Canon Support for PowerShot SD20 | Canon U.S.A., Inc.
PowerShot SD20
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash and 6.5x digital zoom. |
Image Capture Device
Type | 1/2.5 inch Charge-Coupled Device (CCD) |
Total Pixels | Approx. 5.4 Million |
Effective Pixels | Approx. 5.0 Million |
Lens
Focal Length | 6.4mm (35mm film equivalent: 39mm) |
Focusing Range | Normal: 3.9 in./10cm to Infinity, Macro: 1.2-3.9 in./3-10cm |
Autofocus System | 9-point AiAF/1-point AF (Fixed to center), AF-assist Beam (On/Off selectable) |
Viewfinders
Optical Viewfinder | None |
LCD Monitor | 1.5 inch low temperature polycrystalline silicon TFT color LCD |
LCD Pixels | Approx. 78,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/2.8 |
Shutter Speed | 15-1/1500 sec. |
Exposure Control
Sensitivity | Auto*; ISO 50/100/200/400 (equivalent ISO) *Camera automatically sets optimum speeds. |
Light Metering Method | Evaluative, Center-weighted average or Spot* *Metering frame when spot is center fixed. |
Exposure Control Method | Program AE |
Exposure Compensation | +/-2.0 stops in 1/3-stop increments |
White Balance
White Balance Control | Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom |
Flash
Built-in Flash | Auto, Auto with Red-Eye Reduction, Flash on with Red-Eye Reduction, Flash On/Off, Slow-sync |
Flash Range | Normal: 1.0-6.6 ft./30cm-2.0m (When ISO is set to AUTO) |
Recycling Time | Approx. 10 sec. or less |
Flash Exposure Compensation | Not available |
Shooting Specifications
Shooting Modes | Auto, Manual, Portrait, Night Snapshot, Indoor, Underwater, Macro, Stitch Assist, Movies |
Photo Effects | Off, Vivid, Neutral, Low Sharpening, Sepia, Black & White |
Self Timer | Operates with approx. 10 sec. or 2 sec. Delay |
Wireless Control | Not Available |
Continuous Shooting | Approx. 0.9 shots/sec. |
Image Storage
Storage Media | SD Memory Card |
File Format | Design Rule for Camera File System Exif 2.2 (JPEG) |
Print Order Format | Digital Print Order Format (DPOF) Version 1.1 |
Image Recording Format | Still Image: JPEG (Exif 2.2 compliant) |
JPEG Compression Mode | SuperFine, Fine or Normal |
Number of Recording Pixels | Large: 2592 x 1944, Medium1: 2048 x 1536 Medium2: 1600 x 1200, Small: 640 x 480 pixels Movie: 640 x 480, 320 x 240 or 160 x 120 |
Number of Recordable Images
Image data | Note: N=Normal F=Fine SF=SuperFine Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes. |
Playback Specifications
Playback Modes File | Single, Index (9 thumbnail images) |
Erasing Specifications
Erase Modes | Still images: Single Image, All Images Movie: Part of Movie, All Movie |
Interfaces
Computer Interface | USB (mini-B, PTP), Audio/Video Output (NTSC or PAL selectable) |
Video Out | NTSC or PAL |
Other | SD memory card slot. Direct connection to Canon CP Printers and BJ Photo Printers (no computer required), using camera's USB cable. ID Photo Print, Movie Print |
Power Supply | Rechargeable Lithium-ion battery (NB-3L)NB-3L: LCD On - Approx. 120 shotsApprox. 140 min. |
Power Source | Rechargeable Lithium-ion battery (NB-3L) |
Shooting Capacity | NB-3L: LCD On - Approx. 120 shots |
Playback Time | Approx. 140 min. |
Physical Specifications
Operating Temperature | 32-104° F/0-40° C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.56 x 1.85 x 0.73 in. / 90.3 x 47.0 x 18.5mm |
Weight | Approx. 3.53 oz./100g (camera body only) |
21 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian and Turkish) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
