Canon Support for PowerShot PICK Active Tracking | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 11.01.21
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type 1/2.3 CMOS sensor
Effective Pixels Approx 11.7MP
Total Pixels Approx 12.8MP
Type DIGIC 7
Focal Length 19-57mm
Zoom 3x (optical) 4x (digital)
Angle of View (Horzntl, Vertl, Diagnl) Horizontal: Approx 84.7° (wide angle end) - 33.8° (tele angle end)
Vertical: Approx 68.7° (wide angle end) - 25.7° (tele angle end)
Diagonal: Approx 97.5° (wide angle end) - 41.6° (tele angle end)
Pan/Tilt Pan: Approx -170° (left) to +170° (right)
Tilt: Approx -20° (down) to +90° (up)
Closest Focusing Distance 20cm (wide), 30cm (tele)
Still Image Type JPEG
RAW+JPEG/HEIF Simultaneous Recording Full HD (1920 x 1080) 59.94fps, 29.97fps, 23.98fps IPB (Standard) MP4
Menu Languages Japanese, English, Simplified Chinese, French, German, Italian, Spanish, Russian, Korean, Turkish, Portugese (Brazilian)
Voice Control English, French, German, Italian, Spanish, Russian
Wired Connectivity USB Type-C
Wireless Connectivity Bluetooth Specification 4.1 compliant (Bluetooth Low Energy Technology), Wi-Fi IEEE802.11b/g/n 2.4GHz
Type MicroSD, MicroSDHC, MicroSDXC. UHS-I supported
Other Connect App for Mini PTZ Cam available on compatible iOS and Android devices. View and transfer images, control device, change device settings - see app store for full details
Wireless Webcam Utility for Mini PTZ Cam available for Windows. For full details see support pages
Batteries Built-in Rechargeable Lithium Ion
Battery Life 2/3.5/5 hours (high/mid/low shooting frequency)
Power Supply & Battery Chargers USB Type-C, Minimum charging requirement is a USB PD compliant power source providing a minimum of 5V, 1.5A with a USB Type-C output and using the provided USB Type-C to Type-C cable. Minimum for power and operation 9V 2A
Operating Environment Temp: 0-40°C
Humidity range: 10-90%
Tripod Mount Standard CU 1/4"
Dimensions (W x H x D) Approx 56.4mm x 81.9mm
Weight Approx 170g (including memory card)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Firmware Notice: PowerShot Pick: Firmware Version 1.4.0
Advisory Type Firmware Notice
Date 01.18.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
