Canon Support for varioPRINT 135/120/110 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.09.13
File Size 6.24 MB
Date 03.06.12
File Size 14.6 MB
Date 03.22.12
File Size 2.94 MB
Date 03.22.12
File Size 2.91 MB
Date 03.22.12
File Size 3.16 MB
Date 03.22.12
File Size 2.86 MB
Date 09.09.13
File Size 736.0 KB
Date 03.22.12
File Size 3.33 MB
Date 07.25.13
File Size 5.82 MB
Date 09.09.13
File Size 356.0 KB
Date 11.09.12
File Size 2.3 MB
Date 11.09.12
File Size 2.29 MB
Date 11.09.12
File Size 1.86 MB
Date 11.09.12
File Size 1.29 MB
Date 11.09.12
File Size 1.26 MB
Date 11.09.12
File Size 1.31 MB
Date 12.01.14
File Size 1.35 MB
Model Name varioPRINT 135/120/110
Type DirectPress
Printing Resolution Engine: 600 x 2400 dpi / 200lpi
PCL: 600 x 600 dpi
Adobe PostScript 3: 600 x 2400 dpi, 1200 x 1200 dpi (Enhanced)
Letter (Simplex / Duplex:) 120/110/100 ipm / 135/120/110 ipm
Ledger (Simplex / Duplex:) 63/57/52 ipm / 70/63/57 ipm
First Copy Time 3.9 seconds
Maximum Original Size 12.6" x 19.2" (320 x 488 mm)
Standard Paper Capacity 4000 sheets (80 gsm)
Trays 1 & 2: 1500 sheets (Ltr, Statement**)
Tray 3: 500 sheets from 5.5" x 7.17" (140x 182mm) to 12.6" x 17" (320 x 432 mm)
Tray 4: 500 sheets from 5.5" x 7.17" (140 x 182 mm) to 12.6" x 19.2" (320 x 488 mm)Feeding Technology (iPIM - internal Paper Input Module): Roller fed 14 lb. bond - 110 lb. cover (50-300 gsm)
Acceptable Paper Weights
Duplexing Up to 300 gsm
Power Requirements 208V/20A
Dimension 56.3" x 44.5" x 30.1"
(1430mm x 1130mm x 765mm)
Weight 579.8 (263 kg)
Estimated Toner Yield 96,000 / per 2 bottles*
Feeders
Description Color Image Reader (Single-pass Duplex Automatic Document Feeder and Black & White/Color Scanner)
Acceptable Originals Statement, Letter, Legal, 11" x 17", Custom Sizes ADF: 5.5" x 5.04" (140 x 128mm) to 17" x 12" (432 x 305 mm)
Scanning Speed BW/Color: Up to 120 ipm (300 x 300 dpi)
BW: Up to 100 ipm (600 x 600 dpi)
Color: Up to 105 ipm (600 x 300 dpi)
Up to 25 ipm (600 x 600 dpi)
Capacity 300 sheets (20 lb. bond)
Power Source From main unit
Paper Supply Options
Description ePIM (external Paper Input Module)
Paper Capacity 8,000 sheets with Duo Tray Option, (4,600 Standard)
Paper Sizes 8" x 8" (203 x 203 mm) to 12.6" x 19.2" (320 x 488 mm)
Paper Weights 14 lb. bond - 110 lb. cover (50-300 gsm)Feeding Technology: Air Separation, Suction Feeding
Power Source 120V/15A
Dimensions 40.9" x 38.6" x 29.5"
(1040mm x 980mm x 750mm)
Weight 440.9 lbs (200 kg)
Description Document Insertion Unit-F1 (Optional)
Paper Capacity 400 Sheets (200 x 2) (20 lb. Bond)
Paper Sizes 13" x 19.2"
Paper Weights 14 lb. Bond to 110 lb. Cover (50gsm to 300gsm)
Dimensions 55.37" x 29.37" x 31.25"
(1407mm x 746mm x 793mm)
Weight 134 lb. (61kg)
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
