Canon Support for Speedlite 430EX III-RT | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 09.17.15
File Size 248.60 KB
Date 03.30.21
File Size 5.99 MB
Software Development Kit
Compatible Cameras Type-A Eos Cameras (E-Ttl Ii/E-Ttl Autoflash)
Guide Number Supports A Shooting Angle Of View With A Lens Focal Length Of 24-105mm.
The Maximum Guide No. Is Approximately 141.1 Ft./43m At Iso 100 And 105mm Flash Coverage.
When The Extendable Wide Panel Is Pulled Out, The Flash Coverage Is 14mm.
Number Of Flashes Approx. 180-1200 Flashes (With Size-Aa/Lr6 Alkaline Batteries)
Recycling Time Normal Flash: Approx. 0.1-3.5 Sec.
Quick Flash: Approx. 0.1-2.5 Sec.
  • With Size-Aa/Lr6 Alkaline Batteries
  • Flash-Ready State Indicated By Lights (Red For Normal Flash, Green For Quick Flash)
    Flash Range Effective Flash Range With Ef 50mm F/1.4 Lens At Iso 100
    1. Normal Flash:
      Approx. 2.3-77.4 Ft./0.7-23.6m
    2. Quick Flash (At Guide No. 62.7 Ft./19.1m):
      Approx. 2.3-44.6 Ft./0.7-13.6m
    3. High-Speed Sync (At 1/250 Sec. Shutter Speed):
      Approx. 2.3-42.0 Ft./0.7-12.8m
    Af Assist Beam Emission Method Switchable In Personal Functions Between Intermittent Flashes And Infrared Af-Assist Beam.
    Emitting Small Series Of Flashes Is Supported During Viewfinder Shooting, And Quick Mode During Live View Shooting Or Movie Shooting.
    Effective Range (Approx.):
    At Center: 2.3-13.1 Ft./0.7-4.0m
    Periphery: 2.3-11.5 Ft./0.7-3.5m
    Custom Functions 10 Functions
    Personal Functions 8 Functions
    Power Source Four Aa-Size/Lr6 Alkaline Or Aa/Hr6 Ni-Mh Batteries
    Internal Sound Generator N/A
    External Power Source N/A
    Dimensions Approx. 2.78 X 4.48 X 3.87 In./70.5 X 113.8 X 98.2mm
    Weight Approx. 10.41 Oz. / 295g
    Canon Flashes Limited International Warranty
    The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
    This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
    This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
    Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
    When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
    This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
    1. loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
    2. if equipment is defective as a result of leaking batteries or liquid damage.
    3. if equipment has been serviced or modified by other than our Authorized Agents.
    4. Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
    5. Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
    Equipment covered by this Warranty will be repaired in other countries:
    a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
    NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
    This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
    This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
    Online Repair
    SUPPLIES & ACCESSORIES
    ADDITIONAL SUPPORT
    image icon
    How-To Videos
    image icon
    image icon
    Knowledge Base
    CONTACT US
