Canon Support for REALiS WUX6000 D Pro AV | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.22.14
File Size 2.92 MB
Date 06.17.15
File Size 24.61 MB
Date 04.08.15
File Size 602.00 KB
Projector Specifications
Imaging Device 0.71" LCOS Reflective LCD panel x3
Aspect Ratio 16:10
Native Resolution 1920 x 1200 (WUXGA)
Brightness 6000 Lumens (Normal) / 4660 Lumens (Power Saver)
Uniformity 88%
Contrast Ratio 2000:1
Digital Keystone (Vertical) ± 20 degrees
Digital Keystone (Horizontal) ± 20 degrees
Optics
Projection Lens Projector does not ship with lens. 5 optional interchangeable lenses are availabel (see Optics listed below).
Lens Shift Motorized
Zoom Powered
Focus Powered
Image Adjustments
Color Adjust Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Mounting 360° projection
Tilt Angle Bottom Front Feet: 2 places (Max. angles: 6&deg; elevation)
Input Signals
Scanning Frequency H: 27 , 75 kHz, V: 24 , 60Hz
Analog PC Input WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+ / FWXGA / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+ / FWXGA / WXGA / SXGA / XGA / SVGA / VGA
Component Input 1080p / 1080i / 720p / 576p / 576i / 480p / 480i
Digital Video Input 1080p / 1080i / 720p / 576p / 480p
Terminals
(Input) DVI-I 29pin Digital PC/Analog PC Input
(Input) D-Sub 15pin Analog PC/Component Video Input
(Input) RJ-45 Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
(Input) Stereo Mini Jack Audio Input x2
(Output) Stereo Mini Jack Audio Output x1, Connecting Wired Remote
Built-in Speaker 5W, Mono
Control Terminal Dsub9: RS-232C Connection
USB type A: Service Port
RJ-45: Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
Lamp
Lamp Type 340-NSHA lamp
Lamp Life 3000 Hours Full Power / 4000 Hours Power Saver
Ratings
Fan Noise (Quiet/Normal) 40dB (Full Power) / 36dB (Power Saver)
Power Consumption (Normal/Quiet/Stand-By) 455W/360 W
Power Voltage AC 100 , 240V, 50/60 Hz
Temperature Operating 32&deg;F - 104&deg;F (0&deg;C - 40&deg;C)
Temperature Storage 14&deg;F - 140&deg;F (-10&deg;C - 60&deg;C)
Dimension (WxHxD) W: 14.96"(380 mm), H: 6.69"(170mm), D: 16.92"(430 mm) (including protrusion)
Weight 18.73 lbs.
Projector Warranty 3 Years (parts and labor),120 Days lamp
Lamp Warranty 120 Days
General Specifications
Image Mode Standard / Presentation / Dynamic / Video / Cinema / Photo / sRGB / Vivid Photo / DICOM SIM / User 1 / User 2 / User 3 / User 4 / User 5
(Input) HDMI Digital RGB Input
(Input) DVI-D 29pin Digital RGB / Digital Video Input (supports Deep Color)
(Input) Mini D-Sub 15pin Analog RGB / Component Video Input
Power 336W
Standard Zoom Lens RS-IL01ST
Throw Ratio 1.49 - 2.24:1
Focal Length 23.0 - 34.5 mm, 1.5x Optical Zoom
F-Number 1.89 - 2.65
Projection Distances 4.26 - 95.14 ft. (1.3 - 29 m)
Lens Shift (Vertical) Down 15% to Up 55%
Lens Shift (Horizontal) Left 10% to Right 10%
Screen Sizes 40" - 600"
Long Focus Zoom Lens RS-IL02LZ
Throw Ratio 2.19 - 3.74:1
Focal Length 34.0 - 57.7 mm, 1.7x Optical Zoom
F-Number 1.99 - 2.83
Projection Distances 6.23 - 159.12 ft. (1.9 - 48.5 m)
Ultra Wide Angle Lens RS-IL03WF
Throw Ratio 0.80:1
Focal Length 12.8 mm
F-Number 2.0
Projection Distances 2.26 - 17 ft. (0.69 - 5.17m)
Lens Shift (Vertical) Down 5% to Up 5%
Lens Shift (Horizontal) Left 2% to Right 2%
Screen Sizes 40" - 300"
Ultra Long Focus Zoom Lens RS-IL04UL
Throw Ratio 3.55 - 6.94:1
Focal Length 53.6 - 105.6mm, 1.95x Optical Zoom
F-Number 2.34 - 2.81
Projection Distances 15.1 - 292 ft. (4.6 - 89.0m)
Screen Sizes 60" - 600"
Short Focus Zoom Lens RS-IL05WZ
Throw Ratio 1.00 - 1.50:1
Focal Length 15.56 - 23.44mm, 1.5x Optical Zoom
F-Number 2.09 - 2.34
Projection Distances 2.95 - 64 ft. (0.9 - 19.5m)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
