Canon Support for PowerShot SX120 IS | Canon U.S.A., Inc.
PowerShot SX120 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 09.17.09
File Size 2.99 MB
Date 03.05.10
File Size 6.23 MB
Date 08.20.09
File Size 6.05 MB
Date 11.12.09
File Size 6.94 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
10.0 Megapixel, 1/2.5-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 10.3 Megapixels
Effective Pixels
Approx. 10.0 Megapixels
Focal Length
6.0 (W) - 60.0mm (T) f/2.8 (W) - f/4.3 (T)
(35mm equivalent: 36 (W) - 360 (T) mm)
Digital Zoom
4x
Focusing Range
Normal: 1.6 ft./50cm-infinity (W), 3.3 ft./1m-infinity (T)
Macro: 0.4 in.-1.6 ft./1-50cm (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
None
LCD Monitor
3.0-inch low-temperature polycrystalline silicon TFT color LCD with wide viewing angle
LCD Pixels
Approx. 230,000 pixels
LCD Coverage
100%
Maximum Aperture
Shutter Speed
15-1/2500 sec. (settable in Tv and M)
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent
(Subject movement is taken into account while shooting in Auto and Easy modes)
Light Metering Method
Evaluative*, Center-weighted average, spot**
* Facial brightness is also evaluated in Face Detect AF
** Fixed to center
Exposure Control Method
Program AE, Manual; AE Lock, Program Shift, Safety Shift, Auto ISO Shift
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
*The color of faces is evaluated in Face Detect
Built-in Flash
Auto, Auto w/Red-eye Reduction, Flash On, Flash On w/Red-eye Reduction, Flash Off; FE lock, Safety FE, Slow Synchro
Flash Range
50 cm - 4.0 m (W), 1.0 cm - 2.5 m (T) (1.6 - 13 ft. (W), 3.3 - 8.2 ft. (T))
Recycling Time
12 sec. or less (battery voltage: 3.0 V)
- LCD monitor is turned off during flash charging (Except when turning on the power)
Flash Exposure Compensation
Shooting Modes
Auto*, P, Av, Tv, M, Easy, Portrait, Landscape, Special Scene (Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, ISO 3200), Indoor, Kids & Pets, Night Snapshot, Movie, Night Scene
* Automatically detects the shooting scene.
Photo Effects
My Colors
My Colors Off, Vivid, Neutral, Sepia, Black & White, Custom Color*
*Adjustment of contrast, sharpness and saturation is available.
- Saving original image is not available.
Self Timer
Activates shutter after an approx. 2-sec./10-sec. delay, Custom*, Face Self-Timer**
* Shooting start time (0-10 sec. (in 1-second increments), 15/20/30 sec.) and number of shots (1-10 (in one-shot increments)) can be specified.
** When the number of detected faces increases, the shutter is released after 2 sec. delay. However, if no face is detected for 30 seconds or more, the shooting operation starts automatically.
Wireless Control
Not available
Continuous Shooting
Normal: approx. 1.3 fps; AF: approx. 0.9 fps; LV: approx. 0.9 fps
Storage Media
SD/SDHC memory card, MultiMediaCard, MMCplus card, HC MMCplus card
File Format
Design rule for camera file system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural))
Number of Recording Pixels
Still Image: 3,648 x 2,736 (Large), 2,816 x 2,112 (Medium 1), 2,272 x 1,704 (Medium 2), 1,600 x 1,200 (Medium 3), 640 x 480 (Small), 3,648 x 2,048 (Widescreen)
Movie: 640 x 480 (30 fps/30 fps LP), 320 x 240 (30 fps) available up to 4GB or 60 minutes per clip.
- Data stamp is available in all recording pixels
Image data
Movie data
Note: N=Normal, F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Category, Transition Effects, Histogram, Index (4-100 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Resize, Easy;
Movie: Normal Playback, Special Playback, Auto Rotate, Resume, Easy
Erase Modes
Still Image: single image, select all images
- The image data stored in the memory card with the design rule for camera file systems format can be erased. However, protected images cannot be erased)
Movie: any movie file (files must be erased one at a time)
Computer Interface
Hi-Speed USB* (dedicated connector (female) with unified type of digital audio and video**
* Use of USB logomark is not allowed.
** mini-B compatible.
Video Out
NTSC or PAL
Audio Out
Monaural
Other
Memory card slot; direct connection to Canon and SELPHY Compact Photo Printers, PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1. AA-size Alkaline Battery (x2)
2. Rechargeable AA-size NiMH Battery NB-3AH (x2)
3. AC Adapter Kit ACK-800 (optional)Still Image: approx. 130 shots (AA-size Alkaline Battery), approx. 370 shots (AA-size Ni-MH Battery)*Approx. 7 hrs. (AA-size Alkaline Battery), approx. 9 hrs. (AA-size Ni-MH Battery)
*LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.35 x 2.77 x 1.76 in./110.6 x 70.4 x 44.7mm
Weight
Approx. 8.64 oz./245g (camera body only)26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
