Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.18.23
File Size 942.91 KB
Date 01.18.23
File Size 1.03 MB
Date 01.18.23
File Size 776.38 KB
Date 01.18.23
File Size 763.86 KB
Date 01.18.23
File Size 1.06 MB
Date 01.18.23
File Size 677.43 KB
IMAGE SENSOR 1/2.8 type CMOS
NUMBER OF EFFECTIVE PIXELS Approx. 2.1 million pixels
SCANNING METHOD Progressive
LENS 3.5x optical zoom lens with auto focus
FOCAL LENGTH 2.25 (W) 7.88 mm (T)
F-NUMBER F1.4 (W) F2.6 (T)
DIGITAL ZOOM 4X
HORIZONTAL VIEWING ANGLE (16:9) 79.0° (W) 20.9° (T)
VERTICAL VIEWING ANGLE (16:9) 41.0° (W) 11.7° (T)
DAY/NIGHT MODE Auto/Day Mode/Night Mode
I/R CUT FILTER Digital Night mode
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.15 lux (F1.4, shutter speed 1/30 sec., 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.10 lux (F1.4, shutter speed 1/30 sec., 50IRE)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
AF RESPONSE SPEED High, Normal, and Low
SHOOTING DISTANCE Day Mode: 0.3 m (12 in.) infinity
Night Mode: 1.0 m (3.3 ft.) infinity
SHUTTER SPEED 1/25 - 1/8000 sec.
EXPOSURE MODES Auto/Auto (Flickerless)/Auto (Flickerless2)/Auto (Shutter-priority AE)/Manual
WHITE BALANCE Auto/Light Source (Daylight Fluorescent/White Fluorescent/WarmFluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain)
METERING MODES Center-Weighted/Average/Spot/Specify Area
EXPOSURE COMPENSATION 13 levels
WDR n/a
SMART SHADE CONTROL Available
HAZE COMPENSATION Available
AGC LIMIT Available
IMAGE STABILIZER n/a
MOTION ADAPTIVE NOISE REDUCTION Available
CLEAR IR n/a
PAN ANGLE RANGE 350° (±175°)
TILT ANGLE RANGE 90° (ceiling-mounted position: -90° -0°)
ROTATION ANGLE RANGE N/A
IR ILLUMINATION RANGE N/A
MOVING SPEED Pan: Max. 120°/sec., Tilt: Max. 120°/sec.
VIDEO COMPRESSION METHOD JPEG, H.264, H.265
BIT RATE CONTROL CBR (Constant Bit Rate), VBR (Variable Bit Rate), MBR (Maximum Bit Rate)
VIDEO SIZE JPEG, H.264, H.265: 1920 x 1080, 1280 x 720, 960 x 540, 640 x 360, 480 x 270, 320 x 180 1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY JPEG, H.264, H.265: 10 levels
FRAME RATE System frequency 60 Hz: 1, 5, 7.5, 10, 15, 30 fps
System frequency 50 Hz: 1, 2.5, 5, 6.25, 10, 12.5, 25 fps
MAXIMUM FRAME RATE 30 fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL Available
SIMULTANIOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client
H.264: Max. 10 Clients
H.265: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS
IEEE 802.1X EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version Profile-S, Profile-G, Profile-T
IPv4 PROTOCOL TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, ONVIF, WV-HTTP (Canon proprietary)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD G.711 -law (64 kbps), AAC (16/48 KHz, 16/32/64/96/128 Kbps)
AUDIO COMMUNICATION METHOD Audio Reception Only
AUDIO FILE PLAYBACK n/a
PRIVACY MASK Number of registration: Max. 8 places
VIEW RESTRICTION Available
PRESETS Number of registers: Max. 64 positions (+Home Position)
INTELLIGENT FUNCTION - VIDEO Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, Intrusion Detection, Face Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
INTELLIGENT FUNCTION - AUDIO Volume Detection
EVENT TRIGGER TYPE External Device Input, Intelligent Function, Timer, Day/Night Mode Switching
Number of Linked Events: 2
Linked Event Conditions: OR, AND (whether or not there is a sequence to events)
IMAGE UPLOAD FTP/FTPS/HTTP/HTTPS/SMTP/SMTPS (e-mail)
EVENT NOTIFICATION HTTP/HTTPS/SMTP/SMTPS (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION Digital PTZ
ENHANCED DIGITAL ZOOM n/a
DAYLIGHT SAVING TIME Available
CUSTOM SETTINGS Available
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto))
AUDIO INPUT TERMINAL 3.5 mm (0.14 in.) mini-jack connector (monaural)LINE IN or MIC IN
AUDIO OUTPUT TERMINAL n/a
EXTERNAL DEVICE I/O TERMINAL Input x 1, Output x 1
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Supported. Class 10 recommended.
TEMPERATURE Temperature: -10°C - +45°C (+14°F - +113°F)
HUMIDITY Humidity: 5% - 85% (without condensation)
TEMPERATURE Temperature: -30°C +60°C (-22°F +140°F)
HUMIDITY 5% 90% (without condensation)
PoE PoE power supply via LAN connector (IEEE802.3at Type1 compliant)
WITH PoE Max. approx. 6.7 W
DIMENSIONS ( x H) 120 x 54 mm (4.72 x 2.13 in.)
MOUNTING POSITION Ceiling Mount
HEATER N/A
WEIGHT 270 g (9.6 oz.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT No
IMPACT RESISTANCE N/A
Certifications and Compatibility EN 55032 class A, FCC part15 subpart B class A, ICES-003 class A, VCCI class A, RCM AS/NZS EN55032 class A, CNS13438 class A, KS C 9832 class A, EN 55035, KS C 9835, IEC EN 63000:2018, CNS15663 IEC/EN 62368-1 3'rd ed., UL 62368-1 3'rd ed.
Title Firmware Notice: VB-S32D Firmware Ver. 1.0.7
Advisory Type Firmware Notice
Date 02.15.24
Title Firmware Notice: VB-S32VE/VB-S32D Firmware Ver. 1.0.6
Date 08.28.23
Title Firmware Notice: VB-S32D: Firmware Version 1.0.9
Date 01.10.25
Title Firmware Notice: VB-S32D: Firmware Version 1.0.5
Date 07.24.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
