Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 08.07.24
File Size 4.65 MB
Date 08.07.23
File Size 2.69 MB
File Name User Manual
Date 08.07.24
File Size 2.76 MB
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Image Sensor -1" SPAD Sensor (effective pixels: approx. 2,100,000, total pixels: approx. 3,200,000)
Minimum Subject Illumination 0.001 lux (Color (Night Mode), no light accumulation, f/1.4 equivalent, shutter speed 1/30, 50IRE, maximum gain)
Lens Mount Bayonet lens mount based on BTA S-1005B standards
Video Output Format [Frame rate 59.94P] 1920 x 1080: 59.94P*, 59.94i (4:2:2 10 bit) 1280 x 720: 59.94P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 29.97P] 1920 x 1080: 29.97P, 29.97PsF (4:2:2 10 bit) [Frame rate 50.00P] 1920 x 1080: 50.00P*, 50.00i (4:2:2 10 bit) 1280 x 720: 50.00P (4:2:2 10 bit) * 3G-SDI mapping Level A/B supported [Frame rate 25.00P] 1920 x 1080: 25.00P, 25.00PsF (4:2:2 10 bit)
Exposure Auto, Tv, Av, AGC, Manual AE Shift
Metering Mode Standard, Spotlight, Backlight, AF frame metering
White Balance Manual (MWB), AWB, White Balance Set A (WB-A), White Balance Set B (WB-B), Daylight (Dylt), Tungsten (Tung), Color Temperature (Kelv) Preset setting/color temperature setting: available
Auto Black Balance Available
Iris Manual (control range varies depending on the lens)
Gain 0.0 72.0 dB
Custom Picture CrispImg2 (preset)
Shutter Speed Frame rate 59.94P
1/4, 1/8, 1/15, 1/30, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 29.97P
1/4, 1/8, 1/15, 1/30, 1/34, 1/40, 1/48, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 50.00P
1/3, 1/6, 1/12, 1/25, 1/50, 1/60, 1/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000
Frame rate 25.00P
1/3, 1/6, 1/12, 1/25, 1/30, 1/33, 1/40, 1/50, 1/601/75, 1/90, 1/100, 1/120, 1/150, 1/180, 1/210, 1/250, 1/300, 1/360, 1/420, 1/500, 1/600, 1/720, 1/840, 1/1000, 1/1200, 1/1400, 1/1700, 1/2000 Only when the Extended Shutter Speed is set to [Enable], 1/600 1/2000 options can be selected.
Shutter Speed Limit (Lower) [Frame rate 59.94P] 1/4, 1/8, 1/15, 1/30 [Frame rate 29.97P] 1/4, 1/8, 1/15 [Frame rate 50.00P] 1/3, 1/6, 1/12, 1/25 [Frame rate 25.00P] 1/3, 1/6, 1/12
Flicker Reduction Available
Optical Filters ND filter: motor operated insertion-extraction (manual/automatic), 1 density level (approx. 1/64) IR cut filter: motor operated insertion-extraction (manual/automatic)
Focus Manual, One-shot AF
AF frame: Large, small
AF frame position: Center, specified area
AGC Limit Off/72.0 48.0 dB
Day/Night Switch Auto/Day Mode/Night Mode
Color Bars SMPTE, ARIB, EBU
Smart Shade Control (SSC) Available
Haze Compensation Available
Diffraction Correction Available (excluding certain non-supported lenses)
Chromatic Aberration Correction Available (excluding certain non-supported lenses)
Digital Zoom Available, 10x (Max.)
On-Screen Display Available, English/Japanese
Custom Picture CrispImg2, BT.709 Standard, Canon 709
Video Compression Method JPEG, MPEG-4 AVC/H.264, H.265/HEVC
Video Size 1920 x 1080, 1280 x 720, 640 x 360, 320 x 180
Video Quality 10 levels
Video Output Frame Rate (Output from Network Terminal JPEG: 0.1 15 fps
Frame Frequency 59.94P/29.97P: 0.99/4.99/9.99/14.98/29.97/59.94 fps
Frame Frequency 50.00P/25.00P: 1/5/12.5/25/50 fps
I-Frame Interval 0.5/1/1.5/2/3/4 sec.
Simultaneous Client Access Max. 15 Clients
Bit Rate Control Control Method: MBR, CBR
Control: 128/256/384/512/768/1024/1536/2048/3072/4096/6144/8192/10240/12288/14336/16384/24576/32768 kbps
Protocol Network Protocol: IPv4, IPv6, TCP/IP, UDP, HTTP, SNMPv1/v2c/v3 (MIB2), RTP/RTCP, RTSP, DHCP, AutoIP, DNS, mDNS, ARP, ICMP, NTP, SSL/TLS
Control Protocol: NU (Canon proprietary, Serial), Pelco-D (Serial), ONVIF, WV-HTTP (Canon proprietary), WVCOM (Canon proprietary)
Security Video Distribution: Enable/disable settings for each user level (Authorized user, Guest user)
Access Control: User Restrictions (User name and Password), Host Access Restrictions (IPv4, IPv6)
Encrypted Communications: SSL/TLS
Preset Number of registers: Max. 20 positions
3G/HD-SDI Terminal BNC jack (output only) x 1, 0.8 Vp-p/75 , unbalanced 3G-SDI: SMPTE 424, SMPTE 425, SMPTE ST 299-2 HD-SDI: SMPTE 292, SMPTE ST 299-1 Time code (VITC/LTC)
GENLOCK Terminal BNC jack (input only) x 1, 1.0 Vp-p/75
REMOTE Terminal Circular 8-pin jack x 1 (RS-232C/RS-422/RS-485) Serial communication method can be switched by DIP switch
LENS Terminal Circular 12-pin jack x 1
External Device I/O Terminal Input x 2, output x 2 (for future extensionn)
Memory Card microSD card slot x 1 (for future extension, not recordable)
Power Supply External power source: 12 30 V DC (connector included)
Power Consumption DC input: Max. 23.7 W (camera body only)
Operating Temperature Temperature Operating temperature range DC: -20°C +45°C (-4°F +113°F)
Start-up temperature range DC: -10°C +45°C (-14°F +113°F)
Storage Environment Temperature -30°C +60°C (-22°F +140°F)
Humidity 5% 90% (without condensation)
Dimensions (W x H x D) Approx. 128 x 128 x 184 mm (5.04 x 5.04 x 7.24 in.) (excluding protrusions)
Weight Approx. 2.2 kg (4.86 lb.) (camera body only)
Title Firmware Notice: MS-500: Firmware Version 2.0.0
Advisory Type Firmware Notice
Date 08.08.24
SUPPLIES & ACCESSORIES
