Canon Support for VB-M600VE | Canon U.S.A., Inc.
VB-M600VE
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
Heater Unit HU600-VB User Manual
File Name
Camera Management Tool User Manual
File Name
File Name
File Name
Data Size and Bit Rate Estimates
SELECT ERROR CODE
IMAGE SENSOR | 1/3 type CMOS (primary color filter) |
NUMBER OF EFFECTIVE PIXELS | Approx. 1.3 million pixels |
ANALOG VIDEO RESOLUTION | N/A |
ANALOG VIDEO STANDARD | N/A |
ANALOG S/N RATIO | N/A |
SCANNING METHOD | Progressive |
LENS | 3x Optical zoom Lens |
FOCAL LENGTH | 2.8 (W) - 8.4 mm (T) |
F-NUMBER | F1.2 (W) - F2.0 (T) |
HORIZONTAL VIEWING ANGLE | 101.2 ° (W) - 33.7 ° (T) |
VERTICAL VIEWING ANGLE | 74.7 ° (W) - 25.3 ° (T) |
DAY/NIGHT SWITCH | Auto/Manual |
I/R CUT FILTER | Removable |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.25 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.07 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off) 0.018 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on) |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.008 lux (F1.6, when shutter speed is 1/30 sec., when SSC is off)
0.002 lux (F1.6, when shutter speed is 1/8 sec., when SSC is off) 0.001 lux (F1.6, when shutter speed is 1/8 sec., when SSC is on) |
FOCUS | One-shot AF/Manual/Fixed at infinity |
SHOOTING DISTANCE | Day Mode: 0.3m (12 in.) - infinity
Night Mode: 1.0m (3.3 ft.) - infinity |
SHUTTER SPEED | 1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000,1/4000, 1/8000 sec. |
EXPOSURE | Auto/Auto (Flickerless)/ Auto(Shutter-priority AE)/ Manual (Shutter Speed/Aperture/Gain) |
WHITE BALANCE | Auto/Select Light Source (Warm Fluorescent, White Fluorescent, Daylight Fluorescent, Mercury Lamp, Sodium Lamp, Halogen Lamp)/Lock (One-shot WB)/Manual |
METERING MODE | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 7 levels |
SMART SHADE CONTROL | 7 levels |
AGC LIMIT | N/A |
IMAGE STABILIZER | N/A |
PAN ANGLE RANGE | 350 ° (±175 ° ) |
TILT ANGLE RANGE | 150 ° (±75 ° ) |
ROTATION ANGLE RANGE | 350 ° (±175 ° ) |
MOVING SPEED | Pan: 19.2 ° /sec., Tilt: 14.2 ° /sec., Rotation: 43.7 ° /sec. - When the Camera Angle Setting Tool is used |
VIDEO COMPRESSION METHOD | H.264, JPEG |
VIDEO SIZE | JPEG: 1280 x 960, 640 x 480, 320 x 240, 160 x 120
H.264: 1280 x 960, 640 x 480, 320 x 240 |
VIDEO QUALITY | JPEG, H.264: 5 levels |
FRAME RATE | JPEG: 30 - 0.1 fps
H.264: 30/15/10 fps |
MAXIMUM FRAME RATE | 1280 x 960: 30 fps |
I-FRAME INTERVAL | Fixed |
SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users. |
ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4,IPv6) |
ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec (Auto Key Exchange/Manual) |
IEEE 802.1X | N/A |
ONVIF Version | ONVIF Ver. 1.02 |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (client), DHCP (client), DNS (client), ARP, ICMP, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SMTP (client), DNS (client), ICMPv6, POP3, NTP, SMTP authentication, WV-HTTP (from Canon), ONVIF |
AUTO IP | N/A |
AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
AUDIO COMMUNICATION METHOD | Full-duplex (two-way) - Echo cancellation function compliant |
AUDIO FILE PLAYBACK | Available (audio files can be played back when an event is triggered by the intelligent function or external device input.) |
PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
VIEW RESTRICTION | N/A |
PRESETS | N/A |
INTELLIGENT FUNCTION - VIDEO | Moving Object Detection, Abandoned Object Detection, Removed Object Detection, and Camera Tampering Detection |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
INTELLIGENT FUNCTION - VOLUME | Volume Detection |
EVENT TRIGGER TYPE | External Device Input, Intelligent Function (Video), Intelligent Function (Volume), Timer |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) Temporary storage memory in camera: Max. 4 MB, Frame Rate: Max. 10 fps |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | Available |
IMAGE CROPPING FUNCTION | N/A |
DAYLIGHT SAVING TIME | N/A |
CUSTOM SETTINGS | N/A |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier) |
AUDIO OUTPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included) LINE OUT x 1 (connect to an amplifier speaker) |
EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2 |
ANALOG VIDEO OUT | N/A |
MEMORY CARD | SD, SDHC, SDXC Memory Card Compatible. Frame Rate: Max. 1 fps |
TEMPERATURE | Temperature: -10
C - +50
C (+14
F - +122
F)
*Temperature: -30 ° C - +50 ° C (-22 ° F - +122 ° F) * Equipped with separately sold Heater Unit HU600-VB |
HUMIDITY | Humidity: 5% - 85% (without condensation) |
PoE | PoE power supply via LAN connector (IEEE802.3af compliant) |
AC ADAPTER | PA-V17 (100 - 240 V AC) (sold separately) |
EXTERNAL POWER SOURCE | 24 V AC/12 V DC |
WITH PoE | Max. approx. 8.6 W |
WITH AC ADAPTER | Max. approx. 10.9 W |
WITH 12VDC | Max. approx. 9.0 W |
WITH 24VAC | Max. approx. 8.3 W
Max. approx.18.9 W* * when separately sold Heater Unit HU600-VB installed |
DIMENSIONS | (F x H) F180 x 147 mm (F7.09 x 5.79 in.) |
MOUNTING POSITION | Horizontal / Vertical |
HEATER | Optional |
WEIGHT | Approx. 1910 g (4.22 lb.) |
OUTDOOR READY | Yes |
IP RATING | IP66-rated (IEC60529) |
VANDAL RESISTANT | Yes |
IMPACT RESISTANCE | IK 10+ (50 Joules) |
ADDITIONAL SUPPORT
CONTACT US
