Canon Support for REALiS WUX450 D Pro AV | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Projector Specifications
Imaging Device | 0.71" LCOS Reflective LCD panels x 3 |
Aspect Ratio | 16:10 |
Native Resolution | WUXGA (1920 x 1200) |
Brightness | 4500 Lumens / 3460 (Power Save Mode) |
Contrast Ratio | 2000:1 |
Digital Keystone (Vertical) | ±20 degrees |
Digital Keystone (Horizontal) | ±20 degrees |
Optics
Lens Shift | Vertical 0% to 60% Horizontal +10% to -10% |
Throw Ratio | 1.39 - 2.51:1 |
Image Adjustments
Mounting | Ceiling / Rear / Rear-Ceiling / Upward / Downward |
Tilt Angle | Adjustable feet up to 6 degrees |
Input Signals
Scanning Frequency | H: 15,75 kHz, V: 50,85 Hz; Dot Clock: 162 MHz |
Digital PC Input | WUXGA / UXGA / WSXGA+ / SXGA+ / WXGA+ / FWXGA / WXGA / SXGA / XGA / SVGA / VGA |
Component Input | 1080p / 1080i / 720p / 576p / 576i / 480p / 480i |
Digital Video Input | 1080p / 1080i / 720p / 576p / 480p |
Terminals
(Input) DVI-I 29pin | Analog PC / Digital PC input |
(Input) RJ-45 | Yes |
(Input) Stereo Mini Jack | Stereo Input x2 |
(Output) Stereo Mini Jack | Stereo Output x1 |
Built-in Speaker | 5W (Mono) |
Control Terminal | D-sub 9pin: RS-232C Network: RJ-45 (100BASE-T / 100BASETX / 10-BASE-T) |
Lamp
Lamp Type | 250W NSH (AC) |
Lamp Life | 3000 hours / 4000 hours (Economy Mode) |
Remote Control
Sensor | Wireless Infrared (Front / Back Wired Remore Control Connection) |
Ratings
Fan Noise (Quiet/Normal) | 38dB (Normal) / 32dB (Power Saver) |
Power Consumption (Normal/Quiet/Stand-By) | 365W (Normal) / 295W (Power Saver) / 1.0W (Standby) / 0.35W (Standby with LAN off) |
Power Voltage | AC 100 , 240V, 50/60Hz |
Temperature Operating | 32° to 104° F (0° to 40° C) |
Temperature Storage | -4° to 140° F (-20° to 60° C) |
Dimension (WxHxD) | 13.3 x 4.6 x 16.9 in. (without lens, including protruding parts) |
Weight | 13.0 lbs. |
Warranty | 3 years parts and labor, 120 day lamp |
ADDITIONAL SUPPORT
CONTACT US
