Canon Support for Wireless File Transmitter WFT-E5A | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.14.10
File Size 6.10 MB
Software Development Kit
Type<br/>Image transfer accessory compatible with IEEE 802.11a, IEEE 802.11b, IEEE 802.11g wireless LAN and Ethernet (wired LAN) (IPsec-compatible). Can be connected via USB to external media, GPS devices, and Bluetooth units.Compatible Cameras<br/>EOS 7DFTP Transfer<br/>Transfer images over a network to FTP serversEOS Utility<br/>EOS Utility-based control of cameras over a networkWFT Server<br/>Browser-based remote capture and downloading of images over a networkMedia Server<br/>Transfer images over a network to DLNA-compatible media playersLinked Shooting<br/>Wirelessly trigger shooting by Slave cameras linked to a Master cameraCamera Connection<br/>System expansion terminalWired Lan Connection<br/>Ethernet RJ-45 portExternal Device Connection<br/>Hi-Speed USB port (for attaching external media, GPS devices and Bluetooth units)<br/> * Devices can be bus-powered.Power Supply<br/>One LP-E6 battery packBattery Level Indicator<br/>6-level indicatorImage Transfer Capacity<br/> <br/> NOTE: <br/> About the same number of images can be transferred at room temperature (73&deg;F/23&deg;C) and at low temperatures (32&deg;F/0&deg;C). Using a fully charged LP-E6. Under Camera & Imaging Products Association (CIPA) conditions for testing shooting capacity, when using automatic image transfer with images that are approximately 6.1MB. Fewer images can be transferred if the wireless LAN transfer rate drops, and for consecutive image transfer over wireless LAN. Fewer images can be transferred when using bus-powered external media or GPS devices.W x H x D<br/>5.8 x 1.8 x 3.0 in./147.4 x 45.0 x 76.8 mmOunces/grams <br/>Approx. 12.5 oz./355 gTemperature<br/>32&deg;F to 104&deg;F/0&deg;C to 40&deg;CHumidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: EOS 7D: Residual Image in Picture
Advisory Type
Date 11.04.09
Title Canon Support | Service Notice: Wireless File Transmitter WFT-E5A: Firmware Update Version 1.0.6
Advisory Type
Date 08.21.11
Title Canon Support | Service Notice: Wireless File Transmitter WFT-E5A: Firmware Version 1.0.7
Advisory Type
Date 08.05.12
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
