Canon Support for PowerShot G5 | Canon U.S.A., Inc.
PowerShot G5
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 04.01.07
File Size 4.49 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 3.50 MB
Date 04.01.07
File Size 1.56 MB
Date 11.14.07
File Size 976.56 KB
Date 11.14.07
File Size 427.25 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 4x Optical/ 4x Digital/ 16x Combined Zoom
Image Capture Device
Type 1/1.8 inch Charge-Coupled Device (CCD)
Total Pixels Approx. 5.0 million
Lens
Focal Length 7.2-28.8mm, f/2.0-3.0 zoom Lens(35mm film equivalent: 35-140mm)
Digital Zoom 4.0x (Maximum 16x digital zoom is available when combined with optical zoom)
Focusing Range Normal AF: 20 in. - infinity/50cm - infinity
Macro AF: 2 - 20 in./5 - 50cm (WIDE), 6 - 20 in./15 - 50cm (TELE)
Autofocus System 1-point AF (Center Point or FlexiZone AF is available according to shooting mode)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8 inch low temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels [521 (H) x 218 (V)]
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.0-8.0 (W), f/3.0-8.0 (T)
Shutter Speed 15-1/2,000 sec.
Slow shutter of 1.3 sec. and more operates with noise reduction
Exposure Control
Sensitivity AUTO/ ISO 50/ 100/ 200/ 400 equivalent
Light Metering Method Evaluation/ Center-weighted average/ Spot
Exposure Control Method Program AE, Shutter-Priority AE, Aperture-Priority AE, Manual
AE Lock Available
ND Filter Built-in
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, or Flash), or Custom (2 positions)
Flash
Built-in Flash Operation Modes: Auto, Red-Eye Reduction On/ Off
Flash Range WIDE: 2.3-16.4 ft. (70cm-5.0m)TELE: 2.3-13 ft. (70cm-4.0m)(When sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or shorter
Terminals for External Flash Sync-terminals at accessory shoe. Automatic E-TTL Flash is possible with EX-Series Speedlites: Canon Speedlite 550EX, 420EX, 220EX, and Macro Ring Lite MR-14EX and Macro Twin Lite MT-24EX.
Flash Exposure Compensation +/- 2.0EV (at every 1/3-stop)
Shooting Specifications
Shooting Modes Auto, Creative (P, Av, Tv, M, Custom 1, Custom 2), Image (Portrait, Landscape, Night Scene, Stitch Assist, Movie)
Photo Effects Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Operates with approx. 2 sec. or approx 10 sec. count-down
Wireless Control Available (playback is available too)
Continuous Shooting High-Speed: Approx. 2.0 images/sec., Normal: Approx. 1.5 images/sec.(at Large/ Fine mode and LCD viewfinder is OFF)
Image Storage
Storage Media CompactFlash (CF) Card Type I or Type II
Print Order Format Digital Print Order Format (DPOF) Version 1.1
Image Recording Format Still Image: JPEG (Exif 2.2 compliant)
JPEG Compression Mode SuperFine, Fine or Normal
Number of Recording Pixels Still image: Large: 2,592 x 1,944, Medium 1: 1,600 x 1,200, Medium 2: 1,024 x 768, Small: 640 x 480
Movie: 320 x 240 or 160 x 120
Number of Recordable Images
Image data &#160;These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data &#160;Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumbnail images), Magnification (approx. 2.0x to 10x), Slide Show or Movie
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB) (mini-B jack)
Video Out Audio/Video Output (Video:NTSC or PAL selectable monaural audio)
Other CF card slot (accept type I and type II cards). Direct connection to Canon CP Printer and select BJ Printers (no computer required)
Power Supply 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512) 2. AC adapter (type: CA-560)3. Car battery adapter (type: CR-560)4. Coin-type secondary Lithium battery (CR-2025)Approx. 450 images (under Canon's standard conditions*1with full-charged battery)Approx. 360 minutes (under Canon's standard conditions*2 with full-charged battery)
Power Source 1. Rechargeable Lithium-ion battery (type: BP-511 or BP-512) 2. AC adapter (type: CA-560)3. Car battery adapter (type: CR-560)4. Coin-type secondary Lithium battery (CR-2025)
Shooting Capacity Approx. 450 images (under Canon's standard conditions*1with full-charged battery)
Playback Time Approx. 360 minutes (under Canon's standard conditions*2 with full-charged battery)
Physical Specifications
Operating Temperature 32-104&deg;F (0-40&deg;C)
Operating Humidity 10-90%
Dimensions (W x H x D) 4.76 x 2.91 x 2.75 in./121.0 x 73.9 x 69.9mm (Excluding protrusions)
Weight Approx. 14.5 oz./410g (camera body only)
Computer System Requirements
Mac Requirements Computer Model: Power Macintosh, PowerBook, eMac, iMac or iBook. CD-ROM drive required for installing software.
OS: OS 9.0-9.2 or OSX 10.1-10.2
CPU: PowerPC
Interface: USB (Models with Apple genuine USB interface only).
PC Requirements Computer Model: IBM PC/AT compatible. CD-ROM drive required for installing software.
OS: Microsoft Windows 98 (including Second Edition)/ME/2000/XP
CPU: Pentium 150MHz or higher processor (Windows 98/ME/2000), Pentium 300MHz or higher processor (Windows XP)
Interface: USB (Windows 98/ME/2000/XP pre-install model only)
Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (23 &deg;C). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 second intervals. Use flash every 4th shot. Turn camera off and on every 8th shot.
Canon's standard conditions of measuring playback time are as follows: Normal temperature (23 &deg;C). Repeat playback automatically at a speed of 1 image per 5 seconds.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
