Canon Support for PowerShot A520 | Canon U.S.A., Inc.
PowerShot A520
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.25.07
File Size 2.92 MB
Date 03.05.10
File Size 6.07 MB
Date 10.25.07
File Size 6.54 MB
Date 05.23.08
File Size 2.92 MB
Date 10.25.07
File Size 10.51 MB
Date 10.25.07
File Size 1.03 MB
Date 03.05.10
File Size 6.23 MB
Date 10.25.07
File Size 1.67 MB
Date 10.25.07
File Size 478.99 KB
Date 10.25.07
File Size 4.33 MB
Date 05.23.08
File Size 1.03 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type of Camera
Type Compact digital camera with built-in flash and 4x Optical/3.6x Digital/14x Combined Zoom
Image Capture Device
Type 4.0 Megapixel, 1/2.5 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 4.2 Megapixels
Effective Pixels Approx. 4.0 Megapixels
Lens
Focal Length 5.8-23.2mm, f/2.6-5.5 (35mm film equivalent: 35-140mm)
Digital Zoom 3.6x
Focusing Range NORMAL: 1.5 ft./45cm-Infinity
MACRO: 2 in.-1.5 ft./5-45cm (WIDE), 11.8 in.-1.5 ft./30-45cm(TELE)
Autofocus System 9-point AiAF/1-point AF (Fixed to center)Manual Focus, AF Lock, AF-assist Beam ON/Off, MF magnified display function available
Viewfinders
Optical Viewfinder Real-image 4x optical zoom viewfinder
LCD Monitor 1.8 inch low-temperature polycrystalline silicon TFT color LCD
LCD Pixels Approx. 115,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.6-8.0 (W), f/5.5-8.0 (T)
Shutter Speed 15-1/2000 sec; can be set in 1/3-stop increments in Manual and Shutter-priority (Tv) Modes.
Exposure Control
Sensitivity AUTO, ISO 50/100/200/400 equivalent
Light Metering Method Evaluative, Center-weighted average, Spot**Metering frame with Spot mode is center fixed.
Exposure Control Method Program AE, Aperture or Shutter-Priority AE, Manual
Exposure Compensation +/- 2 stops in 1/3-stop increments
ND Filter Not Available
White Balance
White Balance Control Auto, Pre-set (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H) or Custom
Flash
Built-in Flash Operation Modes: Auto*, Flash On*, Flash Off* Red-Eye Reduction is available
Flash Range WIDE: 1.5-11.5 ft./45cm-3.5m
TELE: 1.5-7.2 ft./45cm-2.2m
MACRO: 11.8 in.-1.5 ft./30-45cm (W/T) (When sensitivity is set to Auto)
Recycling Time Approx. 15 sec. or less (battery voltage=3.15V)
Flash Exposure Compensation Not Available
Shooting Specifications
Shooting Modes Auto, Creative Zone (P, Tv, Av, M), Image Zone (Portrait, Landscape, Night scene, Fast shutter, Slow shutter), Special Scene Modes (Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets, Night Snapshot), Stitch Assist, Movie
Photo Effects Off, Vivid, Neutral, Low Sharpening, Sepia and Black & White
Self Timer Activates shutter after an approx. 2 sec. or approx 10 sec. delay, Custom timer
Wireless Control Not Available
Continuous Shooting Approx. 1.9 shots/sec.
Image Storage
Storage Media SD memory card
Print Order Format Design rule for camera file system Exif 2.2(JPEG) and DPOF (Version 1.1) compliant
Image Recording Format Still: Exif 2.2 (JPEG)
Movie: AVI (Image data: Motion JPEG; Audio data: WAVE (Monaural))
JPEG Compression Mode Normal, Fine, SuperFine
Number of Recording Pixels Still Image: 2272x1704 (Large), 1600x1200 (Medium 1), 1024x768 (Medium 2), 640x480 (Small)
Movie: 640x480, 320x240 or 160x120
Number of Recordable Images
Image data &#160; Note: N=Normal F=Fine SF=SuperFine
Storage capacity varies depending on the scene or the subjects. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of SD Memory Card. Individual clips are limited to 3 minutes (30 seconds maximum at 640 x 480 resolution). File sizes and resulting number of shots given above will vary depending on the subject, shooting conditions and shooting mode.
Playback Specifications
Playback Modes File Single, Index (9 thumb images), Normal Playback, Special Playback, Movie Editing, Camera Sound Playback
Erasing Specifications
Erase Modes Still Images: Single Images, All Images Movies: Part of Movie, All of Movie
Interfaces
Computer Interface USB (mini-B/PTP)
Video Out NTSC or PAL
Audio Out Monaural
Other SD memory card slot. Direct connection to Canon CP Printers and select BJ Printers via camera's USB cable (no computer required).
Power Supply 1. Two Size AA Alkaline batteries
2. Two Rechargeable size AA NiMH batteries (Canon brand NB-2AH/NB-1AH)
3. AC Adapter Kit (ACK800)AA NiMH: LCD On - Approx. 300 shots (CIPA Test Standard); LCD Off - Approx. 800 shotsAA Alkaline batteries Approx. 180 minutes (Under Canon's standard conditions*1 with fully charged battery), AA NiMH batteries Approx. 300 minutes.
Power Source 1. Two Size AA Alkaline batteries
Shooting Capacity AA NiMH: LCD On - Approx. 300 shots (CIPA Test Standard); LCD Off - Approx. 800 shots
Playback Time AA Alkaline batteries Approx. 180 minutes (Under Canon's standard conditions*1 with fully charged battery), AA NiMH batteries Approx. 300 minutes.
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 3.57 x 2.52 x 1.51 in./90.7 x 64.0 x 38.4mm (Excluding protrusions)
Weight Approx. 6.35 oz./180g (camera body only)
Note: *1 Normal temperature (73&deg F/23&deg C). Shoot images at wide angle and at telephoto end alternatively with 20 second intervals. Use flash at every fourth shot. Turn camera off and on after every eight shots. LCD brightness setting by Factory default.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
