Canon Support for PowerShot SX70 HS | Canon U.S.A., Inc.
PowerShot SX70 HS
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.28.19
File Size 426.85 KB
Date 09.30.24
File Size 142.00 B
Date 10.28.19
File Size 15.51 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
Compact digital still camera with built-in flash, 65x Optical, 4x Digital and 260x Combined Zoom with Optical Image Stabilizer
Type
20.3 Megapixel*, 1/2.3-inch CMOS
* Image processing may cause a decrease in the number of pixels.
Total Pixels
Approx. 21.1 Megapixels
Effective Pixels
Approx. 20.3 Megapixels
Focal Length
3.8 (W) - 247.0 (T) mm (35mm film equivalent: 21-1365mm)
Optical Zoom
65x
Digital Zoom
Approx. 4x
Focusing Range
Auto: 0.0 in. (0cm) - infinity (W), 5.9 ft. (1.8m) - infinity (T)
Normal: 2.0 in. (5cm) - infinity (W), 5.9 ft. (1.8m) - infinity (T)
Macro: 0.0 in. - 1.6 ft. (0 - 50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
Electronic Viewfinder (Approx. 2,360,000 dots)
LCD Monitor
3.0-inch TFT Color Vari-angle LCD with wide viewing angle (4:3)
LCD Pixels
Approx. 920,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.4 (W), f/6.5 (T)
Shutter Speed
11/2000 sec.
151/2000 sec. (in all shooting modes)
Sensitivity
Auto: ISO 100-800
P: ISO 100-3200
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Compensation
&plusmn;3 stops in 1/3-stop increments
White Balance Control
Auto, Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash, Custom, WB Correction
Built-in Flash
Auto, On, Slow Sync, Off
Flash Range
Approx. 1.6-21.3 ft. (W), 5.9-13.1 ft. (T)
Approx. 50.0cm - 5.0m (W), 2.0-2.5m (T)
Shooting Modes
M, Av, Tv, P, Auto, Standard, Vivid, Neutral, B/W, Sepia
Self Timer
Off / 2 sec. / 10 sec. / Custom
Wireless Control
Built-in Wi-Fi&reg; and Bluetooth&reg;
Continuous Shooting
High-speed Continuous Shooting in One-Shot AF mode: Approx. 10.0 shots/sec.
Low-speed Continuous Shooting in One-Shot AF mode: Approx. 3.0 shots/sec.
High-speed Continuous Shooting in Servo AF mode: Approx. 5.7 shots/sec.
Low-speed Continuous Shooting in Servo AF mode: Approx. 3.0 shots/sec.
Continuous shooting speed may become slower due to the following factors: Tv value, Av value, subject conditions, shooting environment, use of flash, ISO speed, zoom position.
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Fine / Normal
JPEG Compression Mode
Still Image: EXIF 2.31 (DCF2.0)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 Large: 5184 x 2912; Medium: 3648 x 2048; Small: 2432 x 1368
2) 3:2 Large: 5184 x 3456; Medium: 3648 x 2432; Small: 2432 x 1616
3) 4:3 Large: 5184 x 3888; Medium: 3648 x 2736; Small: 2432 x 1824
4) 1:1 Large: 3888 x 3888; Medium: 2736 x 2736; Small: 1824 x 1824
5) Panoramic shot Horizontal, Maximum: 20960 x 2736; Min: 5184 x 2736. Vertical, 15744 x 3648; Minimum: 3648 x 3888
Videos:
4K* 3840 x 2160: 29.97 fps
Full HD 1920 x 1080, 59.94 fps, 29.97 fps
HD 1280 x 720: 59.94 fps
*Shooting takes place by cropping pixels from the center of the sensor.
Playback Modes File
Protect, Rotate, Movie compression, Slideshow, Rating, Movie Playback, Highlight Alert, Movie Frame Grab*, Resize**, Cropping**, Tilt Correction**, Red-Eye Correction**
* 4K movies only.
** Applicable only to images taken with the same model.
Video Out
HDMI (Type D)
Audio Out
Stereo
Other
Hi-Speed USB (Micro); direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack LP-E12
Shooting Capacity
Number of still image shots (CIPA compliant):
Screen ON: Approx. 325 shots
Electronic color viewfinder On: Approx. 255 shots
Screen ON: Approx. 405 shots in ECO Mode
Video Recording Time (CIPA compliant):
Screen ON: Approx. 85 min.
Electronic color viewfinder On: Approx. 75 min.
Playback Time
Approx. 6 hrs.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
Approx. 5.00 x 3.58 x 4.59 in. / 127.0 x 90.9 x 116.6mm
Weight
Approx. 1.34 lbs. / 608g (CIPA standard)
Approx. 1.27 lbs. / 576g (Body only)
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
Wireless API Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: PowerShot SX70 HS: Firmware Version 1.1.1
Advisory Type
Date 11.20.19
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
