Canon Support for REALiS WUX500 D Pro AV | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
NMPJ Ver. 1.2 User's Manual
File Name
WUX500, WUX450ST User's Manual
SELECT ERROR CODE
Main Unit Spec
Projector Specifications
Imaging Device
0.71" LCOS Reflective LCD panel x3
Aspect Ratio
16:10
Native Resolution
1920 x 1200 (WUXGA)
Brightness
5000 Lumens (Normal) / 3800 Lumens (Power Saver)
Contrast Ratio
2000:1
Digital Keystone
V±20°, H±20°
Uniformity
90%
Zoom Ratio
1.8x
Electronic Zoom
12x Maximum
Focus
Manual
Lens Shift
Manual V: 0% -60%, H: ±10%
Throw Ratio
1.39 - 2.51:1
Image Adjustments
Image Mode
Standard / Presentation / Dynamic / Photo / sRGB / User 1 / User 2 / User 3 / User 4 / User 5
Color Adjust
Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Wall Correction
Normal / Greenboard / Adjust (custom)
Mounting
360° projection
Tilt Angle
Bottom Front Feet: 2 places (Max. angles: 6° elevation)
Input Signals
Scanning Frequency
TBD
Analog PC Input
WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+ / FWXGA / WXGA / SXGA / XGA / SVGA / VGA
Digital PC Input
Component Video Input
1080p / 1080i / 720p / 576p / 576i / 480p / 480i
HDBaseT
Equivalent to the Input Signal of Digital PC Input and Digital Video Input.
USB Data Transfer
JPEG Still Image
Digital Video Input
1080p / 1080i / 720p / 576p / 480p
Dot Clock
TBD
Terminals
DVI-I
Digital PC/Analog PC Input
HDMI
Digital PC/Digital Video Input (supports deep color)
RJ-45 (HDBaseT)
HDBaseT input (image, audio and control signal)
Mini Dsub15
Analog PC/Component Video Input
Mini Jack x3
Audio Input x2, Audio Output x1
Mini Jack x1
Connecting Wired Remote
Dsub9
13.5 , 162MHz
Dsub9
RS-232C Connection
USB type A
Service Port
RJ-45
Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
WiFi
NMPJ (Network Multi-Projection)
Remote Control
Remotes
Wireless Infrared (supplied) or Wired (optional)
Built-In Sound
Internal Amplifier
5W, Mono
Lamp
Type
250-NSHA lamp
Life
3000 Hours Full Power / 5000 Hours Power Saver
Power
260/200 W
Ratings
Fan Noise
37dB (Full Power) / 30dB (Power Saver)
Power Consumption
365/295 W
Standby Power
1.6 (HDBaseT)0.6 (Network) /0.2 W (Standard)
Heat Dissipation
Up to 1,246 BTU/h
Power Voltage
AC 100 , 240V, 50/60 Hz
Operating Temperature
32°F - 104°F (0°C -40°C)
Storage Temperature
14°F - 140°F (-10°C - 60°C)
Dimensions (W x H x D)
W: 13.26"(337 mm), H: 5.35"(136mm), D: 14.56"(370 mm) (including protrusion)
Weight
13 lbs. (5.9 kgs)
Projector Warranty
3 Years (parts and labor)
Lamp Warranty
120 Days
ADDITIONAL SUPPORT
CONTACT US
