Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.13.17
File Size 1.84 MB
Date 08.08.19
File Size 698.20 KB
Date 01.20.17
File Size 588.92 KB
Date 10.06.17
File Size 565.81 KB
Date 01.20.17
File Size 576.76 KB
Date 08.08.19
File Size 2.01 MB
Date 01.20.17
File Size 758.05 KB
Date 01.19.18
File Size 2.00 MB
Date 01.18.23
File Size 675.73 KB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/4.85" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS Approx. 2.1 million pixels
SCANNING METHOD Progressive Scan
LENS 3.5x optical zoom lens with auto focus
FOCAL LENGTH 2.25 (W) - 7.88mm (T)
F-NUMBER F1.4 (W) - F2.6 (T)
DIGITAL ZOOM 4x
HORIZONTAL VIEWING ANGLE 77.1° (W) - 20.6° (T)
VERTICAL VIEWING ANGLE 40.2° (W) - 11.5° (T)
DAY / NIGHT MODE Yes
I/R CUT FILTER Digital Night Mode
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 1.0 lux (F1.4, shutter speed 1/30 sec.)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.55 lux (F1.4, shutter speed 1/30 sec.)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE 0.3m (12 in.) - infinity (W)
SHUTTER SPEED 1 - 1/16000 sec.
EXPOSURE MODES Auto/ Auto (Flickerless)/ Auto (Flickerless2) Auto (shutter-priority AE)/ Manual (Shutter Speed, Gain)
WHITE BALANCE Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm
Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/ Manual
(One-shot WB / R Gain/ B Gain)
METERING MODES Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
HAZE COMPENSATION Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT 6 levels
IMAGE STABILIZER N/A
MOTION ADAPTIVE NOISE REDUCTION Available
CLEAR IR N/A
PAN ANGLE RANGE 350° (±175°)
TILT ANGLE RANGE 90° (ceiling-mounted position: -90° - 0°)
ROTATION ANGLE RANGE N/A
IR ILLUMINATION RANGE N/A
MOVING SPEED Pan: Max. 120°/sec.
Tilt: Max. 120°/sec.
VIDEO COMPRESSION METHOD JPEG, H.264
BIT RATE CONTROL Target Bit Rate: 64-16384 kbps
VIDEO SIZE JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANEOUS VIDEO STREAMS 2x H.264, 2x MJPEG, 1x H.264 1x MJPEG
VIDEO QUALITY JPEG, H.264: 10 levels
FRAME RATE JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE JPEG, H.264 (1920 x 1080): 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANEOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version ONVIF Profile S
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD G.711 µ-law (64 kbps)
AUDIO COMMUNICATION METHOD Full-duplex (two-way)/half-duplex (One-way communication)
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK Available
PRIVACY MASK Number of registration: Max. 8 places,
Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION Available
PRESETS Max. 64 positions
INTELLIGENT FUNCTION - VIDEO Moving object detection, abandoned object detection, removed object
detection, camera tampering detection, passing detection and intrusion detection
INTELLIGENT FUNCTION - AUDIO Volume Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
EVENT TRIGGER TYPE External Device Input, Timer, Intelligent Function (Video),
Intelligent Function (Audio), Day/Night Switch
IMAGE UPLOAD FTP/HTTP
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM N/A
DAYLIGHT SAVINGS TIME Available
CUSTOM SETTINGS Available
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL Built-in Microphone
Sensitivity: -40 dB (0 dB=1 V/Pa)
S/N Ratio: 62 dB or greater
Frequency Response: 50 Hz - 16 kHz
AUDIO OUTPUT TERMINAL F3.5 mm (F0.14 in.) mini-jack connector (monaural)
LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL Input x 1, Output x 1
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE MicroSD Memory Card, MicroSDHC Memory Card, MicroSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT Log, Video (Event, Manual, ONVIF, Timer, Upload?
MEMORY CARD RECORDED FRAME RATE Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
TEMPERATURE Operating Temperature Range
-25°C - +50°C (-13°F - +122°F)
HUMIDITY Humidity: 5% - 85% RH (without condensation)
TEMPERATURE -30°C - +60°C (-22°F - +140°F)
HUMIDITY 5% - 90% RH (without condensation)
PoE PoE: PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER N/A
EXTERNAL POWER SOURCE N/A
WITH PoE Max. 8.1 W
WITH AC ADAPTER N/A
WITH 12VDC N/A
WITH PoE + N/A
WITH 24VAC N/A
DIMENSIONS (F x H) F132 x 65 mm (F5.20 x 2.56 in.)
- Camera only
MOUNTING POSITION Ceiling mount
HEATER No
WEIGHT Approx. 620 g (21.9 oz.) (T.B.D.)
OUTDOOR READY Yes
* Dome may cloud when installed under direct sunlight
IP RATING IP66
VANDAL RESISTANT Yes
IMPACT RESISTANCE IK10 (20J)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
