Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.10.17
File Size 511.98 KB
Date 06.13.17
File Size 1.84 MB
Date 03.10.17
File Size 442.29 KB
Date 06.13.17
File Size 368.57 KB
Date 06.13.17
File Size 456.68 KB
Date 08.08.19
File Size 698.20 KB
Date 12.06.21
File Size 7.68 MB
Date 08.08.19
File Size 2.01 MB
Date 01.19.18
File Size 2.00 MB
Date 01.18.23
File Size 675.73 KB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS Approx. 1.3 million pixels
ANALOG VIDEO RESOLUTION N/A
ANALOG VIDEO STANDARD N/A
ANALOG S/N RATIO N/A
SCANNING METHOD Progressive Scan
LENS 2.4x optical zoom lens (electric drive)
FOCAL LENGTH 2.55 (W) - 6.12 mm (T)
F-NUMBER F1.2 (W) - F1.8 (T)
DIGITAL ZOOM 4x
HORIZONTAL VIEWING ANGLE 111.5 ° (W) - 46.2 ° (T)
VERTICAL VIEWING ANGLE 60.5 ° (W) - 25.9 ° (T)
DAY/NIGHT SWITCH Yes
I/R CUT FILTER Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.02 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.001 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE Day Mode: 0.3 m (12 in.) - infinity
Night Mode: 0.3 m (12 in.) - infinity
SHUTTER SPEED 1 - 1/16000 sec.
EXPOSURE MODES Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT 6 levels
IMAGE STABILIZER Digital (2 Levels)
PAN ANGLE RANGE 350 ° (±175 ° )
TILT ANGLE RANGE 150 ° (±75 ° )
ROTATION ANGLE RANGE 350 ° (±175 ° )
IR ILLUMINATION RANGE N/A
MOVING SPEED Pan: 20.1 ° /sec.
Tilt: 20.7 ° /sec.
Rotation: 40.0 ° /sec.
- Camera Angle Setting Tool Required
VIDEO COMPRESSION METHOD JPEG, H.264
BIT RATE CONTROL Target Bit Rate: 64-16384 kbps
VIDEO SIZE JPEG, H.264: 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240
SIMULTANEOUS VIDEO STREAMS N/A
VIDEO QUALITY JPEG, H.264: 10 levels
FRAME RATE JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE 1280 x 960 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANEOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version Ver. 2.4.2, Profile G, Profile S
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), mDNS,ARP, ICMP, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), AutoIP, RTP/RTCP, RTSP, SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), mDNS, ICMPv6, POP3 (Client), NTP (Client), SMTP authentication (POP before SMTP, SMTP-AUTH), RTP/RTCP, RTSP,SSL/TLS, IPsec, WV-HTTP (Canon proprietary), ONVIF (Profile S, Profile G)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD N/A
AUDIO COMMUNICATION METHOD N/A
AUDIO FILE PLAYBACK N/A
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION N/A
PRESETS Number of registers: Max. 20 positions (+Home Position)
Items to Reg.: Digital Pan/Digital Tilt/Digital Zoom, Exposure, Smart Shade Control, Focus, White Balance, Video Quality Adjustment, Day/Night, Haze Compensation
Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO N/A
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
EVENT TRIGGER TYPE Intelligent Function (Video), Timer, Day/Night Switch
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
DAYLIGHT SAVINGS TIME Available
CUSTOM SETTINGS
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL N/A
AUDIO OUTPUT TERMINAL N/A
EXTERNAL DEVICE I/O TERMINAL N/A
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE Frame Rate: Max. 1 fps (JPEG) Max. 30 fps (H.264)
TEMPERATURE Temperature: PoE: -10 ° C - +50 ° C (+14 ° F - +122 ° F)
HUMIDITY Humidity: 5% - 85% RH (without condensation)
TEMPERATURE -30 ° C - +60 ° C (-22 ° F - +140 ° F)
HUMIDITY 5% - 90% RH (without condensation)
PoE PoE power supply via LAN connector (IEEE802.3at Type1 PoE compliant)
AC ADAPTER N/A
EXTERNAL POWER SOURCE N/A
WITH PoE Max. approx. 8.4 W
WITH AC ADAPTER N/A
WITH 12VDC N/A
WITH PoE + N/A
WITH 24VAC N/A
DIMENSIONS (F x H) F150 x 129 mm (F5.91 x 5.08 in.)
MOUNTING POSITION Ceiling mount/Surface mount
HEATER N/A
WEIGHT Approx. 880 g (1.95 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT Yes
IMPACT RESISTANCE IK10 (20J)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
