Canon Support for REALiS WUX400ST D Pro AV | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 05.22.14
File Size 1.53 MB
Date 05.10.14
File Size 1.53 MB
Projector Specifications
Native Resolution WUXGA (1920 x 1200)
Brightness 4000 Lumens
Contrast Ratio 2000:1
Digital Keystone (Vertical) 0-75 degrees (manual)
Digital Keystone (Horizontal) ±10 degrees (manual)
Optics
Lens Shift Vertical 0% to 75%
Horizontal +10% to -10%
Throw Ratio 0.56:1
Terminals
(Input) RJ-45 1000baseT
(Input) Stereo Mini Jack x2
(Output) Stereo Mini Jack x1
Built-in Speaker 5W
Lamp
Lamp Type 260W
Ratings
Fan Noise (Quiet/Normal) 32dB (Quiet) / 38dB (Normal)
Heat Dissipation Up to 1,246 BTU/h
Temperature Operating 32&deg; to 104&deg; F (0&deg; to 40&deg; C)
Temperature Storage -4° to 140° F (-20° to 60° C)
Dimension (WxHxD) 337mm x 126mm x 362mm (without stick-out)
337mm x 132mm x 415mm (with stick-out)
Title Canon Support | Firmware Notice: REALiS WUX400ST Pro AV & REALiS WUX400ST D Pro AV: Firmware Version 01.050400
Advisory Type
Date 07.26.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
