Canon Support for Color imageCLASS MF726Cdw | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.22.17
File Size 2.92 MB
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 04.07.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 12.22.17
File Size 809.44 KB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 460.45 KB
Date 04.27.23
File Size 1.72 MB
Date 08.28.15
File Size 6.86 MB
Date 09.25.23
File Size 1.20 MB
image icon
Canon PRINT - iOS
image icon
Canon PRINT - Android
Wireless Setup How-To Videos
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
Printer Specifications
Printer Type Color Laser MFP
Print Speed Up to 10ppm (2-sided plain paper letter)
Up to 21ppm (1-sided plain paper letter)1
First Print Time 14.3 seconds or less (letter)2
Printer Language UFR II LT (Host-based)
Print Resolution Up to 1200 x 1200 dpi
(9600 x 600 dpi quality)
Maximum Print Size Up to Legal
Duplex Print All mode (Print, Scan, Copy, Fax)
Print Modes Poster, Booklet, Watermark, Page Composer, Toner Saver
Print Memory 1GB (shared)
Direct Print from USB via USB Host v1.1 Print File format: JPEG, TIFF, PDF
Copier Specifications
Copy Type Color Laser
Copy Speed LTR: Up to 21ppm (Black/Color)1
A4: Up to 20ppm (Black/Color )1
Duplex Copy Speed LTR/A4: Up to 10ppm (Black/Color)1
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo/Map
Halftones 256 Levels
Warm-up Time 23 sec or less from power-on
First Copy Time Black/Color: Approx. 15.5/16.2sec (A4), 15.3/16.0 sec (LTR)3
Recovery Time Approx. 8 sec
Maximum Number of Copies Up to 99 copies
Duplex Copy/Bind Time Yes
Reduction/Enlargement 25 - 400% in 1% increments
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter,
ADF: 5.5" x 5" to Legal
Copy Features Frame Erase,
Memory Sort,
2 on 1,
4 on 1,
ID Card Copy
Copy Memory 1GB (shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps4
Fax Resolution Up to 406 x 391 dpi
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 512 pages5
Speed Dials Up to 281 dials
Group Dialing Max. 199 dials / Max. 199 destinations
Sequential Broadcasting Max. 310 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features FAX Forwarding, Dual Access, Remote Reception, PC FAX(TX only), DRPD, ECM, Auto Redial, Fax Activity Reports, Fax Activity Result Reports, Fax Activity Management Reports
Memory Backup Permanent fax memory backup. ( Backup with flash memory)
Activity Reports Activity Result & Activity Management
pC Fax Sending only
Fax Forwarding SMB, E-mail, FTP, iFax Simple
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Optical: Up to 600 x 600 dpi
Driver(digital): Up to 9600 x 9600 dpi
Scan Size Platen: Up to Letter
Duplex Scan Yes
Compatibility TWAIN, WIA (Scan Driver Compatibility)
Output File Formats JPEG, TIFF, PDF, Compact PDF, PDF (OCR), PDF (Device Support)
Scan Features Yes
Pull Scan Yes, USB and Network
Push Scan (Scan to pC) Yes, USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette, 50-sheet multipurpose tray6
Optional Paper Source(s) 250-sheet cassette
Document Feeder 50-sheet duplex
Paper Output 125 sheets (face down)
Paper Weight 16-58 lb. bond (cassette / multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive
Media Types Plain, Heavy, Recycled, Color, Coated, Transparency, Label, Envelope, Index
Envelope Capacity 10 envelopes (cassette), 5 envelopes (manual feed slot)
Envelope Types Com 10, Monarch, DL, C5, B5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business8, Apple AirPrint&trade;9, Mopria Print Service10, Google Cloud Print&trade;11
Network Functions Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6), Email, SMB, WSD-Scan (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1, SNMPv3 (IPv4,IPv6)
OS Compatibility Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003, Mac OS X® 10.5.8 & up, Linux (print only)
Cable Included Power Cord, Telephone Cable (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager
Environmental Specifications
Power Consumption Max: 1,200W or less.
During Operation: Approx. 450W.
Standby: Approx. 23W.
Energy Saver: Approx. 2W
Typical Energy Consumption 0.9 kWh
General Specifications
Dimensions 17" (W) x 19.2" (D) x 18.9" (H)
Unit Weight (without/with cartridge) 63.1 lbs. (w/o cartridge), 68.3 lbs (w/cartridge)
Package Weight Approx. 81.6 lbs
Cartridge Type Cartridge 118 VP Black (Yields approximately 6,800 pages)
Cartridge 118 Black (Yields approximately 3,400 pages)
Cartridge 118 YMC (Yields approximately 2,900 pages)
*Yields based on ISO/IEC Standard
LCD Display 7-line QVGA Color Touch LCD
Duty Cycle Up to 40,000 pages per month
Department ID Management Yes, Up to 300 ID's
Security Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, LDAP
Languages English, French, Spanish, Portuguese
One-Touch Keys Favorites Settings
Warranty 1 Year Exchange / Carry-in (Extended warranty available)12
Scanning Software Included: MF Scan Utility
Sending Method: SMB, E-mail, FTP, iFAX Simple
Color Mode: Full Color, Grayscale, Monochrome
Scan Resolution: 300 x 300 dpi, 200 x 200 dpi
Other Features: EPEAT Silver Rating, NFC13 Capability
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
