Canon Support for VB-M740E | Canon U.S.A., Inc.
VB-M740E
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Camera Management Tool User Manual
File Name
Conduit Box CB740-VB Installation Guide
File Name
Mobile Camera Viewer Operation Guide
File Name
Network Camera Operation Guide
File Name
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
IMAGE SENSOR | 1/3" CMOS (RGB) |
NUMBER OF EFFECTIVE PIXELS | Approx. 1.3 million pixels |
ANALOG VIDEO RESOLUTION | N/A |
ANALOG VIDEO STANDARD | N/A |
ANALOG S/N RATIO | N/A |
SCANNING METHOD | Progressive Scan |
LENS | 2.4x optical zoom lens (electric drive) |
FOCAL LENGTH | 2.55 (W) - 6.12 mm (T) |
F-NUMBER | F1.2 (W) - F1.8 (T) |
DIGITAL ZOOM | 4x |
HORIZONTAL VIEWING ANGLE1 | 113.4° (W) - 46.5° (T) |
VERTICAL VIEWING ANGLE | 61.4° (W) - 26.2° (T) |
DAY/NIGHT SWITCH | Yes |
I/R CUT FILTER | Automatically removable infrared-cut filter |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.02 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE) |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR lamp on) 0.001 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR lamp off) |
FOCUS MODES | Auto/One-shot AF/Manual/Fixed at infinity |
SHOOTING DISTANCE | Day Mode: 0.3 m (12 in.) - infinity Night Mode: 0.3 m (12 in.) - infinity |
SHUTTER SPEED | 1 - 1/16000 sec. |
EXPOSURE | Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain) |
WHITE BALANCE | Auto/Light Source/Manual Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/ Halogen Lamp Manual: One-shot WB/R Gain/B Gain |
METERING MODE | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 9 levels |
SMART SHADE CONTROL | Auto: 3 Levels
Manual: 7 Levels |
HAZE COMPENSATION | Auto: 3 Levels
Manual: 7 Levels |
AGC LIMIT | 6 levels |
IMAGE STABILIZER | Digital (2 Levels) |
PAN ANGLE RANGE | 344° (±172°) |
TILT ANGLE RANGE | 93° (-3° - +90°) |
ROTATION ANGLE RANGE | 344° (±172°) |
IR ILLUMINATION RANGE | N/A |
MOVING SPEED | N/A |
VIDEO COMPRESSION METHOD | JPEG, H.264 |
BIT RATE CONTROL | Target Bit Rate: 64-16384 kbps |
SIMULTANEOUS VIDEO STREAMS | N/A |
VIDEO QUALITY | JPEG, H.264: 10 levels |
FRAME RATE | JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps |
MAXIMUM FRAME RATE | 1280 x 960: 30 fps |
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION | Number of Specified Areas: Max. 8 windows |
I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
SIMULTANEOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user (level of control varies depending on user) |
ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec |
IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
ONVIF Version | Ver. 2.4.2, Profile G, Profile S |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), mDNS,ARP, ICMP, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), AutoIP, RTP/RTCP, RTSP, SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G) |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), mDNS, ICMPv6, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), RTP/RTCP, RTSP,SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G) |
AUTO IP | Yes |
AUDIO COMPRESSION METHOD | N/A |
AUDIO COMMUNICATION METHOD | N/A |
AUDIO FILE PLAYBACK | N/A |
PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
VIEW RESTRICTION | N/A |
PRESETS | Number of registers: Max. 20 positions (+Home Position) Items to Reg.: Digital Pan/Digital Tilt/Digital Zoom, Exposure, Smart Shade Control, Focus, White Balance, Video Quality Adjustment, Day/Night, Haze Compensation Number of Preset Tour Route: Max. 1 |
INTELLIGENT FUNCTION - VIDEO | Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection |
INTELLIGENT FUNCTION - AUDIO | N/A |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
EVENT TRIGGER TYPE | Intelligent Function (Video), Timer, Day/Night Switch |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | Available |
IMAGE CROPPING FUNCTION | Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96 |
DAYLIGHT SAVINGS TIME | Available |
CUSTOM SETTINGS | N/A |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | N/A |
AUDIO OUTPUT TERMINAL | N/A |
EXTERNAL DEVICE I/O TERMINAL | N/A |
ANALOG VIDEO OUT | N/A |
MEMORY CARD RECORDED CONTENT | Log, Video (Event, Manual, ONVIF, Timer, Upload) |
MEMORY CARD RECORDED FRAME RATE | Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264) |
TEMPERATURE | Operating Temperature Range (including direct sun exposure) : PoE: -10°C - +55°C (+14°F - +131°F) |
HUMIDITY | Humidity: 5% - 85% RH (without condensation) |
TEMPERATURE | -30°C - +60°C (-22°F - +140°F) |
HUMIDITY | 5% - 90% RH (without condensation) |
PoE | PoE power supply via LAN connector (IEEE802.3at Type1 PoE compliant) |
AC ADAPTER | N/A |
EXTERNAL POWER SOURCE | N/A |
WITH PoE | Max. approx. 7.4 W |
WITH AC ADAPTER | N/A |
WITH 12VDC | N/A |
WITH PoE + | N/A |
WITH 24VAC+ | N/A |
DIMENSIONS | (H x W x D) 111 x 102 x 214 mm (4.37 x 4.02 x 8.43 in.) (camera body only) - Length when joint fully extended (D): 384 mm (15.12 in.) |
MOUNTING POSITION | Ceiling mount/Surface mount |
HEATER | Optional |
WEIGHT | Approx. 2040 g (4.50 lb.) |
OUTDOOR READY | Yes |
IP RATING | IP66 |
VANDAL RESISTANT | No |
IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
