Canon Support for VB-S31D Mark II | Canon U.S.A., Inc.
VB-S31D Mark II
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Mobile Camera Viewer Operation Guide
File Name
Network Camera Operation Guide
File Name
Camera Management Tool User Manual
File Name
Network Camera Appendix – Specifications
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
IMAGE SENSOR | 1/3" CMOS (RGB) |
NUMBER OF EFFECTIVE PIXELS | Approx. 2.1 million pixels |
SCANNING METHOD | Progressive Scan |
LENS | Fixed focal length lens |
FOCAL LENGTH | 2.7mm |
F-NUMBER | F1.6 |
DIGITAL ZOOM | 4x |
HORIZONTAL VIEWING ANGLE (16:9) | 95° |
VERTICAL VIEWING ANGLE (16:9) | 60° |
DAY/NIGHT MODE | Yes |
I/R CUT FILTER | Digital Night Mode |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.45 lux (F1.6, shutter speed 1/30 sec) |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.25 lux (F1.6, shutter speed 1/30 sec) |
FOCUS MODES | - |
SHOOTING DISTANCE | 0.5m (1.6 ft.) - infinity (W) |
SHUTTER SPEED | 1 - 1/16000 sec. |
EXPOSURE MODES | Auto/ Auto (Flickerless)/Auto (Flickerless2)/Auto (shutter-priority AE)/ Manual (Shutter Speed, Gain) |
WHITE BALANCE | Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain) |
METERING MODES | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 9 levels |
SMART SHADE CONTROL | Auto / Manual / Disable Auto: 3 Levels Manual: 7 Levels |
HAZE COMPENSATION | Auto/Manual/Disable Auto: 3 levels Manual: 7 levels |
AGC LIMIT | 6 levels |
IMAGE STABILIZER | Digital (2 Levels) |
MOTION ADAPTIVE NOISE REDUCTION | Available |
CLEAR IR | N/A |
PAN ANGLE RANGE | 3350° (±175°) |
TILT ANGLE RANGE | 90°(ceiling-mounted position: -90° - 0°) |
ROTATION ANGLE RANGE | N/A |
IR ILLUMINATION RANGE | N/A |
MOVING SPEED | Pan: Max. 120°/sec. Tilt: Max. 120°/sec. |
VIDEO COMPRESSION METHOD | JPEG, H.264 |
BIT RATE CONTROL | - |
VIDEO SIZE | JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240 |
VIDEO QUALITY | JPEG, H.264: 10 levels |
FRAME RATE | JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps |
MAXIMUM FRAME RATE | JPEG, H.264 (1920 x 1080): 30fps |
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION | - |
I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
SIMULTANEOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user |
ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec (Auto Key Exchange/Manual) |
IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
ONVIF Version | ONVIF Profile S |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
AUTO IP (LINK-LOCAL) | Yes |
AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
AUDIO COMMUNICATION METHOD | Audio Reception Only |
AUDIO FILE PLAYBACK | Available |
PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
VIEW RESTRICTION | Available |
PRESETS | Max. 64 positions |
INTELLIGENT FUNCTION - VIDEO | Moving object detection, abandoned object detection, removed object detection, camera tampering detection, passing detection and intrusion detection |
INTELLIGENT FUNCTION - AUDIO | Volume Detection & Scream Detection |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
EVENT TRIGGER TYPE | External Device Input, Timer, Intelligent Function (Video), Intelligent Function (Volume) |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | Available |
IMAGE CROPPING FUNCTION | Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96 |
ENHANCED DIGITAL ZOOM | Available |
DAYLIGHT SAVINGS TIME | Available |
CUSTOM SETTINGS | Available |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. |
AUDIO OUTPUT TERMINA | F3.5mm (F0.14 in.) mini-jack connector (monaural) LINE OUT x 1 (connect to an amplifier speaker) |
EXTERNAL DEVICE I/O TERMINAL | Input x 1, Output x 1 |
ANALOG VIDEO OUT | N/A |
MEMORY CARD TYPE | MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible. |
MEMORY CARD RECORDED CONTENT | Log, Video (Event, Manual, ONVIF, Timer, Upload) |
MEMORY CARD RECORDED FRAME RATE | Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264) |
TEMPERATURE | Temperature: -10°C - +50°C (+14°F - +122°F) |
HUMIDITY | Humidity: 5% - 85% RH (without condensation) |
TEMPERATURE | -30°C - +60°C (-22°F - +140°F) |
HUMIDITY | 5% - 90% RH (without condensation) |
PoE | PoE: PoE power supply via LAN connector (IEEE802.3af compliant) |
AC ADAPTER | N/A |
EXTERNAL POWER SOURCE | N/A |
WITH PoE | Max. approx. 7.6 W |
WITH AC ADAPTER | N/A |
WITH 12VDC | N/A |
WITH PoE+ | - |
WITH 24VAC+ | N/A |
DIMENSIONS | (F x H) F120 x 54mm (F4.72 x 2.13 in.) |
MOUNTING POSITION | Ceiling mount |
HEATER | N/A |
WEIGHT | Approx. 270 g (.60 lb.) |
OUTDOOR READY | No |
IP RATING | N/A |
VANDAL RESISTANT | No |
IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
