Canon Support for PowerShot N | Canon U.S.A., Inc.
PowerShot N
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.25.13
File Size 4.70 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 12.8 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
5.0 (W) - 40.0 (T) mm (35mm film equivalent: 28 (W) - 224 (T) mm)
Optical Zoom
8x
Digital Zoom
4x
Focusing Range
Normal: 0.4 in. (1cm) - infinity (W), 3.3 ft. (1m) - infinity (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
2.8-inch TFT Color Tilt Capacitive Touch LCD (up to 90&deg;)
LCD Pixels
Approx. 461,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.0 (W) - f/5.9 (T)
Shutter Speed
1 - 1/2000 sec.
15 - 1/2000 sec. (Total shutter speed range)
Sensitivity
Auto, ISO 80/100/200/400/800/1600/3200/6400 (in P mode)
Light Metering Method
Evaluative, Center-weighted average, Spot
Exposure Control Method
N/A
Exposure Compensation
+/-2 stops in 1/3 stop increments(Not available when shooting movies)
White Balance Control
Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H
Built-in Flash
Auto, On, Slow Synchro, Off
Flash Range
50 - 90 cm (W) (1.6 - 3.0ft. (W))*1*2
*1 10-50 cm (3.9in - 1.6ft.) when the scene is detected as Macro.
*2 The telephoto focusing range is beyond the flash metering range.
Recycling Time
10 seconds or less (battery voltage: 3.7 V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto, Hybrid Auto, P, Creative Shot, Fisheye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Slow Motion Movie
- Shooting movies is possible with the movie button in a still image mode*.
* Modes that inherit the image effects available in still image shooting (in other modes, movies equivalent to those captured in P mode are produced): P, Auto, Miniature Effect and Monochrome
Photo Effects
N/A
Self Timer
Approx. 10-sec. delay, approx. 2-sec. delay
Wireless Control
N/A
Continuous Shooting
Approx. 2.3 shots/sec. (in P mode)
Storage Media
microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compatible
JPEG Compression Mode
Still Images: Exif 2.3 (JPEG)
Movies: MOV (Image data: H.264; Audio data: Linear PCM (2 channel monoaural))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 360
2) 3:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 424
3) 4:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 640 x 480
4) 1:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480
Movies:
[Digest Movie]
1280 x 720 (30 fps)
[Super Slow Motion Movie]
640 x 480*1 (120 fps)/320 x 240*1 (240 fps)
[Miniature Effect]
1280 x 720*2 / 640 x 480*2
[Other than the above]
1920 x 1080 (24 fps*3) / 1280 x 720 (30 fps*4) / 640 x 480 (30 fps*4)
*1 Playback frame rate is 30 fps. (29.97)
*2 Shooting: 6 fps / 3 fps / 1.5 fps, Playback: 30 fps. (29.97)
*3 Actual frame rate is 23.976 fps.
*4 Actual frame rate is 29.97 fps.
Image data
&bull; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&nbsp;*1 Playback frame rate is 29.97 fps.*2 Playback frame rate is 30 fps*3.*3 Actual frame rate is 23.976 fps.&bull; Files up to 4GB can be taken with continuous shooting.&bull; Super Slow Motion Movie: approx. 30 sec. one-time.&bull; The approximate number of videos recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Playback Modes File
Still Images and Movies:
Auto Rotate, Rotate, Search (Date, Movies, Still Images)
Still Images:
Single, Index (4-100 Thumbnails), Magnification (Approx. 2x-10x), Information Display, Overexposure Warning, Resume Playback, Red-Eye Correction, Photobook Set-up
Movies:
Normal Playback*1, Pause, Skip Backward*2, Previous Frame*3, Next Frame*3, Skip Forward*2
- Displays playback position and shooting time
*1 Audio settings available in 5 levels
*2 Approximately 4 seconds
*3 Rewind and Fast-forward are also available
Erase Modes
Single Image*, Erase All
- The image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).
* Movies can be erased individually.
Computer Interface
Hi-Speed USB (Dedicated connector (female) with unified type of digital, audio and video*1)
*1 mini-B compatible.
Video Out
N/A
Audio Out
N/A
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Source
Rechargeable Lithium-ion Battery NB-9L
Shooting Capacity
Normal: Approx. 200 shots
ECO Mode: Approx. 280 shots
Playback Time
Approx. 4 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.09 x 2.37 x 1.15 in. / 78.6 x 60.2 x 29.3mm
Weight
Approx. 6.14 oz. / 174g (Body only)
Approx. 6.88 oz. / 195g (CIPA Standard)All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
