Canon Support for PowerShot A2000 IS | Canon U.S.A., Inc.
![](/etc.clientlibs/canon/clientlibs/clientlib-base/resources/images/image/canon-image-default.webp)
PowerShot A2000 IS
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type of Camera
Type | Compact digital still camera with built-in flash, 6x Optical/4x Digital/24x Combined Zoom with Optical Image Stabilizer System |
Image Capture Device
Type | 10.0 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD) |
Total Pixels | Approx. 10.0 Megapixels |
Effective Pixels | Approx. 10.3 Megapixels |
Lens
Focal Length | 6.4-38.4mm f/3.2-5.9 (35mm film equivalent: 36-216mm) |
Digital Zoom | 4x |
Focusing Range | Normal: 1.6 ft./50cm-infinity Macro: 0.39 in.-1.6 ft./1-50cm (W) |
Autofocus System | TTL Autofocus, Manual focus (shooting standby only in movie mode) |
Viewfinders
Optical Viewfinder | None |
LCD Monitor | 3.0-inch TFT color LCD |
LCD Pixels | Approx. 230,000 pixels |
LCD Coverage | 100% |
Aperture and Shutter
Maximum Aperture | f/3.2 (W) - f/5.9 (T) |
Shutter Speed | 15-1/1600 sec.; Long Shutter operates with noise reduction when manually set at1.3-15 sec. |
Exposure Control
Sensitivity | Auto, High ISO Auto, ISO 80/100/200/400/800/1600 equivalent(Standard output sensitivity. Recommended exposure index) |
Light Metering Method | Evaluative*, Center-weighted average, Spot** * Control to incorporate facial brightness in Face Detection AF ** Metering frame is fixed to the center |
Exposure Control Method | Program AE; AE Lock |
Exposure Compensation | +/-2 stops in 1/3-stop increments |
White Balance
White Balance Control | Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H), Custom |
Flash
Built-in Flash | Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock,Slow Synchro |
Flash Range | 1.0-11 ft./30cm-3.5m (W), 1.6-6.7 ft./50cm-2.0m (T) (when sensitivity is set to ISOAuto) |
Recycling Time | 10 sec. or less (battery voltage=3.0V) |
Flash Exposure Compensation | N/A |
Shooting Specifications
Shooting Modes | Auto, Easy, P, Portrait, Landscape, Special Scene (Night Scene, Foliage, Snow,Beach, Sunset, Fireworks, Aquarium, ISO 3200), Indoor, Kids & Pets, Night Snapshot,Movie |
Photo Effects | My Colors Vivid, Neutral, Sepia, Black & White, Custom |
Self Timer | Activates shutter after an approx. 2-sec./10-sec. delay, Custom |
Wireless Control | N/A |
Continuous Shooting | Approx. 1.3 fps (Large/Fine) |
Image Storage
Storage Media | SD/SDHC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card |
File Format | Design rule for camera file system, DPOF Version 1.1 |
Image Recording Format | Normal, Fine, SuperFine |
JPEG Compression Mode | Still Image: Exif 2.2 (JPEG) Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural)) |
Number of Recording Pixels | Still Image: 3,648 x 2,736 (Large), 2,816 x 2,112 (Medium 1), 2,272 x 1,704 (Medium 2), 1,600 x 1,200 (Medium 3/Date Stamp), 640 x 480 (Small), 3,648 x 2,048(Widescreen) Movie: 640 x 480 (30 fps/30 fps LP), 320 x 240 (30 fps) available up to 4GB or 60minutes per clip, 160 x 120 (15 fps) up to 3 minutes per clip |
Number of Recordable Images
Image data |
Time of Recordable Movies
Movie data | Note: N=Normal F=Fine SF=SuperFine Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media. |
Playback Specifications
Playback Modes File | Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate,Resume, My Category, Transition Effects, Histogram, Index (9 thumbnails), OverExposure Warning, Slide Show, Red-eye Correction, Resize, Image Inspection Tool,Easy Movie: Normal Playback, Special Playback, Auto Rotate, Resume, Easy |
Erasing Specifications
Erase Modes | Still Image: single image, all images Movie: any movie file |
Interfaces
Computer Interface | USB 2.0 Hi-Speed (mini-B jack) |
Video Out | NTSC/PAL |
Audio Out | Monaural |
Other | Memory card slot; direct connection to Canon SELPHY Compact Photo Printers,PIXMA Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Supply | 1. AA-size Alkaline Battery (x2) 2. Rechargeable AA-size Ni-MH Battery (x2) 3. AC Adapter Kit ACK800 (optional)Still Image: approx. 240 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size Ni-MH Battery)* *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.Approx. 540 min. (AA-size Alkaline Battery), approx. 660 min. (AA-size Ni-MH Battery) |
Power Source | 1. AA-size Alkaline Battery (x2) 2. Rechargeable AA-size Ni-MH Battery (x2) 3. AC Adapter Kit ACK800 (optional) |
Shooting Capacity | Still Image: approx. 240 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size Ni-MH Battery)* *LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used. |
Playback Time | Approx. 540 min. (AA-size Alkaline Battery), approx. 660 min. (AA-size Ni-MH Battery) |
Physical Specifications
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 4.01 x 2.50 x 1.26 in./101.9 x 63.5 x 31.9mm |
Weight | Approx. 6.53 oz./185g (camera body only) |
Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian,Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish,Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
CONTACT US
