Canon Support for PowerShot G1 | Canon U.S.A., Inc.
PowerShot G1
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 01.01.02
File Size 13.35 MB
Date 04.01.07
File Size 5.24 MB
Date 04.01.07
File Size 3.84 MB
Date 04.01.07
File Size 3.59 MB
Date 04.01.07
File Size 3.31 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact Digital Still Camera with Built-in Flash and 3x Optical Zoom Lens. Lens and Flash accessories available.
Image Capture Device
Type 1/1.8-inch Charge-Coupled Device (CCD)
Total Pixels Approx. 3.34 million
Effective Pixels Approx. 3.24 million
Lens
Focal Length 7(wide-angle) - 21(telephoto) mm (35mm film equivalent: 34 - 102mm)
Digital Zoom Max 12x (when combined with optical zoom)
Focusing Range Normal AF: 70cm (2.3 ft.) - infinity
Macro AF: 6cm (0.2 ft.) (wide-angle) / 20cm (0.7 ft.) (telephoto) - 70cm (2.3 ft.)
Manual focus: 6cm (0.2 ft.) (wide-angle) / 20cm (0.7 ft.) (telephoto) - infinity
Autofocus System TTL autofocus (Continuous or Single); AF lock and Manual focus are available.
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8-inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels 113.578 dot (521 x 218)
LCD Coverage 97%
Aperture and Shutter
Maximum Aperture f/2.0 (wide-angle) - f/2.5 (telephoto)
Shutter Speed 8 -1/1,000 sec.
8 sec. shutter is available in Shutter Priority mode or Manual mode.
High speed shutter from 1/500 to 1/1,000 sec. are available only at F8 setting.
Slow shutter of 1.3 sec. and more operates with noise reduction.
Exposure Control
Sensitivity Auto, ISO 50, 100, 200 and 400 equivalent (At Auto setting, camera automatically adjusts sensitivity in the range of from ISO 50 to 100 equivalent).
Light Metering Method Center-weighted average metering or Spot metering
Exposure Control Method Program AE, Shutter priority AE, Aperture priority AE or Manual exposure control
AE lock is available.
Exposure Compensation +/- 2.0EV (at every 1/3-stop)Auto Exposure Bracketing (AEB) is available.
White Balance
White Balance Control TTL auto white balance, pre-set white balance (available settings: Daylight, Cloudy, Tungsten, Fluorescent or Flash) or Custom white balance
Flash
Built-in Flash Operation modes: Auto, Red-eye reduction auto, Red-eye reduction ON, ON or OFF
Flash Range 0.7m (2.3 ft.) - 4.5m (14.76 ft.) (W) / 0.7m (2.3 ft.) - 3.6m (11.8 ft.) (T) (When sensitivity is set to ISO100 equivalent)
Recycling Time Approx. 5 sec.
Terminals for External Flash Sync-terminals at accessory shoe
Use of following external flashes are recommended: Canon Speedlite 220EX, 380EX, 420EX and 550EX
Flash Exposure Compensation +/- 2.0EV (at every 1/3-stop)
Shooting Specifications
Shooting Modes Auto, Creative zone: Program, Shutter priority, Aperture priority and Manual, Image zone: Pan-focus, Portrait, Landscape, Night scene, Black & White, Stitch assist and Movie
Self Timer Operates with approx. 10 seconds countdown.
Wireless Control Shooting and playback are available (Wireless controller is included in the camera kit).When shooting, image is captured 2 seconds after shutter release operation.
Continuous Shooting Approx. 1.7 image/sec.(at Large/Fine mode and LCD viewfinder is OFF)
Image Storage
Storage Media CompactFlash (CF) card (Type I or Type II)
File Format Design rule for Camera File system (DCF*1)
Print Order Format Digital Print Order Format (DPOF)
Image Recording Format Still image: JPEG or CCD-RAW
Movie: AVI (Image data: Motion JPEG, Audio data: WAVE [monaural]
JPEG Compression Mode Super Fine, Fine or Normal
Number of Recording Pixels Still image: Large: 2,048 x 1,536, Middle: 1,024 x 768, Small: 640 x 480
Movie: 320 x 240, at speed of 15 frames/sec., up to approx. 30 sec./shot
Number of Recordable Images
Image data These figures reflect standard shooting conditions established by Canon.
Actual totals may vary according to the subject, shooting conditions and shooting mode.
Time of Recordable Movies
Movie data Individual movie clips are limited to a maximum of 30 seconds each. Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings.
Playback Specifications
Playback Modes File Single, Multi (9 thumbnail images), Magnification (approx. 2.5x or 5x on built-in LCD monitor) or Slide show
Erasing Specifications
Erase Modes Single Image, All Images
Interfaces
Computer Interface Universal Serial Bus (USB), RS-232C/RS-422
Video Out Audio/Video Output (NTSC or PAL selectable, monaural audio)
Other CF card slot (complied with CF Type II standard).
Power Supply 1. Rechargeable Lithium-ion battery (type: BP-511) (included in the camera kit)
2. AC adapter (type: CA-560) (included in the camera kit)
3. Car battery adapter (type: CR-560) (optional)Approx. 260 images (under Canon's standard conditions*2 with full-charged battery)Approx. 160 minutes (under Canon's standard conditions*3 with full-charged battery)
Power Source 1. Rechargeable Lithium-ion battery (type: BP-511) (included in the camera kit)
Shooting Capacity Approx. 260 images (under Canon's standard conditions*2 with full-charged battery)
Playback Time Approx. 160 minutes (under Canon's standard conditions*3 with full-charged battery)
Physical Specifications
Operating Temperature 32-104&deg;F (0-40&deg;C)
Operating Humidity 10-90%
Dimensions (W x H x D) 4.7 x 3.0 x 2.5 in. (119.7 x 76.8 x 63.8 mm) (excluding protruding parts)
Weight Approx. 14.8 oz. (camera body only)
Computer System Requirements
Mac Requirements Hardware: Power Macintosh, PowerBook, iMac or iBook
OS: Mac OS 8.1 through 9.0.4, Quicktime 3.0 or higher(QuickTime 4.1 is in the CD-ROM "DIGITAL CAMERA Solution Disk" included with the PowerShot G1 standard kit) (Please see our Mac OS X Compatibility Statement.)
CPU: Power PC
Interface: USB: Cable connection via camera's USB port is limited to genuine Apple Computer brand models with a built-in USB interface (Power Macintosh NEW G3/G4, PowerBook G3, iMac, iBook). iMac computers running OS 8.1 require installation of "iMac Update 1.0" and "iMac Firmware Update 1.0" or higher. RS-422 Serial: Requires compatible Power Macintosh with built-in printer port or modem port.
RAM: 20MB or more of application memory
PC Requirements Hardware: IBM PC/AT compatible
OS: Windows 95/98 (including the Second Edition), Windows NT 4.0 (Service Pack 3 or higher required), Windows 2000, Windows ME (Please see our Windows XP Compatibility Statement.)
CPU: Pentium 133 MHz or better
Interface: USB: Cable connection via camera's USB port is limited to pre-installed Windows 98, Windows 2000 and pre-installed or upgraded Windows ME systems. RS-232C: Serial or COM port.
RAM: 32MB or more (Windows 95/98), 64MB or more (Windows NT 4.0/Windows 2000/Windows ME)
*1 "DCF" is an abbreviation of "Design rule for Camera File system" standardized by Japan Electronic Industry Development Association (JEIDA).
*2 Canon's standard conditions of measuring shooting capacity are as follows: Normal temperature (73 degrees Fahrenheit). LCD viewfinder is ON. Shoot images at wide angle end and at telephoto end alternately with 20 seconds intervals. Use flash at every 4-time shootings. Turn camera off and on at every 8-time shootings.
*3 Canon's standard conditions of measuring playback time are as follows: Normal temperature (73 degrees Fahrenheit). Repeat playback automatically at a speed of 1 image per 5 seconds.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
