Canon Support for PowerShot Pro 90 IS | Canon U.S.A., Inc.
PowerShot Pro 90 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.01.07
File Size 6.24 MB
Date 01.01.02
File Size 13.35 MB
Date 04.01.07
File Size 2.81 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 3.84 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Capture Device
Type Interline transfer CCD
Total Pixels Approx. 3.34 million (2,140 x 1,560)
Effective Pixels Approx. 3.24 million (2,088 x 1,550)
Lens
Focal Length 7mm (Wide-angle) - 70mm (Telephoto)(37mm (Wide-angle) - 370mm (Telephoto) (35mm film equivalent)
Focusing Range Wide-angle: 10cm (3.9 in.) - infinity
Telephoto: 1m (39 in.) - infinity
Normal: 3.3 ft. (1m) - Infinity (63mm equivalent - T)
Normal+Tele-converter: 7.2 ft. (2.2m) - Infinity (126mm equivalent - T)
Normal+Close-up Lens: 1.1 - 1.6 ft. (33 - 50cm) (T)
Macro: 3.9 in. - 1.6 ft. (10 - 50cm) (W - 63mm equivalent)
Macro: 1.0 - 1.6 ft. (30 - 50cm) (63 - 90mm equivalent)
Super Macro: 1.2 in. - 1.0 ft.(3 - 30cm) (42 - 90mm equivalent)
Manual: 3.9 in. (10cm) - Infinity (W - 63mm equivalent)
Manual: 1.0 ft. (30cm) - Infinity (63mm - 90mm equivalent)
Manual: 3.3 ft. (1m) - Infinity (90mm equivalent - T)
Autofocus System 13 elements in 10 groups
Viewfinders
Optical Viewfinder Color LCD viewfinder
LCD Monitor 46mm diagonal (1.8 inch) Low-temperature polycrystalline silicon TFT LCD
LCD Pixels 113,578 dot (521 (H) x 218 (V))
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture Wide-angle : f/2.8-f/8.0 / Telephoto : f/3.5-f/8.0
Shutter Speed 8 - 1/1000 sec.
Exposure Control
Sensitivity Auto/ISO 50/100/200/400
Light Metering Method Center-weighted averaging/Spot
Exposure Control Method Program AE/Shutter speed-priority AE/Aperture-priority AE/Manual
Exposure Compensation Compensation +/-2.0 in 1/3-stop increments
White Balance
White Balance Control TTL auto / preset (Daylight, Cloudy, Tungsten, Fluorescent and Flash) or Custom
Flash
Built-in Flash Auto, Red-Eye Reduction auto, Red-Eye Reduction ON, ON or OFF
Flash Range 0.7 - 4.2 m (Wide-angle) / 1 - 3.4 m (Telephoto)
Recycling Time 10 sec. or shorter (full flash, battery voltage = 7.4 V)
Flash Exposure Compensation +/-2.0 EV (at every 1/3-stop)
Shooting Specifications
Shooting Modes Auto, Creative zone (Manual / Shutter speed-priority / Aperture-priority / Program), Image zone (Pan-focus / Portrait / Landscape / Night Scene / Black & White / Stitch Assist / Movie)
Self Timer Operates with approx. 10-sec. countdown
Wireless Control Shooting and playback are available (Wireless controller is included in the camera kit)When shooting, image is captured 2 seconds after shutter release operation.
Continuous Shooting 0.7 images/sec. (at Large / Fine)
Image Storage
Storage Media CompactFlash Card Type I, II
File Format Design rule for Camera File system (DCF) (main image and thumbnail: JPEG)(DCF is an abbreviation of "Design rule for Camera File System" standardized by Japan Electronics and Information Technology Industries Association (JEITA))
Print Order Format DPOF ver. 1.0
Image Recording Format JPEG or RAW (still image)AVI (Motion JPEG : image, WAVE: audio (monaural)) (movie)
JPEG Compression Mode Super Fine, Fine and Normal/CCD RAW
Number of Recording Pixels Large: 1,856 x 1,392, Middle: 1,024 x 768, Small: 640 x 480, Movie: 320 x 240
Number of Recordable Images
Image data
Power Supply
Physical Specifications
Operating Temperature 0 - 40&deg;C (32 - 104&deg;F)
Operating Humidity 10 - 90%
Dimensions (W x H x D) 4.98 in. x 3.3 in x 5.48 in./126.5 x 83.9 x 139.1mm (excluding protrusions)
Weight Approx. 680 g (23.9oz) (excluding batteries and CF card)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.1, QuickTime 3.0 or higher (QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included in this package) (Please see our Mac OS X Compatibility Statement.)
CPU: Power PC
Interface: USB (iMac, iBook and Power Macintosh NEW G3 / Power Macintosh G4 or PowerBook G3 with Apple genuine USB interface only. IMac Update 1.0 and iMac Firmware Update 1.0 must be installed for use in your iMac computer under Mac OS 8.1); RS-422 (Modem port or printer port - optional Interface Cable IFC-200MC is required).
RAM: 20MB RAM minimum for application memory Display: 800 x 600 pixels - 256 colors minimum, 1024 x 768 pixels - thousands of colors or more recommended
PC Requirements Hardware: IBM PC/AT compatible
OS: Windows 95/98 (including the Second Edition), Windows NT 4.0 (Service Pack 3 or higher required), Windows 2000, Windows ME(Please see our Windows XP Compatibility Statement.)
CPU: Pentium 133 MHz or better. Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RS-232C: Serial or COM port.
RAM: 32MB or more (Windows 95/98), 64MB or more (Windows NT 4.0/Windows 2000/Windows ME)
Plug-In Module requires Adobe Photoshop 3.0 or higher (Adobe Photoshop 5.0LE is included in this package).
* Warranty program is subject to certain restrictions and limitations. See warranty card for full details.
All data are based on Canon's standard test method. Subject to change without notice.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
