Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.17.13
File Size 9.68 MB
Date 06.17.13
File Size 2.45 MB
Date 03.11.08
File Size 9.26 MB
Date 03.19.07
File Size 9.51 MB
Date 06.17.13
File Size 2.04 MB
Network Video Solution Camera
Item Code 9782A007 (VB-C50iR) / 9781A008 (VB-C50i)
Video Signal Conforms to NTSC
Image Sensor 1/4-inch CCD (primary color filter)
Total Number of Pixels NTSC use: 680,000 (effective 340,000)
Scanning Method 2:1 interlaced
Minimum Illumination Normal mode: 1 Lux (at 1/30 sec.) Night Mode : 0 lux
Imaging Modes Normal mode, Night mode
Focusing Auto / Manual Wide-angle: 0.03 in. to inf.;
Telephoto: 5.25 ft. to inf. (In Night Mode) Wide-angle: 0.07 in. to inf.; Telephoto: 7.55 ft. to inf.
Aperture Auto iris servo system
Lens Focal Length: 3.5mm to 91.0mm, f/1.6 to f/4.0
26x Power Zoom (shooting at infinity)
Filter Diameter: 37mm, pitch=0.75mm
Zoom 26X Power Zoom (shooting at infinity)
Pan Angle Range +/-100&deg;
Tilt Angle Range +90&deg;/-30&deg;
Infrared Cut Filter Power driven insertion / removal (Normal mode / Night Mode)
White Balance TTL system: Auto
Protocols TCP/IP, HTTP, DHCP, FTP, Webview (from Canon)
Video Compression Method Motion-JPEG compression (video quality variable)
JPEG compression (for still pictures)
Video Compression Rate NTSC: 0.1fps to 30fps
Sound Compression Method -law PCM 8bit (sampling freq. 8000Hz mono)
Output Image Size 160 x 120, 320 x 240, 640 x 480
Display Image Size 80 x 60, 160 x 120, 320 x 240, 640 x 480
Server HTTP, FTP, Webview Livescope
Log Management syslog format
Camera Control Pan, tilt, zoom, brightness, shutter speed, focus speed, view restriction, control time restriction
Connection Restrictions Access control (password), video connection, service period, number of concurrent connections (maximum of 50)
Network Ethernet x 1 (RJ-45, 100 Base-TX / 10Base T auto negotiation)
Dimensions VB-C50i: 4.1 x 5.1 x 4.3 in. (104.6 x 130.3 x 108.7mm)
VB-C50iR: 4.1 x 5.1 x 4.4 in. (104.6 x 130.3 x 110.6 mm)
Weight VB-C50i: Approx. 1.4 lbs (620g)
VB-C50iR: 1.5lbs. (700g)
Operating Environment Temperature 0 - 40C, humidity 20 - 85% RH (condensation free)
Power AC Adapter
Power Consumption Max: Approx. 13W or less (When the AC Adapter is used)
AC Adapter
Model PA-V16 (6588A001)
Input 100-240 VAC 50/60 Hz
Output 13 VDC 1.8 A (max.)
Polarity Exterior (-) interior (+)
Dimensions 2.28 x 4.65 x 0.98 in. (W x D x H)
Weight 0.50 lbs (excluding cable)
Optional Software
Description 4075B002 / VK-16 v2.2 Network Video Recording Software
4075B001 / VK-64 v2.2 Network Video Recording Software
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
