Canon Support for PowerShot G6 | Canon U.S.A., Inc.
PowerShot G6
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 3.66 MB
Date 04.01.07
File Size 1.80 MB
Date 04.01.07
File Size 524.16 KB
Date 04.01.07
File Size 1.60 MB
Date 04.01.07
File Size 7.38 MB
Date 04.01.07
File Size 10.51 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 4.0x Optical/4.1x Digital/16x Combined Zoom
Image Capture Device
Type 1/1.8 inch type Charge-Coupled Device (CCD)
Total Pixels Approx. 7.4 Million
Effective Pixels Approx. 7.1 Million
Lens
Focal Length 7.2-28.8mm, f/2.0-3.0 zoom Lens (35mm film equivalent: 35 - 140mm)
Digital Zoom 4.1x
Focusing Range Normal AF: 50cm/20 in. Infinity Macro AF: 5-50cm/2.0-20 in. (WIDE), 15-50cm/6-20 in. (TELE)-Super Macro: 5cm/2 in. (WIDE)
Autofocus System 9-point AiAF (Automatic Focus Point Selection)/1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.0 inch low-temperature polycrystalline silicon TFT color LCD (with vari-angle function)
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.0-8.0 (W), f/3.0-8.0 (T)
Shutter Speed 1-1/2000 sec. Slow shutter of 1.3 sec. and more operates with noise reduction
Exposure Control
Sensitivity AUTO*, ISO 50/100/200/400 equivalent *Camera automatically sets the optimum speed.
Light Metering Method Evaluative/Center-weighted average/Spot* *Metering frame with Spot mode is center fixed.
Exposure Control Method Program AE, Shutter-priority AE, Aperture-Priority AE or Manual
Exposure Compensation +/- 2 EV in 1/3 stop increments
AE Lock Available
ND Filter Built-in
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H or Flash), or Custom White Balance (2 positions)
Flash
Built-in Flash Operation Modes: Auto On/Off, Red-Eye Reduction On/Off
Flash Range WIDE: 70cm-5.0m/2.3-16 ft. TELE: 70cm-4.0m/2.3-13.1 ft.(Sensitivity setting: ISO 100 equivalent)
Recycling Time Approx. 10 sec. or less
Terminals for External Flash Sync-terminals at accessory shoe
Flash Exposure Compensation +/- 2.0 EV in 1/3 stop increments
Shooting Specifications
Shooting Modes Auto, Creative Zone (P, Av, Tv, M), Image Zone (Portrait, Landscape, Night Scene, Stitch Assist, Movie), Custom 1, Custom 2
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down.
Wireless Control Available (playback is available too)
Continuous Shooting High Speed approx. 2.0 fps, Normal Speed approx. 1.2 fps
Image Storage
Storage Media Compact Flash (CF) Card Type I or Type II
Print Order Format Design rule for camera file system, Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Exif 2.2 (JPEG)
JPEG Compression Mode SuperFine, Fine, Normal
Number of Recording Pixels Still Image: 3,072x2,304 (RAW/Large), 2,592x1,944 (Medium 1), 2,048x1,536 (Medium 2), 1,600x1,200 (Medium 3), 640x480 (Small)
Number of Recordable Images
Image data These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.&#160;
Time of Recordable Movies
Movie data Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual 640 x 480 movie clips are limited to 30 seconds maximum per clip; individual 320 x 240 and 160 x 120 movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnails), Magnification (Approx. 2.0x to 10x), Slide Show or Movie Magnified, Auto rotate, Rotation, Histogram, Sound memos (up to 60 sec.), Auto Play
Erasing Specifications
Erase Modes Still Images: Single Image, All Images Movie: Part of Movie, All Movie
Interfaces
Computer Interface Universal Serial Bus (USB) mini-B
Video Out NTSC or PAL
Audio Out Monaural
Other CF card slot (accepts Type I & Type II cards). Direct connection to Canon CP Printers and select BJ Photo Printers (no computer required)
Power Supply 1. Rechargeable Lithium-ion battery (type: BP-511A, BP-511, BP-512 or BP-514)
2. AC adapter (type: CA-560)
3. Car battery adapter (type: CR-560)
4. Coin-type secondary Lithium battery (CR-2025)BP-511A: LCD On - Approx. 300; LCD Off - Approx. 900Approx. 400 minutes (Under Canon's standard conditions with fully charged battery) Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23&deg C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. Canon's standard conditions of measuring playback time are as follows: Normal temperature (23&deg C). Repeat playback automatically at a speed of 1 image per 5 seconds.
Power Source 1. Rechargeable Lithium-ion battery (type: BP-511A, BP-511, BP-512 or BP-514)
Shooting Capacity BP-511A: LCD On - Approx. 300; LCD Off - Approx. 900
Playback Time Approx. 400 minutes (Under Canon's standard conditions with fully charged battery) Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23&deg C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot. Canon's standard conditions of measuring playback time are as follows: Normal temperature (23&deg C). Repeat playback automatically at a speed of 1 image per 5 seconds.
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 4.1 x 2.9 x 2.9 in./104.9 x 72.8 x 73.1mm (Excluding protrusions)
Weight Approx. 13.4 oz./380g (camera body only)
14 languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified Chinese, Japanese, Russian and Portuguese)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
