Canon Support for VB-C300 | Canon U.S.A., Inc.
VB-C300
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
VB-C300 Start Guide
File Name
VB-C300 Operation Guide
File Name
VB-C300 Operation Guide Manual
File Name
VB-C300 Start Guide Manual
File Name
VB-C300 Start Guide (Spanish version)
SELECT ERROR CODE
Network Video Solution Camera
Video Signal | Conforms to NTSC |
Image Sensor | 1/4-inch CCD (primary color filter) |
Total Number of Pixels | NTSC use: 680,000 (effective 310,000) |
Scanning Method | Progressive Scan |
Minimum Illumination | Day Mode: 1 lux (F2.0, color, 1/30 sec.) Night Mode: 0.25 lux (F2.0, monochrome, 1/30 sec.) Using the (optional) VB-RD41S-S Smoke Indoor Housing Day Mode: 2 lux (F2.0, color, 1/30 sec.) Night Mode: 2 lux (F2.0, monochrome, 1/30 sec.) |
Imaging Modes | Day mode, Night mode |
Focusing | Day Mode: 11.8 in. / Night mode: 23.6 in. for Auto/Manual focusing at wide/telephoto ends |
Aperture | Auto iris servo system |
Lens | Focal Length: 3.0mm to 7.2mm, f/2.0 to f/3.4 2.4x Power Zoom (shooting at infinity) |
Viewing Angle | Horizontal = 70.8° (W) to 29.6° (t) Vertical = 51.6° (W) to 22.1° (t) (including distortion) |
Pan Angle Range | 340° (±170°) |
Tilt Angle Range | Upright Position = 115° (-25° to 90°) Inverted = 115° (-90° to 25°) |
Moving Speed | Pan = Max. 90° / sec. Tilt = Max. 70° / sec. |
Infrared Cut Filter | Power driven insertion / removal (Normal mode / Night Mode) |
Night Mode | Yes |
White Balance | TTL system: Auto / Manual preset / One-shot |
Operating System | Linux |
Protocols | TCP/IP, HTTP, DHCP, FTP, Webview (from Canon) |
Video Compression Method | Motion-JPEG compression (movie) JPEG (still pictures) |
Video Compression Rate | NTSC: 0.1fps to 30fps |
Sound Compression Method | G.711µ-law (64kbps) full duplex |
Output Image Size | 160 x 120, 320 x 240, 640 x 480 |
Display Image Size | JPEG: 640×480 /320×240 /160×120 |
Camera Control | Pan, tilt, zoom, brightness, shutter speed, focus speed, white balance |
Connection Restrictions | Access control (password), video connection, number of concurrent connections (maximum of 15) |
Network | Network LAN x 1 (RJ-45, 100 Base-TX / 10Base T auto negotiation) |
Main Unit Interface | Audio IN / OUT: 3.5monaural, mini-jack IN: Connection to a microphone with amp and LINE output x 1 OUT: Connection to a speaker with amp x1 Video OUT: 3.5 monaural, mini-jack Video composite signal output from network camera (for maintenance) x 1 External Device I/O: Input x 2, Output x 1 |
Dimensions | Approx. 4.79 x 5.19 x 5.11 in. (Main unit only, excluding rubber feet and ceiling bracket) |
Weight | Approx. 1.73 lbs. |
Operating Environment | Temperature 0 - 40°C, humidity 20 - 85% RH (condensation free) |
Power | Capable of PoE power supply via LAN connector (in accordance with IEEE 802.3af compliant) 24VAC / 12VDC, (using the supplied connector, no polarity) AC Adapter for 100VAC to 240VAC (PA-V17) |
Power Consumption | Max: Approx. 10W (PoE) Max: Approx. 13W (When the AC Adapter is used) |
Optional Software
Description | 4075B002 / VK-16 v2.2 Network Video Recording Software 4075B001 / VK-64 v2.2 Network Video Recording Software |
ADDITIONAL SUPPORT
CONTACT US
