Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.08.16
File Size 1.95 MB
Software Development Kit
Compatibility
EOS 7D Mark II, EOS 5DS and EOS 5DS R cameras only.
Communication with Smartphones
Images can be viewed, controlled, and received using a smartphone.MP4 video can be viewed and saved using a smartphone with the EOS 7D Mark II camera only.
Remote control of the camera using a smartphone is possible.
Remote Operation Using EOS Utility
Remote control functions and image viewing functions of EOS Utility can be used wirelessly.
Standards Compliance
IEEE 802.11b/g/n
Transmission Method
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transmission Range
Approx. 32.8 ft. / 10m
  • When communicating with a smartphone
  • With no obstructions between the transmission and reception antennas and no radio interference (In the general environment, image display may be delayed or images may not be displayed smoothly.)
Transmission Frequency(Central Frequency)
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 ch
Connection Method
Camera access point mode, Infrastructure*
* Wi-Fi Protected Setup supported.
Security
Authentication method: Open system, Shared key, WPA/WPA2-PSKEncryption: WEP, TKIP, AES
Type
32104°F/040°C
Pixels
85% or less
Dimensions(W x H x D)
Approx. 0.94 x 1.26 x 0.08 in. / 24.0 x 32.0 x 2.1mm
Weight
Approx. 0.07 oz./ 2g
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
