Canon Support for VB-C500D | Canon U.S.A., Inc.
VB-C500D
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
VB-C500D Start Guide
SELECT ERROR CODE
Network Video Solution Camera
Image Sensor | 1/4-inch primary color single plate progressive CCD |
Total Number of Pixels | Effective 310k pixels (total number of pixels: 340 k) |
Scanning Method | Progressive |
Minimum Illumination | Day Mode (Color): 0.2 lux @ 1/30 shutter speed Night Mode (B&W): 0.1 @ 1/30 shutter speed |
Focusing | Manual (0.7m closest , infinity) |
Aperture | Select from the range of 6 to 32 (level value) only when the exposure mode is "Manual" |
Zoom | 2.4x Optical (4x Digital) |
Viewing Angle | Horizontal: 82° (W) , 34° (T), Vertical: 60.5° (W) ,25.5° (T) |
Pan Angle Range | N/A |
Tilt Angle Range | N/A |
Moving Speed | N/A |
Infrared Cut Filter | Digital (Seamless transition) |
Night Mode | Auto / Manual Switching *No power-driven removal/insertion of IR cut filter (Digital Night Mode) |
White Balance | Auto / Light Source (6 types) / Lock (One-shot WB) |
Protocols | IPv4: TCP/IP, UDP, HTTP, FTP, SNMP(MIB2), SMTP(Client), DHCP(Client), DNS(Client), ARP, ICMP, POP3, NTP, SMTP authentication, WV-HTTP(from Canon) IPv6: TCP/IP, UDP, HTTP, FTP, SMTP(Client), DNS(Client), ARP, ICMPv6, POP3, NDP, SMTP authentication, WV-HTTP(from Canon) |
Video Compression Method | Simultaneous distribution of JPEG/MPEG-4 |
Output Image Size | JPEG: 640x480/320x240/160x120 ... multi-size distribution (simultaneous distribution in 3 video sizes) MPEG-4: 640x480/320x240 ... fixed size distribution |
Display Image Size | JPEG: 640×480 / 320×240 / 160×120 |
Camera Control | 3 user levels available (Administrator / Authorized user / Guest user) Up to 50 users' user names and passwords can be set for Authorized users. |
Network | LAN x 1 (RJ45, 100Base-TX (Auto / full-duplex / half-duplex)) |
Dimensions | 5.35" x 5.83" x 4.25" (136 x 148 x 108mm) |
Weight | 1.36 lbs. (approx. 620g) |
Power | PoE: PoE power supply via LAN connector (IEEE802.af compliant) AC Adapter: Optional PA-V17 (AC100V-240V) *connect via an optional power adapter and interface cable |
Power Consumption | PoE: Max. approximately 3.3W AC Adapter: Max. approximately 3.5W with optional PA-V17 |
AC Adapter
Model | Optional PA-V17 (AC100V-240V) *connect via an optional power adapter and interface cable |
Item Code | 2245B001 |
Optional Software
Description | 3331B001 / 1 License for VK-Lite 4075B002 / VK-16 v2.2 Network Video Recording Software 4075B001 / VK-64 v2.2 Network Video Recording Software |
ADDITIONAL SUPPORT
CONTACT US
