Canon Support for PowerShot G3 X | Canon U.S.A., Inc.
PowerShot G3 X
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
20.2 Megapixel*, 1.0-inch CMOS (sensor aspect ratio: 3:2)
*Image processing may cause a decrease in the number of pixels.
Total Pixels
Approx. 20.9 Megapixels
Effective Pixels
Approx. 20.2 Megapixels
Focal Length
8.8 (W) - 220 (T) mm (35mm film equivalent: 24 - 600mm)
Digital Zoom
4x
Focusing Range
Auto/Manual: 2.0 in. (5cm) - infinity (W), 2.8 ft. (85cm) - infinity (T)
Normal: 2.0 in. (5cm) - infinity (W), 2.8 ft. (85cm) - infinity (T)
Macro: 2.0 in. - 1.6 ft. (5-50cm) (W)
Autofocus System
TTL Autofocus (Continuous, Servo AF), Manual Focus
Optical Viewfinder
Supports Electronic Viewfinder EVF-DC1 (optional accessory)
LCD Monitor
3.2-type TFT color liquid crystal
LCD Pixels
Approx. 1.62 million dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W), f/5.6 (T)
Shutter Speed
1-1/2000 sec. 15-1/2000 sec. (in Tv & M mode) BULB, 30, 25, 20 (in M mode only)
Sensitivity
Auto, ISO 125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/ 4000/5000/6400 (When in Auto mode)
Max. ISO Speed 12800 (When in P mode)
Light Metering Method
Evaluative*, Center Weighted Average, Spot**
* Facial brightness is evaluated (Face Detect AE) in Face Detect.
** Fixed to Center, linked to AF frame
Exposure Control Method
Manual Exposure, Program Shift, Safety Shift, AE Lock
Exposure Compensation
Still Images: &plusmn;3 stops in 1/3-stop increments Videos: &plusmn;3 stops in 1/3-stop increments (not available during shooting)
White Balance Control
Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Custom1-2
Built-in Flash
Auto, On, Slow Synchro, Off
Facial brightness is also evaluated in Face Detect.
Flash Range
2.0 (60cm) - 22 ft. (6.8m) (W), 2.8 ft. (85cm) - 10 ft. (3.1m) (T)
Image brightness may diminish depending on the shooting distance.
Recycling Time
10 sec. or less (battery voltage: 7.4 V)
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop increments
Shooting Modes
C1, C2, M, Av, Tv, P, Auto, Hybrid Auto, Creative Shot*1, SCN*2, Creative Filters*3, Movie*4
Shooting movies is possible with the movie button
*1 Portrait, Smart Shutter*4, Star*5, Handheld Night Scene, Snow, Fireworks*2 High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Background Defocus, Soft Focus, Monochrome, Super Vivid, Poster Effect*3 Standard Movie, Short Clip, Manual Movie, iFrame Movie *4 Smile, Wink Self-Timer, Face Self-Timer*5 Star Nightscape, Star Trails, Star Time-Lapse Movie
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color**Adjustment of contrast sharpness, saturation, red, green, blue and skin tone are available.
Self Timer
Off, Approx. 2 sec. delay, Approx. 10 sec. delay, Custom*
*Delay time (0-15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
1) Normal in Auto/P modes: Approx. 5.9 shots/sec. (When set to One-Shot)
2) AF in P mode: Approx. 3.2 shots/sec. (When set to Servo AF)
Storage Media
SD/SDHC/SDXC and UHS-I Memory Cards
File Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Superfine / Fine
JPEG Compression Mode
Still Image: Exif 2.3 (DCF 2.0), RAW (Canon original: 14-bit, CR2)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo))
Number of Recording Pixels
Still Images:
1) 16:9 - Large: 5472 x 3080; Medium 1: 4320 x 2432; Medium 2: 1920 x 1080; Small: 720 x 408;
2) 3:2 - Large: 5472 x 3648, Medium 1: 4320 x 2880, Medium 2: 2304 x 1536, Small: 720 x 480
3) 4:3 - Large: 4864 x 3648, Medium 1: 3840 x 2880, Medium 2: 2048 x 1536, Small: 640 x 480
4) 1:1 - Large: 3648 x 3648; Medium 1: 2880 x 2880; Medium 2: 1536 x 1536; Small: 480 x 480
RAW:1) 16:9 - 5472 x 3080
2) 3:2 - 5472 x 3648
3) 4:3 - 4864 x 3648
4) 1:1 - 3648 x 3648
Videos:
Full HD 1920 x 1080: 59.94 fps
Full HD iFrame: 1920 x 1080: 29.97 fps
Full HD Star Time-Lapse Movie: 1920 x 1080: 14.985 fps / 29.97 fps
HD 1280 x 720: 29.97 fps
640 x 480: 29.97 fps
Miniature Effect: 1280 x 720: 6 fps (5x speed) / 3 fps (10x speed) / 1.5 fps (20x speed)
Miniature Effect: 640 x 480: 6 fps (5x speed) / 3 fps (10x speed) / 1.5 fps (20x speed)
Short Clip: 1280 x 720: 29.97 fps
Image data
Note: SF=Superfine F=Fine
&#8226; The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly.
Movie data
&#42;1 Using an SD Speed Class 10 / UHS-I compatible memory card.
&#8226; Recording stops automatically once the file size reaches 4 GB or the memory card becomes full.
&#8226; Recording may stop unexpectedly if a memory card with a low Speed Class is used.
&#42;2 Actual frame rate is 23.976 fps.
&#42;3 Recording time setting can be selected from 4&#8211;6 sec.
Playback Modes File
Playback Function Menu:
Rotate, Protect, Favorites, Image Search, Resize, Cropping
Playback Menu:
Album Playback, List/Play Digest Movies, Slideshow, Erase, Protect, Rotate, Favorites, Photobook Set-up, i-Contrast, Red-Eye Correction, Cropping, Resize, My Colors, Face ID Info, Transition Effect/Transition, Index Effect, Scroll Display, Group Images, Auto Rotate, Resume, Set Touch Actions, Set Shortcut button, Print Settings
Erase Modes
Select Image, Select Range, Select All Images The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).Using the Movie editing function, sections of the movie can be deleted. RAW + JPEG images can be erased individually.
Other
SD memory card slot; direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-10L, AC Adapter Kit CA-PS700 (ACK-DC80)
Shooting Capacity
Approx. 300 shots with Screen On
Approx. 240 shots with Viewfinder On and displayed in EVF-DC1
Approx. 410 shots with ECO Mode
Playback Time
Approx. 6 hr.
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.85 x 3.01 x 4.15 in. / 123.3 x 76.5 x 105.3mm
Weight
1.62 lb. / 733g (including battery and memory card)
1.52 lb. / 690g (camera body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Firmware Notice: PowerShot G3 X: Firmware Version 1.2.0.0
Advisory Type
Date 04.14.20
Title Canon Support | Firmware Notice: PowerShot G3 X: Firmware Version 1.1.0.0
Advisory Type
Date 02.27.17
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
