Auto Lighting Optimizer
(22) Still photo cropping / Aspect ratio
(23) AF point (1-point AF)
(24) AEB/FEB
(25) View Assist
(26) HDR PQ
(27) Flash ready / FE lock / High-speed sync
(28) Electronic shutter
(29) Touch shutter / Create folder
(30) AE lock
(31) Shutter speed / Multi-function lock warning
(32) Aperture value
(33) Wi-Fi® function
(34) Wi-Fi® signal strength
(35) Bluetooth® function
(36) Exposure simulation
(37) Magnify button
(38) ISO speed
(39) Highlight tone priority
(40) Exposure compensation
(41) Exposure level indicator
Focus Method Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 1053 zones (39 x 27)
Movies: Max. 975 zones (39 x25)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%
Stills: Max. 4368 positions (78 x 56)
Movies: Max 3354 positions (78 x 43)
* When set to [1-point AF] and selected using the screen and Multi-controller.
* Values for the selectable positions for AF points do not represent AF performance.
Focusing brightness range (still photo shooting) EV 7.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (movie recording) 4K30p: EV -5.5 to 21
Full HD30p: EV -5.0 to 21
(with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.)
Available AF Areas Spot AF
1-point AF
Expand AF area: Above/below/left/right
Expand AF area: Around
Flexible Zone AF 1
Flexible Zone AF 2
Flexible Zone AF 3
Whole area AF
Whole area tracking OFF Spot AF
Whole area tracking OFF 1-point AF
Whole area tracking OFF Expand AF area: Above/below/left/right
Whole area tracking OFF Expand AF area: Around
Available Subject Detection Auto
People
Animals (dogs / cats / birds / horses)
Vehicles (motorsports cars or motorcycles / aircraft / trains)
* Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
Selects the eye closer to the camera (as detected from the angle of the face).
At the same distance from the camera, selects the eye closer to the center of the image.
Right Eye:
Prioritizes the subjects right eye.
Left Eye:
Prioritizes the subjects left eye.
Metering Modes Real-time metering from CMOS image sensor (6144 [96x64] metering zones)
(1) Evaluative metering (AF point-linked)
(2) Partial metering (approx. 10.0% of the area at the center of the screen)
(3) Spot metering (approx. 5.0% of the area at the center of the screen)
(4) Center-weighted average metering
Metering Range EV -3 to 20 (at 73°F/23°C, ISO 100) (Still Photo Shooting)
Exposure Modes
Shooting Mode Name
Fv Flexible-priority AE
P Program AE
Av Aperture-priority AE
M Manual exposure
Tv Shutter-priority AE
BULB Bulb exposure
C1/C2/C3 Custom shooting
ISO Speed Range Manually Set
Normal ISO 100102400
Expanded L (equivalent to ISO 50), H1 (equivalent to ISO 204800) and H2 (equivalent to ISO 409600)
For [Highlight tone priority], the settable ISO speed range will be ISO 200 to 102400.
Expanded ISO cannot be set for HDR mode or during HDR PQ shooting.
ISO Auto range settings in still photo shooting
Auto Range ISO Speed
Minimum L (equivalent to ISO 50) to H1 (equivalent to ISO 204800)
Maximum ISO 100 to H2 (equivalent to ISO 409600)
ISO Auto details in still photo shooting
Shooting mode No Flash Using Flash
Compatible Lens Incompatible Lens
Fv / P / Tv / Av / M ISO 100*1*2102400*2 ISO 100*1*26400*2 ISO 100*1*21600*2
B ISO 400*3 ISO 400*3
*1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced].
*2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range].
*3: If outside the setting range, changed to the value closest to ISO 400.
Exposure Compensation
User-set ±3 stops in 1/3- or 1/2-stop increments
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock (1) Auto AE lock
AE is locked as soon as subjects are in focus using One-Shot AF when set to selected metering mode in [C.Fn2: AE lock meter. mode after focus].
(2) User-set AE lock
Use the AE lock button (update by pressing the button again) in Fv, P, Tv, Av, and M mode.
Enabled in all metering modes.
Type Electronically controlled focal-plane shutter
(1) Electronic first curtain
(2) Mechanical shutter
(3) Electronic shutter*
* Cannot be used in conjunction with the following functions: flash photography, HDR shooting, multiple exposures, Multi Shot Noise Reduction, AEB, HDR PQ, anti-flicker shooting, Dual Pixel RAW shooting, Digital Lens Optimizer [High].
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated.
* In electronic shutter shooting, fast shutter speeds of 1/10000 sec. or faster are only available in Tv or M mode (up to 1/8000 sec. in P, Av, or Fv mode).
Shutter Speeds Mechanical / 1st-curtain Electronic shutter:
1/8000th sec 30 seconds, in 1/3 or ½-step increments
Electronic shutter:
1/64,000th sec 30 seconds, in 1/3 or ½-step increments
X-sync Speed Mechanical Shutter: 1/200 sec.
Elec. 1st-curtain: 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Still Photo IS In-body IS operation can be selected when using a non-IS lens.
Always on
Only for shot (no stabilization in viewfinder/LCD screen between shots)
Coordinated IS when used with Canon RF or RF-S lenses having optical Image Stabilization
Accessory Shoe Canon Multi-function accessory shoe
Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 stops in 1/3- or 1/2-stop increments
Continuous flash control E-TTL each shot / E-TTL 1st shot
HDR Shooting (HDR PQ) Disable / HDR PQ
Still Photo HDR PQ
Recording format Bit depth Color sampling method HDR specification
HEIF 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Movie HDR PQ
mp4 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Continuous HDR Shooting (still images) 1 shot only / Every shot
Maximum shooting Times
High-frame rate disabled 100.00 fps or more Maximum: 2 hr. 00 min. 00 sec.
59.94 fps or less Maximum: 6 hr. 00 min. 00 sec.
High-frame rate enabled 239.76 / 200.00 fps Maximum: 45 min. 00 sec.
119.88 / 100.00 fps Maximum: 1 hr. 30 min. 00 sec.
* Longest time available per recording.
* Except when recording stops from overheating or due to the power source used, errors, or other reasons.
File Format
Canon Log OFF ON (Canon Log 3)
HDR PQ OFF ON OFF
Container format MP4
Bit depth 8 bit 10 bit
Compression H.264 / MPEG-4 AVC H.265 / HEVC
Video signal recording
range
Full range (0-255) Full range (0-1023) Full range (128-1020)
Color sampling method YCbCr 4:2:0 YCbCr 4:2:2
Standards compliance Rec.ITU-R BT.709 Rec. ITU-R BT.2100
Color gamut Rec.709 Rec.2020 Rec.709 / Rec.2020 / Cinema Gamut
Audio IPB
(Standard)*
AAC / Linear PCM
IPB (Light) AAC
* Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable].
Estimated Recording time, Movie Bit Rate and File Size RAW, 8K-DCI Normal / 8K-UHD Normal
Recording format compression method/RAW type Frame Rate (fps) Total Recording Time (approx.) Video bit rate/(approx.Mbps) File Size (approx. MB/min.)
64 GB 256 GB 1 TB
RAW1 Standard
RAW
29.97 3 min. 13 min. 51 min. 2600 18631
25.00
24.00
23.98
Light
RAW
59.94 3 min. 13 min. 51 min. 2600 18631
50.00
29.97 5 min. 20 min. 1 hr. 19 min. 1670 11979
25.00 6 min. 24 min. 1 hr. 34 min. 1400 10048
24.00 6 min. 25 min. 1 hr. 39 min. 1340 9619
23.98
XF-HEVC S
YCC422
10-bit
High-quality Intra 24.00 4 min. 17 min. 1 hr. 9 min. 1920 13735
23.98
Standard Intra 29.97 4 min. 18 min. 1 hr. 14 min. 1800 12877
25.00 5 min. 22 min. 1 hr. 28 min. 1500 10731
24.00 5 min. 23 min. 1 hr. 32 min. 1440 10302
23.98
Light Intra 29.97 7 min. 28 min. 1 hr. 51 min. 1200 8585
25.00 8 min. 34 min. 2 hr. 13 min. 1000 7155
24.00 8 min. 35 min. 2 hr. 18 min. 960 6869
23.98
Standard LGOP1 29.97 15 min. 1 hr. 3 min. 4 hr. 6 min. 540 3865
25.00
24.00
23.98
XF-HEVC S
YCC420
10-bit
Standard LGOP2 29.97 21 min. 1 hr. 25 min. 5 hr. 33 min. 400 2863
25.00
24.00
23.98
1 v90 SD card speed or CFexpress 2.0 speed required
2 v60 SD card speed or CFexpress 2.0 speed required
* Requires CFexpress 2.0 Type-B [400MB/sec. or more]. SD cards not compatible except where noted.
* Video bit rate indicates video only; audio and metadata are not included.
* When [Audio format: AAC / 16bit / 2CH] is set (when set to RAW, LPCM / 24bit / 4CH).
* When [Add News Metadata: Off] is set.
* Movie recording stops when the maximum recording time per movie is reached.
* When set to 4K-UHD, 24.00 fps is not available.
Estimated Recording Time, Continued.
64 GB 256 GB 1 TB
S RAW Standard
RAW
59.94 4 min. 18 min. 1 hr. 11 min. 1860 13338
50.00 5 min. 21 min. 1 hr. 25 min. 1550 11121
29.97 9 min. 36 min. 2 hr. 22 min. 930 6686
25.00 10 min. 43 min. 2 hr. 49 min. 780 5613
24.00 11 min. 45 min. 2 hr. 56 min. 750 5399
23.98 11 min. 45 min. 2 hr. 59 min. 740 5327
Light
RAW
59.94 10 min. 40 min. 2 hr. 37 min. 840 6042
50.00 12 min. 48 min. 3 hr. 9 min. 700 5041
29.97 20 min. 1 hr. 20 min. 5 hr. 13 min. 420 3038
25.00 24 min. 1 hr. 36 min. 6 hr. 15 min. 350 2538
24.00 25 min. 1 hr. 41 min. 6 hr. 38 min. 350 2395
23.98
XF-HEVC S
YCC422
10-bit
Standard LGOP 29.97 1 hr. 3 min. 4 hr. 12 min. 16 hr. 25 min. 135 968
25.00
24.00
23.98
XF-HEVC S
YCC420
10-bit
Standard LGOP 29.97 1 hr. 25 min. 5 hr. 40 min. 22 hr. 9 min. 100 718
25.00
24.00
23.98
XF-HEVC S
YCC420
8-bit
25.00
24.00
23.98
1. Requires CFexpress 2.0 Type-B [400MB/sec. or more]
* When [Audio format: AAC / 16bit / 2CH] is set.
Card Performance Requirements 4K-DCI Normal / 4K-UHD Normal
64 GB 256 GB 1 TB
XF-AVC S
YCC422
10-bit
High-qulity Intra 29.971 14 min. 56 min. 3 hr.42 min. 600 4294
25.001 17 min. 1 hr. 8 min. 4 hr. 26 min. 500 3579
24.002 17 min. 1 hr. 11 min. 4 hr. 37 min. 480 3436
23.982
Standard Intra2 29.97 18 min. 1 hr. 15 min. 4 hr. 56 min. 450 3221
25.00 22 min. 1 hr. 30 min. 5 hr. 55 min. 375 2685
24.00 23 min. 1 hr. 34 min. 6 hr. 10 min. 360 2577
23.98
Light Intra2 29.97 28 min. 1 hr. 53 min. 7 hr. 24 min. 300 2148
25.00 34 min. 2 hr. 16 min. 8 hr. 52 min. 250 1791
24.00 35 min. 2 hr. 22 min. 9 hr. 14 min. 240 1719
23.98
Standard LGOP3 29.97 56 min. 3 hr. 47 min. 14 hr. 47 min. 150 1075
25.00
24.00
23.98
1 v90 or higher SD card speed required.
2 v60 or higher SD card speed required.
3 U3 or higher SD card speed required.
* Requires CFexpress 2.0 Speed
* Same applies when [Movie cropping: Enable] is set.
Video AF Dual Pixel CMOS AF; Movie Servo AF available in AF Menu
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording (On/Off) 3 or 5 seconds; user-selectable
Time-lapse Movie Setting Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5)
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2)
2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 2.1 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view
Coating Clear View LCD II
Anti-smudge coating applied.
Anti-reflection coating not applied.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
Item Still Photo Movie
Magnify zoom display 1.5x10x (15 levels) -
AF point display Yes -
Grid display Off / 3×3 / 6×4 / 3×3+diag -
Zebra display - Yes
False Color display - Yes
Rating OFF / 1 to 5 Stars
Select images / Select range / All images in folder / All images on card / All
found images
Image Search Search conditions
Rating / Date / Folder / Protection / Type of file
Protect Select images / Select range / All images in folder / Unprotect all images in
folder / All images on card / Unprotect all images on card / All found images
Shooting information display No information display / Basic information display / Detailed shooting
information display
Highlight Alert White areas without image data blink in single-image display.
Histogram Brightness / RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen The following settings are available for the [Quick Control screen] during movie recording.
View 1: Conventional Quick Control screen
View 2: Cinema EOS-style Quick Control screen
Protection (1) Single image (select image)
(2) Select range
(3) All images in a folder
(4) All images on card
Image browsing and image search can be based on ratings.
Ratings-based image selections also possible with DPP.
(5) All found images (only during image search)
Erase Except protected images
(1) Select images to erase
(2) Select range
(3) All images in folder
Compatible Printers Direct printing from camera not supported
DPOF Compliant to DPOF Version 1.1
Standards Compliance IEEE 802.11b/g/n/a/ac
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n/a/ac)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Frequency: 5180 to 5825 MHz
Channels: 36 to 165 channels
Connection Method (1) Camera access point mode
(2) Infrastructure mode
Security
Connection Method Authentication Encryption
Encryption Key Format and Length
Camera Access Point WPA2 / WPA3-Personal AES ASCII 8 characters
Open Disable
Infrastructure Open WEP Hexadecimal 10 digits
Hexadecimal 26 digits
ASCII 5 characters
ASCII 13 characters
Disable
Shared key WEP Same as WEP above
WPA / WPA2 / WPA3-Personal TKIP
AES
1-127 characters
WPA / WPA2 / WPA3-Enterprise -
Communication with a Smartphone Images can be viewed, controlled, and received using a smartphone.
Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
Images can be sent to a smartphone.
NFC connection: Not supported
Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Not supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.
From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 5.0 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
USB Video Class (UVC) Available
* The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB.
Custom Controls Customizable Buttons
Shutter button
Movie button
AF-ON button
AE lock button
AF point button
Depth of field preview button
Lens AF stop button
Multi-function button
Set button
Multi-controller
Lens function button
Speedlite menu direct button
Customizable Dials Main dial
Quick control dial 1 & 2
Lens Control ring
My Menu Registration Up to six top-tier menu items and Custom Functions can be registered.
Up to five My Menu tabs can be added.
My Menu tab overall operations Adding a tab
Deleting tabs in a batch
Deleting all tab items
Setting the menu display
My Menu tab detailed operations Selecting a registered item
Sorting registered items
Deleting selected registered items
Deleting registered items in a batch
Deleting tabs
Changing a tab name (16 ASCII characters)
USB Terminal Equivalent to SuperSpeed Plus USB (USB 3.2 Gen 2) For PC communication Terminal type: USB Type-C Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
Battery Canon LP-E6P battery pack (LP-E6NH/LP-E6N can also be used but functionality is limited)
LP-E6 cannot be used
With the AC Adapter AC-E6N + DC Coupler DR-E6, AC power is possible (AC Adapter Kit ACK-E6 can also be used).
With the USB Power Adapter PD-E1, in-camera charging of LP-E6NH is possible. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Optional Battery Grip Compatible with Canon Battery Grip BG-R10
(Accepts one or two LP-E6NH, LP-E6N, or LP-E6 battery packs)
Battery Check Automatic battery check with 6-level display when the power switch is turned ON.
Displayed in 6 levels in viewfinder, and on LCD screen.
Battery info display in Set-up Menu:
Remaining capacity
Shutter count, on current battery charge
Recharge performance (battery's ability to hold charge; displayed in 3 levels
Start-up Time Approx. 0.4 sec.
Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 5.45 x 3.87 x 3.48 in. / 138.4 x 98.4 x 88.4mm
Based on CIPA standards.
Weight Approx. 1.5 lbs. / 670g (including battery, SD memory card; without body cap)
Approx. 1.3 lbs. / 588g (body only; without battery, card or body cap)
Working Temperature Range 32104°F / 040°C
Working Humidity Range 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Firmware Notice: EOS R5 Mark II: Firmware Version 1.0.2
Advisory Type Firmware Notice
Date 12.05.24
Title Firmware Notice: EOS R5 Mark II: Firmware Version 1.0.1
Date 09.26.24
Title Steps to resolve still image problem when using certain SanDisk SD cards with the Canon EOS R5 Mark II
Advisory Type Service Notice
Date 01.14.25
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Firmware Notice: EOS R5 Mark II: Firmware Version 1.0.3
Date 03.18.25
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
