Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.13.17
File Size 1.84 MB
Date 08.08.19
File Size 2.01 MB
Date 01.19.18
File Size 2.00 MB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION N/A
ANALOG VIDEO STANDARD N/A
ANALOG S/N RATIO N/A
SCANNING METHOD Progressive
LENS Fixed focal length lens (4x digital zoom)
FOCAL LENGTH 2.7 mm
F-NUMBER F1.6
HORIZONTAL VIEWING ANGLE 96 °
VERTICAL VIEWING ANGLE 60.5 °
DAY/NIGHT SWITCH Auto/Manual
I/R CUT FILTER Fixed
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.4 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.03 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.01 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.2 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.02 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.007 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
FOCUS Fixed at infinity
SHOOTING DISTANCE 0.5m (1.6 ft.) - infinity
SHUTTER SPEED 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/10000, 1/16000 sec.
EXPOSURE Auto / Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Gain)
WHITE BALANCE Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/ Manual (One-shot WB / R Gain/ B Gain)
METERING MODE Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
AGC LIMIT 5 levels
IMAGE STABILIZER N/A
PAN ANGLE RANGE N/A
TILT ANGLE RANGE N/A
ROTATION ANGLE RANGE N/A
MOVING SPEED N/A
VIDEO COMPRESSION METHOD JPEG, H.264
VIDEO SIZE JPEG, H.264: 1280x720, 640x360, 320x180 1280x960, 640x480, 320x240
VIDEO QUALITY JPEG, H.264: 5 levels
FRAME RATE JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE JPEG, H.264 (1280x960): 30fps
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4,IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version ONVIF Ver. 2.4 / Profile S
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client),DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP(Canon proprietary), ONVIF
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon Proprietary), ONVIF
AUTO IP Available
AUDIO COMPRESSION METHOD G.711 µ-law (64 kbps)
AUDIO COMMUNICATION METHOD Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK N/A
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION Available
PRESETS Max. 20 positions
INTELLIGENT FUNCTION - VIDEO Moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
INTELLIGENT FUNCTION - VOLUME Volume Detection
EVENT TRIGGER TYPE External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Volume)
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max.
approx. 5 MB
Frame Rate: Max. 10 fps (JPEG)
Max. 30 fps (H.264)
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION Digital PTZ
Cropping Sizes: 640x360, 512x288, 384x216, 256x144, 128x72 640x480, 512x384, 384x288, 256x192, 128x96
DAYLIGHT SAVING TIME Available
CUSTOM SETTINGS Number of Registers: 4
Items to Register: Exposure, Smart Shade Control, Focus, White Balance, Image Quality Adjustment, Day/Night
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL F3.5mm (F0.14 in.) mini-jack connector (monaural)
Switch LINE IN/MIC IN in the setting page.
LINE IN x 1 (connect to an amplifier microphone) or
MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL N/A
EXTERNAL DEVICE I/O TERMINAL Input x 1, Output x 1
ANALOG VIDEO OUT N/A
MEMORY CARD MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible.
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
TEMPERATURE Temperature: -10 ° C - +50 ° C (+14 ° F - +122 ° F)
HUMIDITY Humidity: 5% - 85% (without condensation)
PoE PoE: PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER N/A
EXTERNAL POWER SOURCE N/A
WITH PoE Max. approx. 4.3 W
WITH AC ADAPTER N/AN/A
WITH 12VDC N/A
WITH 24VAC N/A
DIMENSIONS (H x W x D) 52 x 32 x 114 mm (2.13 x 1.26 x 4.49 in.)
MOUNTING POSITION Horizontal / Vertical
HEATER N/A
WEIGHT Approx. 180 g (.39 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT No
IMPACT RESISTANCE N/A
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
