Canon Support for PowerShot GOLF Digital Laser Rangefinder | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 06.13.24
File Size 142.00 B
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type Monocular Camera-equipped Telescopic Laser Rangefinder
Measurement Range Approximately 7.0 800 yds (6.4 732 m)
(Range may be limited by object measured or environment)
Measurement Accuracy Less than 100 yds (91 m) +/- 1.0 yd. (0.91 m)
100 yds. (91 m) or more +/- 2.0 yd. (1.83 m)
(Straight-line measurement, based on Canon testing standards)
Distance Display Increment 0.5 yds (0.5 m)
Measurement Speed Approx. 0.8 Sec.
Measurement Methods/Modes Slope-adjusted Measurement
Straight-line Distance
(with [SLOPE] set to [ON]: Horizontal distance +/- difference in elevation
with [SLOPE] set to [Off]: Playback function and image delete function are restricted)
Slope Sensor Built-in
Continuous Rangefinding Available (Holding down the measure button halfway fires the laser for approx. 8 sec. after which flagpole-locking detects the target of measurement)
Still Photo/Movie Recording Available (Selecting [Ranging+Photo] from the [Mode] menu enables still/video recording with rangefinder results superimposed over the image
Type 1/3-inch CMOS Sensor
Pixels EFFECTIVE: Up to approx. 11 megapixels TOTAL: approx 13.5 megapixels
Aspect Ratio 4:3 (Horizontal: Vertical)
Focal Length 51.0mm (equivalent to approx. 410mm (35mm equivalent))
Shooting Range Approx. 4.4 yd (approx. 4 m) to infinity
Digital Zoom Enables approx. 2X magnification
Telephoto Magnification When equivalent to approx. 410mm 6X
When equivalent to approx. 820mm 12X (using digital zoom)
F-Number f/3.9 (no aperture control)
Type Lens Shift System - 2-axis correction (pitch/yaw)
(Stabilization cannot be deactivated.)
Movie Digital IS Not Available
Compatible Media microSD / microSDHC / microSDXC memory cards
* UHS-I Compatible
Error Warnings Displayed in the viewfinder
Card formatting Normal (Logical) Formatting (low-level formatting not available)
No Card Warning Available
Shutter Release Without Card Not Supported
Image Recording Format Compliant with Design rule for Camera File System 2.0 and Exif 2.31
(Time difference information supported)
Folder Setting Folders Created Automatically
(selection of folders on cards not available)
File Name Settings Not supported
File Number Auto Reset
(when cards are replaced, the numbering is reset to start from 0001. If the new card already contains images the existing numbering is continued)
Format Container Format: MP4
Video: H.264 / MPEG-4 AVC
Audio: MPEG-4 AAC -LC (Stereo)
Quality Full HD 1920x1080 (Movie recording size not adjustable)
Lower image quality when recording at equivelant of approx. 820mm due to digital zoom.
Frame Rate When set to NTSC: 30 fps / 24 fps
When set to PAL: 25.00 fps
Maximum Recording Time per Movie 59 Seconds
Total recording Time Available 8 GB: Max 33 min.
32 GB: Max 132 min.
128 GB: Max 530 min.
Maximum File Size microSD FAT12/16: Max 2 GB
microSDHC FAT32: Max 4 GB
microSDXC exFAT: Unlimited
Card Performance Requirements SD Speed Class 6 or Higher
Video System NTSC/PAL
Recording Microphone Built-in Stereo Microphones
No external microphone IN terminal provided.
White Balance Auto
Type OLED Color Electronic Viewfinder
Size 0.39 Inch
Dot Count Width: 1024 Dots
Height: 768 Dots
Total: Approx. 2,360,000 Dots
Coverage Approx. 100% (With eyepoint of approx. 20 mm)
Brightness Adjustment Not supported
Electronic Viewfinder Refresh Rate -59.94 fps
Focusing Method Contrast Detection
Continuous AF Enable / Disable
AF is active during movie recording under all settings.
Eye Detection Not supported
AF Point Display Shown in the viewfinder when the shutter button is pressed halfway
Focus Confirmation (show in viewfinder) Green Frame: In Focus
Red Frame: Out of Focus
Shooting Mode Autoexposure Shooting (Shooting mode selection not available)
Metering Mode Center-weighted average metering (Metering mode cannot be changed)
ISO Speed Still and Movie recording: Controlled automatically (ISO 100-3200)
Exposure Compensation +/- 3 stops in 1/3-stop increments
Exposure Compensation Factors Shutter Speed, ISO Speed
Type (for still and movie recording) Electronic Shutter, using the image sesnor
Shutter Speed Controlled Automatically (1/8000 to 1/30 Sec.)
Drive Mode Single Shooting
Self-Timer Not Provided
Playback Methods In Electronic Viewfinder
On a computer or Smartphone
Movie Playback Play
Skip backward (approx. 4 sec.)
Previous frame
Next Frame
Skip Forward (approx. 4 sec.)
Erase Images Select and rease images / all images on card
Indicator Lamp Green Lit/Blinking: Accessing Card
Orange Lit: Charging in Progress
Orange Off: Charging Completed
Slope Function Lamp (Blue) Blinking: Straight-line distance
Off: Straight-line distance / Slope-adjusted distance
Display Device Shown in the electronic viewfinder
Description Rangefinding
Shooting
Playback
Function Settings
Display languages English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukrainian, Norwegian, Swedish, Spanish, Russian, Turkish, Simplified Chinese, Traditional Chinese, Korean, Japanese
Firmware Updates Available
Terminal Type USB Type-C
Transmission Equivalent to Hi-Speed USB (USB 2.0)
Applications For charging the built-in battery and powering the rangefinder
* Recognized as a USB device when connected to computers; images on the rangefinder memory card can be browsed and imported.
Wi-Fi Connectivity Not Provided
Bluetooth Connectivity Not Provided
Time Zone Settings Honolulu, Anchorage, Los Angeles, Denver, Chicago, New York, Caracas, New Foundland, São Paulo, Fernando de Noronha, Azores, London, Paris, Cairo, Moscow, Tehran, Dubai, Kabul, Karachi, Delhi, Kathmandu, Dacca, Yangon, Bangkok, Beijing/Singapore, Tokyo/Seoul, Adelaide, Sydney, Solomon Islands, Wellington, Chatham Islands, Samoa
Time Difference Setting Available (in 15-minute Increments)
Daylight saving time Available
Date/Time back-up Battery Same as battery that powers the rangefinder
Battery Built-in rechargeable Lithium-ion battery
Rated voltage/Capacity 3.7 V, 1000 mAH
Recharge Cycles Approx. 300 charging/usage cycles
USB Power Source 5 V 0.5 A or more (5 V 1 A or more recommended)
Charging over USB Supported
Power over USB Supported
USB Charging Time Approx. 2 hr. 30 min.
* The charging time required and the amount charged vary depending on ambient temperature and remaining capacity.
Number of Still Photos that can be taken Approx. 200 shots
* With a new, fully charged battery at room temperature (73ºF)
Time Available for Movie Recording Approx. 1 hr. 10 min.
Time Available for Image Display Approx. 1 hr. 40 min.
Battery Check Battery level automatically checked and indicated in a 4-level display when the unit is powered on.
Power Saving Function Auto Power off: 5 sec. / 10 sec. / 15 sec.
Viewfinder off: 1 min. / 3 min.
Body Material Polycarbonate and Stainless Steel
Exterior Color Black
Water Resistance Equivalent to IPX4
* Not dustproof
Tripod Socket Not Provided
Dimensions (W) x (H) x (D) Approx. 1.2 x 2.3 x 3.6 in. (31.0 x 58.9 x 91.2 mm)
Weight (including memory card) Approx. 5.3 oz (151 g)
Usable Temperature 32-104ºF (0-40ºC)
Usable Humidity 10-90%
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
