Canon Support for Color imageCLASS MF634Cdw | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 04.26.23
File Size 460.45 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 07.19.23
File Size 405.58 KB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 12.19.23
File Size 476.17 KB
Date 07.03.18
File Size 407.86 KB
Date 10.03.19
File Size 2.92 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Date 07.09.26
File Size 1.33 MB
Date 07.09.26
File Size 2.27 MB
Date 10.05.17
File Size 23.09 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Printer Specifications
Printer Type All in One, Color, Wireless, Duplex Laser Printer
Print Speed Up to 19 ppm (1-sided plain paper letter), Up to 11 ppm (2-sided plain paper letter)1 (bw / color)
First Print Time 12 seconds or less (letter)2
Printer Language UFR II (Host Based)
Print Resolution Up to 600 x 600 dpi,
1200 x 1200 dpi equivalent
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Poster, Booklet, Watermark, Toner Saver, Page Composer
Print Memory 1 GB (Shared)
Direct Print from USB JPEG, TIFF, PDF
Copier Specifications
Copy Type Color Laser
Copy Speed Up to 19 ppm (letter)
Duplex Copy Speed Up to 11 ppm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text, Photo
Halftones 256 Levels
Warm-up Time 13 seconds or less from power on
First Copy Time Approximately 11.7 / 13.8 seconds (bw/color, letter)3
Recovery Time Approximately 6 seconds
Maximum Number of Copies Up to 999 copies
Reduction/Enlargement 25 - 400% in 1% increments
Copy Size Platen: Up to Letter / DADF: Up to Legal
Copy Features Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Copy Memory 1 GB (Shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)4
Fax Resolution Up to 406 x 391 (Ultrafine)
Transmission Time Approx. 3 seconds
Memory Capacity Up to 512 sheets5
Speed Dials 19 one-touch speed dials, Up to 262 coded dials
Group Dialing 199 destinations
Sequential Broadcasting 310 destinations
Duplex Fax Yes
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Fax Forwarding, Dual Access, Remote Reception, PC Fax (TX only), Distinctive Ring Pattern Detection, Error Detection Mode, Auto Redial, Fax Activity / Activity Result Reports, Fax Activity Management Reports
Memory Backup Permanent fax memory backup (Backup with flash memory)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical), 9600 x 9600 dpi (software interpolated resolution)
Scan Size Platen: Up to Letter / ADF: Up to to Legal
Duplex Scan Yes (Single-Pass)
Compatibility TWAIN, WIA 2.0, ICA
Output File Formats JPEG, TIFF, PDF, Compact PDF, PDF (OCR)
Scan Features Push Scan, Pull Scan, Scan to USB
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 150-sheet cassette plus 1-sheet manual feed slot6
Document Feeder 50-sheet duplex6
Paper Output 100 sheets (face down)
Paper Weight 14-43 lb. bond (cassette/manual feed slot)
Media Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Media Types Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope
Envelope Capacity 1 envelope (manual feed slot)
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n7
WiFi Access Mode Infrastructure Mode, WPS easy Setup, Wi-Fi&reg; Direct Connection8
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP, AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS)
WiFi Encryption Modes WEP (64/128 bit), WPA-PSK (TKIP, AES), WPA2-PSK (AES)
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business9, Apple&reg; AirPrint&reg;10, Mopria&trade; Print Service11, Google Cloud Print&trade;12
Network Functions Print, Scan (SMB, E-mail, FTP), PC Fax
Embedded Web Server (Remote UI) IE 9.0 or higher, Safari 5.0.6 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4, IPv6)
TCP/IP Set of Application Services Bonjour (mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1, SNMPv3 (IPv4, IPv6)
OS Compatibility Windows&reg; 10, 8.1, 8, 7, Windows Server&reg; 2016, Windows Server&reg; 2012, 2012 R2, 2008 R2, 2008,Windows Vista&reg;, Mac OS 10.7.5 or later
Cable Included Power Cord, Phone Cable (USB not included)
Bundled Software Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, AddressBook Tool, Toner Status
Environmental Specifications
Power Consumption Approx: 340 W (during operation), 12.8 W (standby), Energy Saver Mode: Less than 1 W (USB/wired/wireless)
Typical Energy Consumption 0.5 kWh
General Specifications
Dimensions 17.8 inches (W) x 18.1 inches (D) x 15.7 inches (H)
Unit Weight (without/with cartridge) 44 lbs. (w/o cartridge),
48.4 lbs. (w/cartridge)
Package Weight Approx. 63.8 lbs.
Cartridge Type Cartridge 045 CMY (Yields approx. 1,300 pages), K (Yields approx. 1,400 pages) / Cartridge 045 Hi-Capacity CMY (Yields approx. 2,200 pages), Hi-Capacity Black (Yields approx. 2,800 pages) Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5 Inch, Color Touch LCD
Duty Cycle Up to 30,000 pages per month
Department ID Management Up to 300 IDs
Security IP / MAC Address Filtering, HTTPS, SNMPv3, IEEE802.1x
Languages English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean
Warranty 3 year limited exchange/carry-in warranty (Extended warranty available)13
Other Features:
Send Specifications
Sending Method: SMB, E-mail, FTP, iFAX Simple
Color Mode: Full Color, Monochrome
Scan Resolution: 300 x 300 dpi, 200 x 200 dpi
Recommended Monthly Print Volume:200-2,500 pages
Operating Temperature: 50-86°F
Operating Humidity: 20-80% RH (no condensation)
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
