Canon Support for VB-C60 | Canon U.S.A., Inc.
VB-C60
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
NETWORK CAMERA VB-C60 Operation Guide
File Name
Network Camera VB-C60 Start Guide
File Name
File Name
Network Camera VB-C60 Operation Guide
SELECT ERROR CODE
IMAGE SENSOR | 1/4 type CCD (Primary Color Filter) |
NUMBER OF EFFECTIVE PIXELS | Approx. 310,000 pixels |
ANALOG VIDEO RESOLUTION | N/A |
ANALOG VIDEO STANDARD | N/A |
ANALOG S/N RATIO | N/A |
SCANNING METHOD | Progressive |
LENS | 40x Optical with Auto Focus (4x Digital) |
FOCAL LENGTH | 3.4(W) - 136.0mm (T) |
F-NUMBER | F1.6 (W) - F5.6 (T) |
HORIZONTAL VIEWING ANGLE | 55.8 ° (W) - 1.5 (T) |
VERTICAL VIEWING ANGLE | 43.3 ° (W) - 1.1 (T) |
DAY/NIGHT SWITCH | Auto/Manual |
I/R CUT FILTER | Removable |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.7 lux @ F1.6, 1/30 sec |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0.2 lux @ F1.6, 1/30 sec |
FOCUS | Auto / One-shot AF / Manual / Fixed Focus at Infinity |
SHOOTING DISTANCE | Day Mode: 0.3m - infinity (W), 1.5m - infinity (T)
Night Mode: 0.5m - infinity (W), 1.8m - infinity (T) |
SHUTTER SPEED | 1/1 - 1/8000 second |
EXPOSURE | Auto / Flickerless / Shutter Priority AE / Manual |
WHITE BALANCE | Auto/ Light Source (6 Types) / Lock (One-shot WB) |
METERING MODE | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 7 levels |
SMART SHADE CONTROL | 7 levels |
AGC LIMIT | N/A |
IMAGE STABILIZER | 2 levels (Digital) |
PAN ANGLE RANGE | 340 ° (±170 ° ) |
TILT ANGLE RANGE | 115 ° (-90 ° , 25 ° ) |
ROTATION ANGLE RANGE | N/A |
MOVING SPEED | Pan: Max. 150 ° /sec, Tilt: Max. 150 ° /sec |
VIDEO COMPRESSION METHOD | MPEG-4, JPEG |
VIDEO SIZE | JPEG: 640x480 , 320x240 , 160x120
MPEG-4: 640x480 , 320x240 |
VIDEO QUALITY | JPEG, MPEG-4: 5 levels |
FRAME RATE | M-JPEG: 30 - 0.1 frames per second
MPEG-4: 30 / 15 /10 frames per second |
MAXIMUM FRAME RATE | 640 x 480: 30fps |
I-FRAME INTERVAL | Fixed |
SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - MPEG-4: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users. |
ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4) |
ENCRYPTED COMMUNICATIONS | IPSec |
IEEE 802.1X | N/A |
ONVIF Version | N/A |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (client), DHCP (client), DNS (client), ARP, ICMP, POP3, NTP, SMTP authentication, WV-HTTP (from Canon) |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SMTP (client), DNS (client), ICMPv6, POP3, NTP, SMTP authentication, WV-HTTP (from Canon) |
AUTO IP | N/A |
AUDIO COMPRESSION METHOD | G.711 µ-law (64 kbps) |
AUDIO COMMUNICATION METHOD | Full-duplex (two-way) |
AUDIO FILE PLAYBACK | Available (audio files can be played back when an event is triggered by motion detection or external device input.) |
PRIVACY MASK | N/A |
VIEW RESTRICTION | Available |
PRESETS | Max. 20 Positions |
INTELLIGENT FUNCTION - VIDEO | Motion Detection |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 4 |
INTELLIGENT FUNCTION - VOLUME | N/A |
EVENT TRIGGER TYPE | External Device Input, Motion Detection |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max. 4 MB, Frame Rate: Max. 10 fps |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | N/A |
IMAGE CROPPING FUNCTION | N/A |
DAYLIGHT SAVING TIME | N/A |
CUSTOM SETTINGS | N/A |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page. LINE IN x 1 (connect to an amplifier microphone) or MIC IN x 1 (connect to a microphone w/o amplifier) |
AUDIO OUTPUT TERMINAL | F3.5mm (F0.14 in.) mini-jack connector (monaural) LINE OUT x 1 (connect to an amplifier speaker) |
EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2 |
ANALOG VIDEO OUT | N/A |
MEMORY CARD | N/A |
TEMPERATURE | Temperature: -10 ° C - +50 ° C (+14 ° F - +122 ° F) |
HUMIDITY | Humidity: 5% - 85% (without condensation) |
PoE | PoE power supply via LAN connector (IEEE802.3af compliant) |
AC ADAPTER | PA-V17 (100 - 240 V AC) (sold separately) |
EXTERNAL POWER SOURCE | 24 V AC/12 V DC |
WITH PoE | Max. approx. 9 W |
WITH AC ADAPTER | Max. approx. 9.6 W |
WITH 12VDC | Max. approx. 9 W |
WITH 24VAC | Max. approx. 9 W |
DIMENSIONS | (H x W x D ) 149 x 142 x 142mm (5.87 x 5.59 x 5.59 in.) |
MOUNTING POSITION | Horizontal |
HEATER | N/A |
WEIGHT | Approx. 840g (1.85 lbs.) |
OUTDOOR READY | No |
IP RATING | N/A |
VANDAL RESISTANT | No |
IMPACT RESISTANCE | N/A |
ADDITIONAL SUPPORT
CONTACT US
