Canon Support for MegaTank MAXIFY GX7020 | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
Print and scan wirelessly from any Wi-Fi® enabled computer, Android™ or iOS tablet and smartphones from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer or mobile device, a wireless router and a wireless printer. All devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Wireless Setup
- Wireless Setup on Windows Computers
- Wireless Setup on Mac Computers
- Wireless Setup on iOS Devices (iPad, iPhone)
- Wireless Setup on Android Tablets and Smartphones
- Go to Wireless Help Homepage
Need additional information or assistance?
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
MegaTank MAXIFY GX7020 | 1 |
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
Printer
High Page Yield | Up to 6,000 (Black & White) / 14,000 (Color) Pages (Per Full Ink Bottle Set)7 |
Print Speed (up to) | Black: ESAT Approx. 24.0 ipm9 Color:FPOT Color: ESAT Approx. 15.5 ipm9 |
Number of Nozzles | Color (C/M/Y): 1.024x3 / Pigment Black: 1,280 / Total: 4,352 |
Print Resolution (Up to) | Up to 1200 x 600 dpi10 |
Ink Compatibility | INK TYPE GI-26 Pigment-Based Ink Bottles (Cyan, Magenta, Yellow, Black) INK TANK & FILL VOLUME GI-26 Black Ink Bottles: 167.0 ml GI-26 C, M, Y Ink Bottles: 132.0 ml (each) |
Paper Sizes | 4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), Legal (8.5" x
14"), U.S. #10 Custom Size: Width: 3.5" - 8.5" / Length: 5" x 47" |
Paper Compatibility | Plain: Plain Paper, High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper, Double-sided Matte Paper; Other (Canon): Magnetic Photo Paper, Restickable Photo Paper, Light Fabric Iron on Transfers; Other (non-Canon): Greeting Card, Envelopes, Recycled paper and Chlorine-free paper can be used Rear Tray Supported Media Weight Plain Paper: 64 - 105 gsm OR Canon Paper: Max. approx. 275 gsm (Canon PP-301) OR Thicker Paper: approx. 115-250gsm Bottom Cassette Supported Media Weight Plain Paper: 64 - 105 gsm |
Printer Features | Document Printing, Photo Printing, Wireless Printing8, Mobile Device Printing,
Business Card Printing, Greeting Card Printing, Label Printing, Square Media Printing Support,
Double-sided Matte Paper Support, Print from USB Flash Drive5 HIGH PAGE YIELD: Up to 6,000 (Black & White) / 14,000 (Color)7 |
Paper Handling | PAPER HANDLING INPUT Cassette 1: 250 Sheets Plain Paper (Letter) Cassette 2: 250 Sheets Plain Paper (Letter) Rear Paper Tray: 100 Sheets of Plain Paper OR 20 Sheets (4" x 6") AUTO DOCUMENT FEEDER 50 Sheets Plain Paper |
Noise Level (Approx.) | Approx. 49.0 dB(A) (Plain Paper) |
Copier
Copy Speed (up to) | FCOT (Color/Simplex): Approx. 12 seconds9 |
Copy Features | 4-on-1 / 2-on-1 Copy, Document Copy, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Multiple Copy (Up To 99 Pages), Photo Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Standard Copy |
Scanner
Scanner Type | Flatbed & ADF (Auto Document Feeder) |
Scanning Element | Contact Image Sensor (CIS) |
Max. Resolutions | Optical:1200 x 1200 dpi (Optical)11 |
Scanner Features | Single Sided (Simplex) Scanning, Single-pass Duplex Scanning Save to PC, Attach to E-mail, Multi-Page PDF, Save to USB Flash Drive, Unsharp mask, Descreen, Reduce slow-through, Rescan, Rotate, Auto Crop, Scan to Folder |
Color Depth | Grayscale: 16-bit/8-bit Color: 16-bit/8-bit Per Color |
Max. Document Size | 8.5" x 11.7" (A4/Letter) ADF:8.5" x 14.0" (Legal) |
Fax
Modem Speed | Max. 33.6 kbps (Automatic Fall Back)12 |
Transmission Speed (approx.) | Black: Approx. 3 sec13 Color: Approx. 1 min13 |
Memory Capacity | Approx. 250 Pages14 |
Speed Dialing | Max. 99 Locations |
Fax Features | Caller rejection, Fax reception reject, Fax number re-entry, Check RX fax info, Dial search, Memory transmission, Answering machine connectivity, Remote reception, Redial, Double sided printing (fax images), FAX to Folder |
General
Dimension (W x D x H) | Closed: 15.8 (L) x 16.2 (W) x 12.4 (H) Trays Extended: 15.8 (L) x 25.4 (W) x 15.3 (H) Weight: 28.6 lbs. |
Display | 2.7" LCD Touchscreen |
Weight | 28.6 lbs. |
Other Features | Auto Power On/Off, Print/Scan/Copy, Quiet Mode, Wireless Direct Connection, Wireless
Connect1, Auto Paper Width Detection, Energy Star® Certified23, User Replaceable
Print Head, User Replaceable Maintenance Cartridge Display: 2.7" LCD Touchscreen Smart assistant & automation support: Amazon Alexa18, Google Assistant18 |
OS Compatibility | Windows:15 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:16 macOS v10.12.6 - 10.15 (Catalina) Mobile Operating Systems:17 iOS®, iPadOS, Android™ |
Standard Interface | Hi-Speed USB Wi-Fi® (Wireless LAN, 2.4/5 GHz, IEEE 802.11b/g/n)8 Wired LAN (100BASE-TX) / 10BASE-T) |
Power Consumption (approx.) | 23.0W Copying (0.9W Standby) |
Software Included | SOFTWARE (WINDOWS15/MAC16) MAXIFY GX7020 Wireless MegaTank Small Office All-in-One Printer Driver Easy-PhotoPrint Editor Software19, PosterArtist Lite Software22 MOBILE APPS & PRINTING AirPrint®3, Mopria® Print Service4, Canon PRINT app2, Easy PhotoPrint Editor App19, Canon Print Service20 (Android), PIXMA Cloud Link2, Creative Park App21 |
Warranty | 3-Year or 80,000 Page* Limited Warranty with InstantExchange Program |
Canon U.S.A., Inc. LIMITED WARRANTY – (USA Only)
The limited warranty set forth below is given by Canon U.S.A., Inc. (“Canon USA”) with respect to the new or refurbished Canon-brand MAXIFY GX-Series inkjet printer product (“Product”) packaged with this limited warranty, when purchased and used in the United States only. This limited warranty will apply to a warranty repaired or replacement Product only as set forth below.
The Product is warranted against defects in materials and workmanship under normal use and service for three (3) years from the date of original purchase, or the printing of 80,000 pages, whichever comes first. Product returned to a Canon USA repair facility, and proven to be defective upon inspection, in Canon USA’s sole discretion and at no charge, will be (a) repaired utilizing new, remanufactured, repaired and/ or recycled parts (b) exchanged for new Product or; (c) exchanged for a refurbished Product, as determined by Canon USA, Inc. This limited warranty applies to a warranty repaired or replacement Product only as follows: a warranty repaired or replacement Product will be warranted under this limited warranty only until the end of the warranty period of the original Product purchased. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink bottles, or maintenance cartridges, as to which there shall be no warranty or replacement. This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty (“Separate Warranty”). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold “as is” and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
a) Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA’s user’s manual or other documentation, or services performed by someone other than a Canon USA repair facility. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user’s manual or other documentation for the Product.
b) Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink bottles or refilled ink bottles, that cause damage to the Product or cause abnormally frequent service calls or service problems.
c) If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON, OR IN, THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER’S LICENSE AGREEMENT.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILTY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON OR ENTITY WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA,. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) CANON USA SHALL NOT BE LIABLE FOR LOSS OF REVENUES OR PROFITS, INCONVENIENCE, EXPENSE FOR SUBSTITUTE EQUIPMENT OR SERVICE, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR ANY OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, YOU ASSUME ALL RISK AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO YOU AND YOUR PROPERTY AND TO OTHERS AND THEIR PROPERTY ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE EXCLUSION OR LIMITATION MAY NOT APPLY TO YOU.) THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT, AND STATES YOUR EXCLUSIVE REMEDY.
A range of Canon USA customer technical support* options are available:
- Interactive troubleshooting, the latest driver downloads, hours of operation, and answers to frequently asked questions (www.usa.canon.com/support)
- Toll-free live technical support Monday–Friday (excluding Canon-observed holidays) at 1-844-4-MAXIFY (1-844-462-9439)
- Telephone Device for the Deaf (TDD-1-855-270-3277)
- Warranty Service:
In the event service is required for the Product during the limited warranty period, a Canon USA Customer Care Center representative will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, you will be provided instructions for Canon USA’s then current warranty service procedures. You may be asked for the Product serial number and/or other information pertaining to your Product.
This limited warranty give you specific legal rights, and you may also have other rights, which vary from state to state.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747 USA
© 2020 Canon U.S.A., Inc.
Canon is a registered trademark of Canon Inc. in the United States and may also be a registered trademark in other countries.
