Canon Support for PowerShot S45 | Canon U.S.A., Inc.
PowerShot S45
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 2.26 MB
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 2.68 MB
Date 04.19.10
File Size 234.0 KB
Date 04.19.10
File Size 770.0 KB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact Digital Still Camera with Built-in Flash and 3x Optical Zoom Lens. Lens and Flash accessories available.
Image Capture Device
Type 1/1.8-inch Charge-Coupled Device (CCD)
Total Pixels Approx. 4.1 Million
Effective Pixels Approx. 4.0 Million
Lens
Focal Length 7.1 - 21.3mm zoom lens (35mm film equivalent: 35 - 105mm)
Digital Zoom 3.6x
Focusing Range Normal AF: 50cm (1.6 ft.) - infinity
Macro AF: 10 - 50cm/ 3.9in. - 1.6 ft. (wide-angle)/ 33 - 50cm/ 1.0 - 1.6 ft. (telephoto)
Manual focus: 10cm/ 3.9 in. - infinity (wide-angle) / 30cm/ 1.0 ft. - infinity (telephoto) - infinity
Autofocus System Around most of picture area; AF lock and Manual focus are available. AF lock and Manual focus are available.
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8 inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approximately 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 - 4.9
Shutter Speed 15 - 1/1,500 sec.
Slow shutter speed of 1.3 sec. is only available in select modes.
Exposure Control
Sensitivity AUTO/ISO 50/100/200/400 equivalent
Light Metering Method Evaluation/ Center-weighted average/ Spot
Exposure Control Method Program AE, Shutter priority AE, Aperture priority AE or Manual
Exposure Compensation +/- 2 EV in 1/3-step increments
Auto Exposure Bracketing (AEB) is available
White Balance
White Balance Control TTL Auto White Balance, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom.
Flash
Built-in Flash Operation Modes: Auto/ On/ Off, Auto Red-Eye Reduction ON/ OFF
Flash Range WIDE: 1.8 - 13.1ft.TELE: 1.8 - 8.2 ft.(When sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or less.
Flash Exposure Compensation +/- 2.0 EV in 1/3-step increments
Shooting Specifications
Shooting Modes Creative zone: Program, Shutter priority, Aperture priority, Manual, and Custom. Image zone: Portrait, Landscape, Night Scene, Fast Shutter, Slow Shutter, Stitch Assist and Movie
Photo Effects Vivid Color, Neutral Color, Low Sharpening, Sepia, Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down
Wireless Control Not Available
Continuous Shooting High Speed: Approx. 2.5 images/sec., Normal: Approx. 1.5 images/sec.
Image Storage
Storage Media CompactFlash (CF) Card Type I or Type II
File Format Design rule for Camera File System (DCF*1)
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)/ RAW
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels 2592 x 1944/ 2272 x 1704 (Large), 1600 x 1200 (Medium 1), 1024 x 768 (Medium 2), 640 x 480 pixels (Small)
Movie: 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Individual movie clips are limited to 3 minutes maximum per clip. Above figures show total movie capacity on various CF cards, measured under Canon's standard test conditions, and may vary depending upon scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (approx. 2x to 10x on built-in LCD monitor) or Slide Show
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out Audio/Video Output (Video: NTSC or PAL selectable monaural audio)
Other CF card slot (accept type I and type II cards). Direct connection to Canon CP Printer CP-100, and select Bubble Jet Direct Photo Printers (no computer required).
Power Supply 1. Rechargeable Lithium-ion battery (NB-2L).
2. AC Adapter kit (ACK-700)
3. Car battery adapter (CBC-NB2)
Important Safety InformationApprox. 210 shots (LCD monitor ON)
Approx. 460 shots (LCD monitor OFF)Approx 160 min.
Power Source 1. Rechargeable Lithium-ion battery (NB-2L).
Shooting Capacity Approx. 210 shots (LCD monitor ON)
Playback Time Approx 160 min.
Physical Specifications
Operating Temperature 32 - 104&deg;F (0 - 40&deg;C)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 4.41 x 2.28 x 1.65 in./112.0 x 58.0 x 42.0mm (Excluding protrusions)
Weight Approx. 9.2 oz./260g (camera body only)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 9.0 through 9.2, OS X (Version 10.1/10.2). (Please see our Mac OS X Compatibility Statement)
Note: Adobe Photoshop LE, Canon File Viewer Utility v. 1.0, and USB Mounter v. 1.8 software are not supported in Mac OS X.
CPU: Power PC
Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook).
RAM: 20MB and over for application
PC Requirements Hardware: IBM PC/AT compatible
OS: Windows 98 (including the Second Edition), Windows 2000, Windows ME, Windows XP (Please see our Windows XP compatibility statement)
CPU: Pentium 150 MHz and over
Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME or Windows XP systems.
RAM: 64MB or more (Windows 2000/ Windows ME/ Windows 98), 128MB or more (Windows XP)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronics and Information Technology Industries Association (JEITA).
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
