Canon Support for PowerShot G1 X | Canon U.S.A., Inc.
PowerShot G1 X
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type
14.3 Megapixels, 1.5-inch CMOS
Total Pixels
Approx. 15.0 Megapixels
Effective Pixels
Approx. 14.3 Megapixels
Focal Length
15.1 (W) - 60.4mm (T) (35mm film equivalent: 28 (W) - 112mm (T)
Optical Zoom
4x
Digital Zoom
4x
Focusing Range
Normal: 1.3 ft. (40cm) - infinity (W), 4.3 ft. (1.3m) - infinity (T)
Auto: 7.9 in. (20cm) - infinity (W), 2.8 ft. (85cm) - infinity (T)
Macro: 7.9 in. - 2.3 ft. (20-70cm) (W), 2.8 ft. - 5.2 ft. (85cm - 1.6m) (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
Real-image zoom viewfinder
LCD Monitor
3.0-inch TFT color LCD (Vari-angle type with wide-viewing angle)
LCD Pixels
Approx. 922,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.8 (W) - f/5.8 (T)
- The following f/numbers are available in Av or M:
W: f/2.8, 3.2, 3.5, 4.0, 4.5, 5.0, 5.6, 6.3, 7.1, 8.0, 9.0, 10, 11, 13, 14, 16
T: f/5.8, 6.3, 7.1, 8.0, 9.0, 10, 11, 13, 14, 16
- Differs depending on the zoom position
Shutter Speed
1-1/4000 sec.
60-1/4000 sec. (Total shutter speed range)
- Shutter speed range differs depending on the shooting mode
Shutter speeds available in Tv and M:
60, 50, 40, 30, 25, 20, 15, 13, 10, 8, 6, 5, 4, 3.2, 2.5, 2, 1.6, 1.3, 1, 0.8, 0.6, 0.5, 0.4, 0.3, 1/4, 1/5, 1/6, 1/8, 1/10, 1/13, 1/15, 1/20, 1/25, 1/30, 1/40, 1/50, 1/60, 1/80, 1/100, 1/125, 1/160, 1/200, 1/250, 1/320, 1/400, 1/500, 1/640, 1/800, 1/1000, 1/1250, 1/1600, 1/2000,1/2500, 1/3200, 1/4000 (Units: sec.)
Sensitivity
Auto*, ISO 100/125/160/200/250/320/400/500/640/800/1000/1250/1600/2000/2500/3200/4000/5000/6400/8000/10000/12800 (When in P mode)*Optimal ISO speed is automatically set depending on the shooting mode.
Light Metering Method
Evaluative*1, Center-weighted average, Spot*2*1 Facial brightness is evaluated (Face Detect AE) in Face Detect.*2 Fixed to Center, linked to AF frame
Exposure Control Method
AE Lock (not available when shooting movies)
Exposure Compensation
+/-3 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Flash, Underwater, Custom1, Custom2
*Facial color is evaluated in Face AiAF (Face Detect WB). Adjusts the white balance separately for the main subject and the background when the flash fires.
Built-in Flash
Auto, On, Slow Synchro, Off - Facial brightness is also evaluated in Face Detect
Flash Range
1.6-23 ft. (W), 3.3-10.2 ft. (T) (50cm-7.0m (W), 1.0-3.1m (T))- Image brightness may diminish depending on the shooting distance.
Recycling Time
5.0 seconds or less (battery voltage: 7.4 V)
Flash Exposure Compensation
+/-2 stops in 1/3-stop increments
Shooting Modes
C1, C2, M, Av, Tv, P, Auto*1, SCN*2, Creative Filters*3, Movie*4
- Shooting movies is possible with the movie button
*1 Smart Auto also available for movies
*2 Movie Digest, Portrait, Landscape, Kids & Pets, Sports, Smart Shutter*5, High-Speed Burst HQ, Handheld Night Scene, Beach, Underwater, Foliage,Snow, Fireworks, Stitch Assist
*3 High Dynamic Range, Nostalgic, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap
*4 Standard, iFrame Movie
*5 Smile, Wink Self-timer, Face Self-timer
Photo Effects
My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color*
* Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available.- Not available in RAW and RAW+JPEG
Self Timer
Approx. 10-sec. delay, Approx. 2-sec. delay, Custom*
* Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1-10 shots (in one-shot increments)) can be specified.
Wireless Control
Not available
Continuous Shooting
Normal: Approx. 1.9 shots/sec. (in P mode), Approx. 4.5 shots/sec. (in High-speed Burst HQ mode)*
AF: Approx. 0.7 shots/sec. (in P mode)
LV: Approx. 0.7 shots/sec. (in P mode)
- Under conditions where the flash does not fire automatically.
- Differs depending on the zoom position.
* Max. of 6 continuous shots per burst
Storage Media
SD Memory Card, SDHC Memory Card, SDXC Memory Card
File Format
Design rule for Camera File system, DPOF (Version 1.1) compliant
Image Recording Format
Normal, Fine, RAW
JPEG Compression Mode
Still Image: Exif 2.3 JPEG, RAW (14 bit, CR2 (Canon Original))Video: MOV (Image data: H.264; Audio data: Linear PCM (2 channel stereo))Videos: MOV (Image data: H.264, Audio data: Linear PCM (Stereo))
Number of Recording Pixels
Still Images:[16:9]Large: 4352 x 2448, Medium 1: 3072 x 1728,Medium 2: 1920 x 1080, Small: 640 x 360
[3:2]Large: 4352 x 2904, Medium 1: 3072 x 2048,Medium 2: 1600 x 1064, Small: 640 x 424
[4:3]Large: 4352 x 3264, Medium 1: 3072 x 2304,Medium 2: 1600 x 1200, Small: 640 x 480RAW: 4352 x 3264
[1:1]Large: 3264 x 3264, Medium 1: 2304 x 2304,Medium 2: 1200 x 1200, Small: 480 x 480
[4:5]Large: 2608 x 3264, Medium 1: 1840 x 2304,Medium 2: 960 x 1200, Small: 384 x 480
Videos:[iFrame Movie]1280 x 720 (30 fps*1)
[Miniature Effect]1280 x 720*2 / 640 x 480*2
[Other than the above*3]1920 x 1080 (24 fps*4), 1280 x 720 (30 fps*1) /640 x 480 (30 fps*1)
*1 Actual frame rate is 29.97 fps.*2 Shooting: 6 fps, 3 fps, 1.5 fps Playback: 30 fps*1*3 Movies made in Movie Digest mode: 640 x 480 (30 fps*1) only.*4 Actual frame rate is 23.976 fps.
Image data
Note: N=Normal / F=Fine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Movie data
Playback Modes File
Still Images & Movies:Auto Rotate, Transition Effects (Off, Scroll, Slide, Fade), Scroll Display, Rotate, Favorites, My Category, Search Jump (Favorites*1, Date*1, My Category*2, Still Images/Movies/Movie Digest, Jump 10 Images*1, Jump 100 Images*1), Smart Shuffle, Group Playback, Movie Digest, Filtered Playback, Slideshow
*1 Can also be controlled with Front Dial*2 No category also selectable
Still Images:Single, Index, Magnification (Approx. 2x-10x), Thumbnails (4-100), Information Display, Histogram, Overexposure Warning, Resume Playback, Red-Eye Correction, i-Contrast, Trimming, Resize, My Colors
Movies:Normal Playback, Slow Motion, Skip Backward, Previous Frame, Next Frame, Skip Forward, Resume Playback, Delete Unwanted Portions of a Clip
Erase Modes
Select*1, Select Range, Select All Images*2
- The image data in memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased).
- RAW+JPEG images can be erased individually. *1 Movies can be erased individually.*2 When images have been selected in filtered playback, only those images will be played back.
Computer Interface
Hi-Speed USB 2.0 (Dedicated connector (female) with unified type of digital, audio and video*1)
*1 mini-B compatible
Video Out
Analog: NTSC or PAL, Digital: HDMI (HDMI mini connector)
Audio Out
Stereo
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed Cable
Power Source
1. Rechargeable Lithium-ion Battery Pack NB-10L
2. Compact Power Adapter CA-PS700 (included with AC Adapter Kit ACK-DC80)
Shooting Capacity
LCD Monitor on: Approx. 250 shotsLCD Monitor off: Approx. 700 shotsApprox: 310 shots when in Quick Shot mode (LCD monitor on)
Playback Time
Approx. 7 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
4.60 x 3.17 x 2.55 in. / 116.7 x 80.5 x 64.7mm
Weight
Approx. 17.3 oz. / 492g (Camera only)
Approx. 19.0 oz. / 534g (Including the battery and memory card)27 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi, and Hindi.)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
