Canon Support for RF1200mm F8 L IS USM Lens | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Focal Length 1200mm
Maximum and Minimum Aperture f/8 - f/64
Lens Mount Type RF Mount, metal
Compatible Cameras Canon EOS R-series
Minimum Focusing Distance 4.3 m / 14.1 ft.
Maximum Magnification 0.29x
Field of View, at Minimum Focus Distance Approx. 241 mm × 161 mm / 9.5 x 6.3 in.
Angle of View (Diagonal) 02° 05'
Canon RF Extender 1.4x/2x Compatible
Equivalent Focal Length / Maximum Aperture RF1.4x - 1680mm f/11
RF2x - 2400mm f/16
Maximum close-focusing magnification RF1.4x - 0.41x
RF2x - 0.60x
Autofocus with EOS R-series cameras* * (as of 2/2022) Possible with either extender
Image Stabilizer with EOS R-series cameras* * (as of 2/2022) Possible with either extender
Lens Construction 26 elements in 18 groups
Special Elements (2) Fluorite, (1) Super UD Lenses, (1) UD (Ultra-low Dispersion)
Lens Coating Super Spectra Coating, Fluorine Coating, ASC
Filter Size Diameter ο52 mm
Aperture Blades 9, circular shape
Image Stabilization 4 stops correction with In-lens Optical Image Stabilization
Focusing Drive System Canon USM low-speed drive (Ring USM)
Full-time Manual Focusing Yes
(Supports both ONE SHOT AF and SERVO AF with compatible EOS R-series cameras)
Manual Focus Speed Selection Yes (1, 2, and 3 settings, via switch on lens)
1= fastest MF; 3= slowest MF rotation
Focus Distance Range Selection Yes (3 positions, via switch on lens)
FULL 4.3m/14.1 feet infinity
4.3m/14.1 feet 30m/98.4 feet
30m/98.4 feet infinity
Dual Pixel CMOS AF Coverage (Horizontal x Vertical) EOS R5/R6 - approx. 100% x 100%
EOS R - approx. 88% x 100%
With Extender RF1.4x EOS R5/R6 - approx. 80% x 80%
EOS R - approx. 80% x 80%
With Extender RF2x EOS R5/R6 - approx. 40% x 60%
EOS R - approx. 40% x 60%
Power Focus Yes, via rotation of Playback Ring
Lens Focus Preset switch set to OFF; Focus Mode switch set to "PF"
Two focus speeds, based on ring rotation angle
IS On-Off Image Stabilizer switch, on lens barrel
Optical Image Stabilization Provided
4 stops correction (CIPA standard) with both EOS R and R5
IS Mode Selection IS Modes 1, 2 and 3 (via switch on lens barrel)
Mode 1 - general shake correction
Mode 2 - correction during panning
Mode 3 - correction only during exposure
Panning Mode Support (SCN Mode) Supported
Control Ring Dual-function Manual focus ring / Control Ring (selected using camera menu)
Manual Focus Ring Electronic ring system
Full-time Manual focus possible
No physical limit to ring rotational angle
AF/MF Switch YES - AF/PF/MF Switch
MF/Control Ring Switch None - must be selected in camera menu
Distance Scale None
Distance scale available in EVF or Live View LCD screen of compatible EOS R-series cameras
Distance Limiter Switch FULL (2.6 m to infinity) / 2.6 m to 20 m / 20 m to infinity
Focus Pre-set Function Yes, via Playback Ring on lens barrel
Off - On - On with beep tone, via lens switch
Distance memorized via Focus Preset button
Two distances can be memorized; immediate return to either via direction of Playback Ring
Lens Function Buttons (AF-Stop Buttons) Yes; four positioned on lens barrel
Dust / Weather Resistant Construction Yes - rubber ring on lens mount
Maximum Outer Diameter x Length Approx. ο6.6 in. x 21.1 in. (ο168.0mm x 537mm)
Weight Approx. 117.8 oz. / 7.4 lb. / 3340g
Lens Hood Canon Lens Hood (long) ET-160 (Bundled)
Canon Lens Hood (short) ET-160B (Sold Separately)
Lens Cap Canon E-185C (Bundled)
Dust Cap Canon Lens Dust Cap RF (Bundled)
Lens Case Canon Lens Soft Case LS1200 (Bundled)
Extension Tubes None (No Canon RF mount extension tubes)
Close-up Lenses 250D / 500D Not compatible
Drop-in Filters Compatible - 52mm Drop-in Filter Holder 52 (WIII) Included
Accepts 52mm screw-in filters
Canon 52mm clear Protect Filter included
Canon EF Lenses Limited Warranty
The limited warranty set forth below is given by Canon U.S.A., Inc. (Canon U.S.A.) in the United States and Canon Canada Inc., in Canada (herein referred to collectively as "Canon") with respect to the Canon Binoculars and Photographic Lens Products packaged with this Limited Warranty and identified by model number on this limited warranty card (each a "Product")when purchased and used in the United States or Canada.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase
A Product, when delivered to you in new condition in its original container, is warranted against defects in materials or workmanship as follows: for a period of one (1) year from the date of original purchase, defective parts or a defective Product returned to Canon, or its authorized service providers, and proven to be defective upon inspection, will be repaired with new or comparable rebuilt parts or exchanged for a refurbished Product, as determined by Canon or the authorized service provider in their sole discretion. Replaced parts and exchanged Products will become the property of Canon.
When returning a Product for warranty service, the shipping charges must be prepaid and the Product should be shipped in its original container, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A copy of the warranty card and proof of purchase should be enclosed, as well as a description of the problem (including film samples, where appropriate). Repairs will be made and the Product will be returned, shipped at NO CHARGE, within the country of repair.
This warranty only covers defective materials or workmanship encountered in normal use and service of a Product and does not apply in the following cases:
a) Loss of or damage due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
b) If a Product is defective as a result of leaking batteries or liquid damage.
(c) Defective materials or workmanship where the defect is due to a Product having been serviced or modified by other than Canon or a Canon authorized service provider.
(d) Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
(e) Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
(f) Damage or service resulting from modifications or alterations to a Product in any way (including any alteration or removal of its serial number or identification marks).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO A PRODUCT SHALL BIND CANON (SOME STATES AND PROVINCES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU). CANON SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, WITHOUT LIMITATION, ANY LOSS OF FILM) CAUSED BY THE USE OR MISUSE OF, OR INABILITY TO USE, A PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. IN NO EVENT SHALL RECOVERY OF ANY KIND AGAINST CANON BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT SOLD BY CANON AND CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF USE OR MISUSE OF, OR INABILITY TO USE, THE PRODUCT NOT CAUSED DIRECTLY BY THE NEGLIGENCE OF CANON (SOME STATES AND PROVINCES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU). THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT, OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
Canon U.S.A., Inc., One Canon Park, Melville, NY 11747
Canon Canada Inc., 8000 Mississauga Road, Brampton, Ontario, L6Y 5Z7
Canon Sales and Service Center
Canon USA
One Canon Park,
Melville, NY 11747,USA
Tel: (1)-800-828-4040
Canon Canada Inc,
Brampton, Ontario, L6Y 5Z7, Canada
(1)-800-652-2666
Online Repair
Title Firmware Notice: RF1200mm F8 L IS USM: Firmware Version 1.0.4
Advisory Type Firmware Notice
Date 04.16.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
