Canon Support for EOS-1Ds | Canon U.S.A., Inc.
EOS-1Ds
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.10.08
File Size 5.33 MB
Date 04.16.09
File Size 6.96 MB
Date 10.15.10
File Size 8.08 MB
Date 06.10.08
File Size 10.99 MB
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 10.15.10
File Size 8.41 MB
Date 10.01.07
File Size 11.53 MB
Date 04.01.07
File Size 6.56 MB
Date 07.23.12
File Size 6.88 MB
Date 04.14.09
File Size 7.50 MB
Date 10.21.10
File Size 11.20 MB
Date 03.05.10
File Size 12.70 MB
Date 06.10.08
File Size 4.94 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR
Recording Media Type I or II CF Card
Image Format 35.8 x 23.8mm (1.4 x 1 in.)
Compatible Lenses Canon EF Lenses
Lens Mount Canon EF Mount
Image Sensor
Type High-sensitivity, high-resolution, large single-plate CMOS sensor
Pixels Effective pixels: Approx. 11.1 megapixels, Total pixels: Approx. 11.4 megapixels
Aspect Ratio 3:2
Color Filter System RBG primary color filter
Low Pass Filter Located in front of the CMOS sensor, non-removable
Recording System
Recording Format Design rule for Camera File system (except Color Matrix 4) and RAW
Image Format JPEG, RAW (12 bit)
File Size RAW & JPEG:1) Large/Fine: approx. 4.1 MB (4064 x 2704 pixels)
2) Large/Normal: approx. 1.7MB (4064 x 2704 pixels)
3) Small/Fine: approx. 1.4MB (2032 x 1352 pixels)
4) RAW: approx. 11.4MB (4604 x 2704 pixels)
* Exact file sizes depend on the subject and ISO speed.
Folders Folder creation and selection is possible
File Numbering 1) Consecutive numbering2) Auto reset3) Manual reset
Interface IEEE 1394 (with dedicated cable)
White Balance
Settings Auto, daylight, shade, overcast, tungsten light, fluorescent light, flash, custom, color temperature setting, personal white balance (Total 10 settings)
Auto White Balance Hybrid auto white balance with the CMOS sensor and a dedicated, external sensor
Color Temperature Compensation White balance bracketing: +/-3 stops in full-stop increments
Viewfinder
Type Glass pentaprism
Coverage Approx. 100% vertically and horizontally with respect to the effective pixels
Magnification 0.7x (-1 diopter with the 50mm lens at infinity)
Eye Point 20mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Interchangeable (9 types), Standard focusing screen: Ec-CIII
Mirror Quick-return half mirror (Transmission:Reflection ratio of 37:63, no mirror cut-off with the EF 1200mm f/5.6 or shorter lens)
Viewfinder Information AF information (AF points, focus confirmation light), exposure information (shutter speed, aperture, manual exposure, metering range, ISO speed, exposure level, exposure warning), flash information (flash ready, FP flash, FE lock, flash exposure level), JPEG format, number of remaining shots, CF Card information
Depth Of Field Preview Enabled with depth-of-field preview button
Eyepiece Shutter Built-in
Autofocus
Type TTL-AREA-SIR with a CMOS sensor
AF Points 45 AF points (Area AF)
AF Working Range EV 0-18 (at ISO 100)
Focusing Modes One-Shot AF, Al Servo AF, Manual focusing (MF)
AF Point Selection Automatic selection, manual selection, home position (switched to registered AF point)
Selected AF Point Display Superimposed in viewfinder and indicated on top LCD panel
AF Assist Beam AF-assist beam is emitted by the dedicated Speedlite
Exposure Control
Metering Modes TL full aperture metering with 21-zone SPC1) Evaluative metering (linkable to any AF point)2) Partial metering (approx. 8.5% of viewfinder at center)3) Spot metering- Center spot metering (approx. 2.4% of viewfinder at center)- AF point-linked spot metering (approx. 2.4% of viewfinder)- Multi-spot metering (Max 8 spot metering entries)4) Center weighted average metering
Metering Range EV 0-20 (at 20&deg;C with 50mm f/1.4 lens, ISO 100)
ISO Speed Range Equivalent to ISO 100-1250 (in 1/3-stop increments), ISO speed can be expanded to ISO 50 with C.Fn 3-1
Exposure Compensation Auto exposure bracketing (AEB): +/-3 stops in 1/3-stop increments
AE Lock Auto: Operates in One-Shot AF mode with evaluative metering when focus is achieved, Manual: By AE lock button in all metering modes
Shutter Electronically-controlled, focal-plane shutter1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec.Soft-touch electromagnetic release10-sec. or 2-sec. delayremote control with N3 type contact
Type Electronically-controlled, focal-plane shutter
Shutter Speeds 1/8000 to 30 sec. (1/3-stop increments), bulb, X-sync at 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. or 2-sec. delay
Remote Control remote control with N3 type contact
External Speedlite
EOS Dedicated Speedlite E-TTL autoflash with EX series Speedlite
PC Terminal Provided
Drive System
Drive Modes Single/Continuous
Continuous Shooting Speed Approx. 3 fps
Maximum Burst 10 shots. The maximum shots per burst depends on the subject, shooting mode, and ISO speed.
LCD Monitor
Type TFT color LCD monitor
Monitor Size 2.0 inches
Pixels Approx. 120,000
Coverage 100% with respect to effective pixels
Brightness Control Adjustable to one of five levels
Playback
Display Format 1. Single image with information2. Single image3. Four image index4. Nine image index5. Magnified view (P.Fn-30)
Highlight Alert In display formats 1 and 2 above, any overexposed highlight areas will blink in the image display.
Image Protection and Erase
Protection Erase protection of one image, all images in a folder, or all images in the CF Card can be applied or cancelled.
Sound Recording
Recording Methods The voice narration recorder with the built-in microphone is attached to the image.
File Format WAV
Recording Time Max 30 sec. per recording
Menus
Menu Categories 1. Recording menu2. Playback menu3. Set-up menu4. Custom/Personal Functions menu
LCD Monitor Language Japanese, English, French, German, Spanish
Firmware Update Update possible by the user
Power Source
Battery One Ni-MH pack NP-E3. AC power can be supplied via the AC adapter and DC coupler.
Number of Shots At 20&deg;C/68&deg;F: Approx. 600At 0&deg;C/22&deg;F: Approx. 450. These figures apply when a fully-charged Ni-MH Pack NP-E3 is used.
Battery Check Automatic
Power Saving Provided. Power turns off after 1, 2, 4, 8, 15, or 30 min.
Back-up Battery One CR2025 lithium battery
Dimensions and Weight
Dimensions (W x H x D) 156 x 157.6 x 79.9 mm / 6.1 x 6.2 x 3.1in
Weight 1265g / 44.6 oz. (body only; battery: 335g / 11.8 oz.)
Operating Environment
Working Temperature Range 0 - 45&deg;C/ 32 - 113&deg;F
Working Humidity Range 85% or lower
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Safety Notice: Lithium-Ion Battery Pack
Advisory Type
Date 12.31.08
Title Canon Support | Service Notice: TIFF Image Loss with Microsoft Windows Vista
Advisory Type
Date 02.21.07
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Service Notice: Information on Original Data Security and Original Data Verification Kits
Advisory Type
Date 01.24.15
Title Canon Support | Service Notice: Mistaken Origin Displayed on Packaging of Optional Interface Cables
Advisory Type
Date 02.19.08
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
