Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.10.17
File Size 511.98 KB
Date 06.13.17
File Size 1.84 MB
Date 03.10.17
File Size 442.29 KB
Date 06.13.17
File Size 368.57 KB
Date 06.13.17
File Size 456.68 KB
Date 08.08.19
File Size 698.20 KB
Date 12.06.21
File Size 7.68 MB
Date 08.08.19
File Size 188.47 KB
Date 08.08.19
File Size 2.01 MB
Date 01.19.18
File Size 2.00 MB
Date 01.18.23
File Size 675.73 KB
Date 10.06.17
File Size 122.02 KB
IMAGE SENSOR 1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS Approx. 2.1 million pixels
ANALOG VIDEO RESOLUTION N/A
ANALOG VIDEO STANDARD N/A
ANALOG S/N RATIO N/A
SCANNING METHOD Progressive Scan
LENS 2.4x optical zoom lens with auto focus
FOCAL LENGTH 2.55 (W) - 6.12mm (T)
F-NUMBER F1.2 (W) - F1.8 (T)
DIGITAL ZOOM 4x
HORIZONTAL VIEWING ANGLE (16:9) 122.1° (W) - 50.1° (T)
ERTICAL VIEWING ANGLE (16:9) 65.8° (W) - 28.2° (T)
DAY/NIGHT SWITCH Yes
I/R CUT FILTER Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR) 0.035 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) 0.002 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE)
FOCUS MODES Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE Day Mode: 0.3 m (12 in.) - infinity
Night Mode: 0.3 m (12 in.) - infinity
SHUTTER SPEED 1 - 1/16000 sec.
EXPOSURE MODES Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE Auto/Light Source/Manual Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp Manual: One-shot WB/R Gain/B Gain
METERING MODE Center-Weighted/Average/Spot
EXPOSURE COMPENSATION 9 levels
SMART SHADE CONTROL Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT 6 levels
IMAGE STABILIZER Digital (2 levels)
PAN ANGLE RANGE 350° (±175°)
TILT ANGLE RANGE 150° (±75°)
ROTATION ANGLE RANGE 350° (±175°)
MOVING SPEED Pan: 20.1°/sec.
Tilt: 20.7°/sec.
Rotation: 40.0°/sec.
VIDEO COMPRESSION METHOD JPEG, H.264
BIT RATE CONTROL Target Bit Rate: 64-16384 kbps
VIDEO SIZE JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240
VIDEO QUALITY JPEG, H.264: 10 levels
FRAME RATE JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE 1920 x 1080 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL 0.5/1/1.5/2/3/4/5 sec.
SIMULTANEOUS CLIENT ACCESS Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS SSL/TLS, IPsec
IEEE 802.1X EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version Profile S, Profile G
IPv4 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
AUTO IP (LINK-LOCAL) Yes
AUDIO COMPRESSION METHOD G.711 µ-law (64 kbps)
AUDIO COMMUNICATION METHOD Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK Available (audio files can be played back when an event is triggered by the intelligent function or external device input)
PRIVACY MASK Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION Available
PRESETS Number of registers: Max. 20 positions (+Home Position) Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS Max. 15
EVENT TRIGGER TYPE External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch
IMAGE UPLOAD FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY Available
IMAGE CROPPING FUNCTION Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
DAYLIGHT SAVINGS TIME Available
CUSTOM SETTINGS Available
NETWORK TERMINAL LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL 3.5 mm (0.14 in.) mini-jack connector (monaural) LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier) - Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL 3.5 mm (0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL Input x 2, Output x 2
ANALOG VIDEO OUT N/A
MEMORY CARD TYPE microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible.
MEMORY CARD RECORDED CONTENT Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE Max. 1 fps (JPEG)
Max. 30 fps (H.264)
TEMPERATURE -30°C - +60°C (-22°F - +140°F)
HUMIDITY 5% - 90% (without condensation)
PoE PoE power supply via LAN connector (IEEE802.3at Type1 compliant)
AC ADAPTER PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE 24 V AC/12 V DC
WITH PoE 8.4W
WITH AC ADAPTER AC Adapter PA-V18: Max. approx. 9.9 W (100 V AC)
Max. approx. 9.8 W (240 V AC)
WITH 12VDC 8.7W
WITH PoE N/A
WITH 24VAC+ 8.1W
DIMENSIONS ( x H) 150 x 129 mm (5.91 x 5.08 in.)
MOUNTING POSITION N/A
HEATER N/A
WEIGHT Approx. 890 g (1.97 lb.)
OUTDOOR READY No
IP RATING N/A
VANDAL RESISTANT Yes
IMPACT RESISTANCE IK10 (20J)
Title Canon Support | Firmware Notice: VB-H651V Firmware Version 1.0.2
Advisory Type
Date 07.09.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
