Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 10.26.22
File Size 9.65 MB
Date 10.26.22
File Size 4.71 MB
Date 12.15.22
File Size 9.65 MB
Date 06.05.20
File Size 60.6 MB
Product
Product Category Field Lens
Product Series UJ122x8.2B
Image Composition
Object Image Format 2/3 inch
Aspect Ratio 16:9
Zoom Ratio 122x
Focal Length Range 8.2 , 1000 mm
Focal Length Range with Extender 16.4 , 2000 mm (with 2x Extender)
Angular Field of View 60.7&deg; x 36.5&deg; at 8.2 mm
0.55&deg; x 0.31&deg; at 1000 mm
Angular Field of View with Extender 32.6&deg; x 18.7&deg; at 16.4 mm (with 2x Extender)
0.28&deg; x 0.15&deg; at 2000 mm (with 2x Extender)
Optical Brightness
Maximum Relative Aperture (F-Number) 1:1.7 at 8.2 - 340 mm
1:5.0 at 1000 mm
Maximum Relative Aperture (F-Number) with Extender 1:3.4 at 16.4 - 680 mm (with 2x Extender)
1:10.0 at 2000 mm (with 2x Extender)
Scene Composition
MOD From Front of Lens 3.0 Meter
Scene Object Dimensions at MOD 314.6 x 177.0cm**1 [8.2mm]
2.7 x 1.5 cm at 1000 mm
**1 When using macro, the minimum shooting distance and the shooting distance at time of closest proximity will differ. Please see the manual for details.
Scene Object Dimensions at MOD with Extender 157.3 x 88.5cm[16.4mm]**1 [8.2mm] (with 2x Extender)
1.4 x 0.8 cm at 2000 mm (with 2x Extender)
Physical Attributes
Width 9.9in (250.6mm)
Height 10.1in (255.5mm)
Dimensions 25.1in (637.4mm)
Weight 58.6 lbs. (26.6 kg)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
