Canon Support for PowerShot A85 | Canon U.S.A., Inc.
PowerShot A85
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 03.05.10
File Size 6.23 MB
Date 04.01.07
File Size 958.98 KB
Date 04.01.07
File Size 2.79 MB
Date 04.01.07
File Size 2.11 MB
Date 04.01.07
File Size 708.04 KB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash and 3x Optical/3.6x Digital/11x Combined Zoom
Image Capture Device
Type 4.0 M pixel, 1/2.7 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 4.2 Million
Effective Pixels Approx. 4.0 Million
Lens
Focal Length 5.4-16.2mm, f/2.8-4.8 (35mm film equivalent: 35-105mm)
Digital Zoom 3.6x
Focusing Range NORMAL: 46cm/1.8 ft. - Infinity
MACRO: 5-46cm/2-18 in. (WIDE), 26-46cm/10-18 in. (TELE)
Autofocus System Manual focus: Available 9-point AiAF/1-point AF (Fixed to center)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 118,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8-8.0 (W), f/4.8-8.0 (T)
Shutter Speed 15-1/2000 sec.
Exposure Control
Sensitivity AUTO*; ISO 50/100/200/400 equivalent *Camera automatically sets the optimum speed.
Light Metering Method Evaluative / Center-weighted average / Spot* *Metering frame with Spot mode is center fixed.
Exposure Control Method Program AE / Aperture or Shutter-Priority AE / Manual
Exposure Compensation +/- 2 EV in 1/3 stop increments
ND Filter Not Available
White Balance
White Balance Control TTL, Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), or Custom
Flash
Built-in Flash Operation Modes: Auto On/Off, Red-Eye Reduction On/Off
Flash Range WIDE: 46cm-4.2m/1.5-14 ft.
TELE: 46cm-2.5m/1.5-8.2 ft.
MACRO: 26-46cm/10 in.-1.5 ft. (When sensitivity is set to Auto)
Recycling Time Approx. 15 sec. or less (battery voltage=4.3V)
Flash Exposure Compensation Not Available
Shooting Specifications
Shooting Modes Auto, Creative Zone (P, Tv, Av, M), Image Zone (Portrait, Landscape, Night scene, Fast shutter, Slow shutter, Stitch assist, Movies), Special Scene Mode (Foliage, Snow, Beach, Fireworks, Underwater, Indoor)
Photo Effects Off, Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Activates shutter after an approx. 2 sec. or approx 10 sec. delay
Wireless Control Not Available
Continuous Shooting Approx. 1.5 shots/sec.
Image Storage
Storage Media CompactFlash (CF) Card Type I
Print Order Format Design rule for camera file system, Digital Print Order Format (DPOF) Version 1.1 (Digital Print Order Format)
Image Recording Format Exif 2.2 (JPEG)
JPEG Compression Mode SuperFine, Fine, Normal
Number of Recording Pixels Still Image: 2,272x1,704 (Large), 1,600x1,200 (Medium 1), 1,024x768 (Medium 2), 640x480 pixels (Small)
Movie: 640x480, 320x240 or 160x120
Number of Recordable Images
Image data These figures reflect standard shooting conditions established by Canon.
Actual totals and file sizes may vary according to the subject, shooting conditions and shooting mode
Time of Recordable Movies
Movie data Above-written figures are measured under Canon's standard conditions and may vary depending on the scene, subjects or camera settings. Total length of movie files recordable on specific CF cards; Individual movie clips are limited to 3 minutes maximum per clip.
Playback Specifications
Playback Modes File Single, Index (9 thumb images), Magnification (Approx. 2-10x), Slide Show or Movie Magnified, Auto rotate, Rotation, Histogram, Sound memos (up to 60 sec.), Auto Play
Erasing Specifications
Erase Modes Still Images: Single Image, All Images Movie: Part of Movie, All Movie
Interfaces
Computer Interface USB (mini-B/PTP)
Video Out NTSC or PAL
Audio Out Monaural
Other CF card slot (accept Type I card). Direct connection to Canon CP Printers and select BJ Printers (no computer required)
Power Supply 1. Size AA Alkaline battery x4
2. Rechargeable size AA NiMH battery (NB-2AH) x4
3. Compact Power Adapter (CA-PS500)AA NiMH: LCD On - Approx. 500; LCD Off - Approx. 1200Approx. 360 minutes (Under Canon's standard conditions*1 with fully charged battery)
Power Source 1. Size AA Alkaline battery x4
Shooting Capacity AA NiMH: LCD On - Approx. 500; LCD Off - Approx. 1200
Playback Time Approx. 360 minutes (Under Canon's standard conditions*1 with fully charged battery)
Physical Specifications
Operating Temperature 32 - 104&degF/0 - 40&degC
Operating Humidity 10 - 90%
Dimensions (W x H x D) 3.98x2.52x1.24 in./101.0x64.0x31.5mm (Excluding protrusions)
Weight Approx. 7.06 oz./200g (camera body only)
Note: *1 Normal temperature (23&degC). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash at every 4-time shooting. Turn camera off and on at every 8-time shooting. LCD brightness setting by Factory default.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
