Canon Support for PowerShot SX1 IS | Canon U.S.A., Inc.
PowerShot SX1 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 09.17.08
File Size 1.43 MB
Date 04.09.09
File Size 7.61 MB
Date 09.26.08
File Size 4.94 MB
Date 04.02.25
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 20x Optical/4x Digital/80x Combined Zoom with Optical Image Stabilizer System
Image Capture Device
Type 10.0 Megapixel, 1/2.3-inch type CMOS sensor
Total Pixels Approx. 11.8 Megapixels
Effective Pixels Approx. 10.0 Megapixels
Lens
Focal Length 5.0-100.0mm f/2.8-5.7 (35mm film equivalent: 28-560mm)
Digital Zoom 4x
Focusing Range Normal: 1.6 ft./50cm-infinity (W), 3.3 ft./1m-infinity (T)
Macro: 3.9 in.-1.6 ft./10-50cm (W)
Super Macro: 0-3.9 in./0-10cm (W)
Autofocus System TTL Autofocus, Manual focus
Viewfinders
Optical Viewfinder TFT color
LCD Monitor 2.8-inch TFT color LCD widescreen with wide viewing angle
LCD Pixels Approx. 230,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 (W) - f/5.7 (T)
Shutter Speed 15-1/3200 sec.; Long Shutter operates with noise reduction when manually set at 1.3-15 sec.
Exposure Control
Sensitivity Auto, High ISO Auto, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index)
Light Metering Method Evaluative*, Center-weighted average, Spot**
* Control to incorporate facial brightness in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method Program AE, Manual Exposure, i-Contrast, Program Shift, Safety Shift, Auto ISO Shift; AE Lock
Exposure Compensation +/-2 stops in 1/3-stop increments
White Balance
White Balance Control Auto,* Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Flash
Built-in Flash Auto, Manual, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE Lock, Safety FE, Slow Synchro
Flash Range 1.6-15.7 ft./50cm-4.8m (W), 3.3-8.5 ft./1-2.6m (T) (when sensitivity is set to ISO Auto)
Recycling Time 7 sec. or less (battery voltage=6V)
Flash Exposure Compensation +/-2 stops in 1/3-stop increments
Shooting Specifications
Shooting Modes Auto, P, Av, Tv, M, C, Portrait, Landscape, Sports, Special Scene (Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, Night Scene, Indoor, ISO 3200, Color Accent, Color Swap, Long Shutter), Super Macro, Night Snapshot, Stitch Assist, Movie
Photo Effects My Colors
Vivid, Vivid Blue, Vivid Green, Vivid Red, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Custom
Self Timer Activates shutter after an approx. 2-sec./10-sec. delay, Face Detection Self-timer
Wireless Control Available with optional Wireless Controller WC-DC300
Continuous Shooting Normal: approx. 4.0 fps; AF: approx. 1.1 fps; LV: approx. 1.2 fps (Large/Fine)
Image Storage
Storage Media SD/SDHC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format Design rule for camera file system, DPOF Version 1.1
Image Recording Format Normal, Fine, SuperFine, RAW
JPEG Compression Mode Still Image: Exif 2.2 (JPEG)
Movie: MOV (Image: H.264; Audio: Linear PCM (Stereo))
Number of Recording Pixels Still Image: 3648 x 2736 (Large), 2816 x 2112 (Medium 1), 2272 x 1704 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 3840 x 2160 (Widescreen L), 1920 x 1080 (Widescreen S), RAW (3648 x 2736)
Movie: High Definition: 1920 x 1080 (30 fps); Standard Definition: 640 x 480 (30 fps), 320 x 240 (30 fps), available up to 4GB or 29 min. 59 sec. (HD)/60 min. (SD) per clip
Number of Recordable Images
Image data
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Specifications
Playback Modes File Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, My Colors, My Category, Transition Effects, Histogram, Overexposure Warning, Index, Slide Show, Red-eye Correction, Trimming, Resize, Image Inspection Tool, i-Contrast
Movie: Normal Playback, Special Playback, Editing, Auto Rotate, Resume
Erasing Specifications
Erase Modes Still Image: single image, select range, select by date, select by category, select by folder, all images
Movie: part of movie, all of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B jack)
Video Out NTSC/PAL
Audio Out Stereo
Other Mini-HDMI cable: connection to high definition monitor; Memory card slot: direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply 1.AA-size Alkaline Battery (x4) 2.Rechargeable AA-size Ni-MH Battery (x4) (NB-3AH)3.Compact Power Adapter CA-PS700 (optional)Still Image: approx. 160 shots (AA-size Alkaline Battery), approx. 420 shots (AA-size Ni-MH Battery (NB-3AH)) *Approx. 720 min. (AA-size Battery), approx. 840 min. (AA-size Ni-MH Battery) * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source 1.AA-size Alkaline Battery (x4) 2.Rechargeable AA-size Ni-MH Battery (x4) (NB-3AH)3.Compact Power Adapter CA-PS700 (optional)
Shooting Capacity Still Image: approx. 160 shots (AA-size Alkaline Battery), approx. 420 shots (AA-size Ni-MH Battery (NB-3AH)) *
Playback Time Approx. 720 min. (AA-size Battery), approx. 840 min. (AA-size Ni-MH Battery) * LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Physical Specifications
Operating Temperature 32-104&deg;F/0-40&deg;C
Operating Humidity 10-90%
Dimensions (W x H x D) 5.02 x 3.48 x 3.45 in./127.5 x 88.3 x 87.7mm
Weight Approx. 20.6 oz./585g (camera body only)
Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian,Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish,Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
