Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.10.17
File Size 511.98 KB
Date 03.10.17
File Size 443.39 KB
Date 05.23.16
File Size 441.86 KB
Date 06.13.17
File Size 1.84 MB
Date 08.08.19
File Size 698.20 KB
Date 12.06.21
File Size 7.68 MB
Date 08.08.19
File Size 188.47 KB
Date 08.08.19
File Size 2.01 MB
Date 03.10.17
File Size 457.27 KB
Date 01.19.18
File Size 2.00 MB
Date 01.18.23
File Size 675.73 KB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS Approx. 2.1 million pixels
ANALOG VIDEO RESOLUTION N/A
ANALOG VIDEO STANDARD N/A
ANALOG S/N RATIO N/A
SCANNING METHOD Progressive Scan
LENS 30x optical zoom lens with auto focus
FOCAL LENGTH 4.4 (W) - 132mm (T)
F-NUMBER F1.4 (W) - F4.6 (T)
DIGITAL ZOOM 20x
HORIZONTAL VIEWING ANGLE (16:9) 62.6° (W) - 2.2° (T)
VERTICAL VIEWING ANGLE (16:9) 36.9° (W) - 1.3° (T)
DAY / NIGHT MODE Yes
I/R CUT FILTER Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.05 lux (F1.4, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.002 lux (F1.4, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE Day Mode: 0.3 m (12 in.) - infinity (W), 2.0 m (6.6 ft.) - infinity (T)
Night Mode: 1.0 m (3.3 ft.) - infinity (W), 2.0 m (6.6 ft.) - infinity (T)
SHUTTER SPEED 1 - 1/16000 sec.
EXPOSURE MODES Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT 6 levels
IMAGE STABILIZER Digital (2 levels)
PAN ANGLE RANGE 360°continuous panning
TILT ANGLE RANGE 180° (ceiling-mounted position: 0° - 180°)
ROTATION ANGLE RANGE N/A
IR ILLUMINATION RANGE N/A
MOVING SPEED Pan: Max. 450°/sec.
Tilt: Max. 450°/sec.
VIDEO COMPRESSION METHOD JPEG, H.264
BIT RATE CONTROL Target Bit Rate: 64-16384 kbps
VIDEO SIZE JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANEOUS VIDEO STREAMS N/A
PLACE HOLDER N/A
VIDEO QUALITY JPEG, H.264: 10 levels
FRAME RATE JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE 1920 x 1080 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANEOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF VERSION Profile S, Profile G
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD G.711 µ-law (64 kbps)
AUDIO COMMUNICATION METHOD Full-duplex (two-way) - Echo cancellation function compliant
RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK Available (audio files can be played back when an event is triggered by the intelligent function or external device input)
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION Available
PRESETS Number of registers: Max. 256 positions (+Home Position)
Number of Preset Tour Route: Max. 5
INTELLIGENT FUNCTION - VIDEO Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, Intrusion Detection, and Auto Tracking
INTELLIGENT FUNCTION - AUDIO Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
EVENT TRIGGER TYPE External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION N/A
DAYLIGHT SAVINGS TIME Available
CUSTOM SETTINGS Available
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL F3.5 mm (F0.14 in.) mini-jack connector (monaural)
LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL F3.5 mm (F0.14 in.) mini-jack connector (monaural)
LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL Input x 2, Output x 2
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE Max. 1 fps (JPEG)
Max. 30 fps (H.264)
TEMPERATURE AC, DC, PoE: -10°C - +50°C (+14°F - +122°F)
HUMIDITY 5% - 85% (without condensation)
TEMPERATURE -30°C - +60°C (-22°F - +140°F)
HUMIDITY 5% - 90% (without condensation)
PoE PoE power supply via LAN connector (IEEE802.3at Type1 compliant)
AC ADAPTER AC Adapter: PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE 24VAC / 12VDC
WITH PoE 10.7W
WITH AC ADAPTER AC Adapter PA-V18: Max. approx. 11.3 W (100 V AC)
Max. approx. 11.1 W (240 V AC)
WITH 12VDC 9.7W
WITH PoE + N/A
WITH 24VAC 10.2W
DIMENSIONS (F x H) F199 x 199 mm (F7.83 x 7.83 in.)
MOUNTING POSITION N/A
HEATER N/A
WEIGHT Approx. 1990 g (4.39 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT N/A
IMPACT RESISTANCE N/A
Title Canon Support | Firmware Notice: VB-R13VE/VB-R12VE /VB-R13: Firmware Version 1.1.2
Advisory Type
Date 07.18.17
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
