Canon Support for PowerShot ELPH 190 IS | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type
20.0 Megapixel, 1/2.3-inch CCD
Total Pixels
Approx. 20.5 Megapixels
Effective Pixels
Approx. 20.0 Megapixels*
* Image processing may cause a decrease in the number of pixels.
Focal Length
4.3 (W) - 43.0 (T) mm (35mm film equivalent: 24-240mm)
Optical Zoom
10x
Digital Zoom
4x
Focusing Range
Normal: 2.0 in. (5.0cm) - infinity (W), 3.3 ft. (1.0m) - infinity (T)
Auto: 0.4 in. (1.0cm) - infinity (W), 3.3 ft. (1.0m) - infinity (T)
Macro: 0.4 in. - 1.6 ft. (1-50cm) (W)
Infinity: 9.8 ft. (3.0m) - infinity (W), 9.8 ft. (3.0m) - infinity (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
Not available
LCD Monitor
2.7-inch TFT Color LCD with wide viewing angle (4:3)
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/3.0 (W), f/6.9 (T)
Shutter Speed
1-1/2000 sec.
15-1 sec. (in Long Shutter Mode)
Sensitivity
Auto, ISO 100-1600
Light Metering Method
Evaluative, Center Weighted Average, Spot
Exposure Compensation
Still Images: ±2 stops in 1/3-stop increments
White Balance Control
Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Built-in Flash
Auto, On, Slow Synchro, Off
Flash Range
1.6-13.0 ft. (W), 3.3-6.6 ft. (T)
50.0cm - 4.0m (W), 1.0-2.0m (T)
Shooting Modes
P, Auto, Portrait, Face Self-Timer, Low Light, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Fireworks, Long Shutter
Self Timer
Off / 2 sec. / 10 sec. / Custom
Wireless Control
Built-in Wi-Fi&reg; and NFC
Continuous Shooting
Normal Continuous Shooting in Auto/P modes: Approx. 0.8 shots/sec.
Normal Continuous Shooting Low Light mode: Approx. 2.2 shots/sec.
Under lighting conditions where flash does not fire automatically. Excluding RAW and RAW+JPEG. Until memory card becomes full.
Storage Media
SD/SDHC/SDXC Memory Cards
File Format
SD/SDHC/SDXC and UHS-I Memory Cards
Print Order Format
Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible
Image Recording Format
Fine
JPEG Compression Mode
Still Image: Exif. 2.3 (JPEG)
Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Monaural))
Number of Recording Pixels
Still Images:
Large: 5152 x 3864
Medium 1 (M1): 3648 x 2736
Medium 2 (M2): 2048 x 1536
Medium: 2560 x 1920
Small: 640 x 480
Wide: 5152 x 2896
Videos:
HD 1280 x 720: 25.00 fps
640 x 480: 29.97 fps
Image data
Approx. Number of Shots Recordable to 16 GB Memory Card
Note: F=Fine
Movie data
Total Movie Time Recordable to Memory Card
The values in the table are based on Canon measurement conditions and may change depending on the subject, memory card and camera settings. After Low-level formatting.
&#42;1 Using an SD Speed Class 10 / UHS-I compatible memory card
&#8226; Recording stops automatically once the file size reaches 4 GB or the memory card becomes full.
&#8226; Recording may stop unexpectedly if a memory card with a low Speed Class is used.
Playback Modes File
Protect, Favorites, Erase, Slideshow, Rotate, i-Contrast, Resize, Red-Eye Correction, Photobook Set-up, Auto Rotate, Resume, Transition Effect
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Hi-Speed USB (Mini-B); direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers
Power Source
Battery Pack NB-11L
Shooting Capacity
Approx. 190 shots
Approx. 245 shots in ECO Mode
Video Recording Time: Approx. 50 min.
Playback Time
Approx. 4 hr.
Operating Temperature
32-104&deg;F / 0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.75 x 2.24 x 0.93 in. / 95.3 x 56.8 x 23.6mm
Weight
4.87 oz. / 138g (CIPA standard)
4.34 oz. / 123g (Body only)
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
